low cost? $650 and up PLUS Maxi of some sort to display...
for automotive use, I would go with the autel and make sure you get the plug inductive cable/octopus, if you plan on ignition work. the other two are general purpose scopes and will require a laptop and more accessories to do similar work the Autel does.
Bench scopes vs application specific scopes is what it will boil down to, and what your budget is.
We don’t hear a lot about the autel, how come? Everytime when I watch videos on youtube, technicians are using pico, snap-on modis or vantage pro.autel is about 500bucks, can be used with any tablet android or windows based .
Picoscope real nice software, Hantek can do job but software is awful .
If plan on doing serious auto use I'd go autel out of those 3.
It the best out of those 3 models, hantek waste of money beside level entry learning stage and it not that great here as software such junk . the better picos are nice but over you price and overpriced but i do own one lol .
I bought a Hantek 6022be. And a DC current clamp. And a couple of 20:1 attenuators. And a secondary waveform pickup. This scope requires a PC (or maybe a tablet, I don't know). I had available to me a 4 year old laptop taken out of service at work. So all in, under $200, and if I decide that I need more channels (it's 2 only) or higher quality, then I'm not out too much.
I've only played with is so far. First thing I forgot to turn on the current clamp (all my experience is with AC clamps which are passive) Once I figured that out, I play around, using a couple of back probes, looking at injector current patterns, secondary and primary ignition patterns and the output from both crank and cam sensors. I was pleasantly surprised at how well it all worked.
I've always liked to have wiring diagrams for my cars, and using this kind of tester it is absolutely mandatory that you know how the system is supposed to work and what each wire does or you're just going to be wasting your time.
Can you take a screenshot of the compression test.I recently picked up a Maxiscope 408 from eBay for 360 shipped to the door. I've never used a scope before today, but I used it to set the gains on my car audio amplifier. All that involves is looking for clipped sine wave signal at the hertz my speaker is designed to play. In my case, 40 hz for the subwoofer. I plan on using mainly for automotive use, but figured a simple single channel test would be a good starting point. If I was experienced at using an oscilloscope, I would give more feedback on it, but that will have to wait till further down the road. I do plan on trying out a relative cranking dynamic compression test Monday or Tuesday using multiple channels and an amp clamp.
Sent from my Z962BL using Tapatalk
sample rates better on the 6074 plus it got 4 channels and comes with more leads.
I seen the 6074 for around 190bucks .
Why not a used Snap-On Vantage Pro?
I've seen them for ~$300. It's enough for auto repair. I haven't run into anything where it wasn't adequate yet. Maybe I don't do enough.![]()
So is the Pico 2240A useless? I want to get a scope to play with. I currently have a car with a bad wheel sensor. On my scan tool it looks fine. I am only a DIY. Is the 2240A worth the money?
I know the software is good. What are the downsides? Speed? How will that effect the use of the scope?
LabNation makes a good 2 channel scope for a reasonable price. I have one and like it. Pico costs a lot more and doesn’t work on phones and tablets. Pico does have good waveform libraries and has 4 channel models. For the money thought lab nation will get you going and will be a great addition to your setup.
I have never seen an EETM303 sell on eBay for under $500! Most "Buy It Now" prices are over $700.
For $300-$350, I would buy one !
Sorry for sort of digging this up from the past. Why hasn't someone come up with a way to use a cheaper scope, like a Hantek or other with the better Pico Software? Also does anyone have experience with the MicSig tablet scopes?
Because that software is proprietary. Part of the price tag for a pico is that the software development is included in that price. Honestly they've been more than generous making the software open to all. If some scumbag company came along and tried something like you speak of they'd lock it down and either start charging or require registration.
Its already bad enough companies like Autel copy pastes Pico program files but luckily for Pico the Chinese don't seem to care about making a truly competitive scope option (the Autel one is garbage).
Only thing really wrong with hankek for auto work is the poor software.
Hantek best option for low price, the pico 2204 good way go if likely use it more and want the intuitive software, capture data features and waveform gen features .
2204 and 2205 totally usable and fairly cheap auto diag tools .
Well, I just purchased a Hantex 6074BE, we will see how it works. VinceG here seems to really like it, as well as others. I feel like the people who really don't like it either got a bad unit, or really haven't given it a chance. Or maybe even they need the guided tests because they don't really know what they are looking at. Anyways the way I figure for the price I paid its worth the leads alone. I can slowly build this kit if needed and one day if I need to upgrade I can just buy a bare Pico.
