Wire stripping tools
chaosracing
Kutztown, Pa
I have a pair similar to the vise grips one you show. I have had it for many years now. It must be getting worn out because now it does slip once in a while. I forget the brand name. It also does not have the wire guide (which I would not use anyway if it had one)
I never knew about the scissors though.
silver2000
Falmouth, Massachusetts
I have also noticed that they wear out over the years. As far as the wire guide. I never used to use it but then my OCD kicked in when I am stripping wire for outlets and I like getting the exact same amount of "strippage" This is a little more important if you start to use the Wagos so you constantly get the perfect strip but experience can also deliver a nice result too.
Olafur
Iceland
Pictured are 3 almost identical cable cutters. Their secret is they are fantastic all-around wire strippers. I post this because with all the talk about wire strippers here - these never get mentioned. And I kid you not, you will have great difficulty finding electrician or a mechanic over here without them, since they double as cutters and strippers and do both very well and fast. I favour the Bost or Knipex versions, but many others works just fine.
Just my $02 :thumbup:
Jbullfrog
Avoca, Iowa
I have one of these and it works great for smaller harness wires. It auto strips from the rear. I like them for repairing harness connections, in the field. They are rated for 14-28 gauge.
I have auto strippers like the ViseGrip, but almost all auto strippers are awkward for left handed people, we hold the tool in our left. I have a Cornwell t-rex style stripper also, but it isn't the greatest, as you have to have access to the end of the wire and clearance past it for the tool.
Jbullfrog
Avoca, Iowa
Most strippers for stranded wire should not be used on solid wire. It is harder and will burr the cutting edges of tools meant for small stranded wire.
pepi
Woodstock, GA
wire stripper.JPG my favorite wire stripper!
That's GREAT........ funny the perfect reply :thumbup:
Now I'm thinking who would watch a video about wire strippers ...... someone that needs to be told when to come in out of the rain ?
Bryanthegreat
Minnesota
I prefer Klein for my wiring needs. I usually only use the auto strippers to take the jacket off of multi conductor cables.
silver2000
I like the manual tools as well but I never seem to be able to master the results with them but they are likely more practical for someone doing it every day.
jayrush13
Lebanon Oregon
I have never seen this kind of stripper here in the US but am very curious now. Do you have part numbers for the knipex or bost versions? Could only find the shell ones in your picture imported through ali Express
TwoInch
NW INDIANA
Re: Wire stripping tools video
Can't do the Wranglestar "like a pro" gimmick marketing stuff.
Sent from my LGLS676 using Tapatalk
HenryAZ
MEMBER EMERITUS
South Congress AZ
If you have a lot of wires the same gauge to strip, these WIHA Industrial wire strippers are adjustable from #24->#8 AWG. The jaws form a diamond shape, are adjusted by a screw and held by a locknut. $20 and some change at Amazon.
For basic stripping, I like the Ideal T-Strippers, two sizes for smaller and larger gauge wires.
Olafur
Iceland
I bought the "shell" version on Ebay from China. I think they are "fake" but I am not sure.
The Knipex version can be seen here;
https://uk.rs-online.com/web/p/cable-cutters/7276746/
Bost number seems to be 121.01
From this discussion:
https://www.garagejournal.com/forum/showthread.php?t=370840&showall=1
I have several of those, IMHO very versatile and useful tool for cutting and stripping cables, wires, zip-ties etc.
Wamsutta
Amarillo, Texas
With my Klein's on a 16AWG wire, I have to first break the insulation with the 16AWG die and then pull the insulation off with the 14AWG die. :headscrat
TwoInch
NW INDIANA
Why so? What happens if you use 14awg slot to break and pull?
I know solid awg is one size smaller than stranded awg.. Does this have something to do with it?
Wamsutta
Amarillo, Texas
If I pull with same slot that I break it with, it'll break one of the strands off as I'm pulling; that's why I pull with the larger slot.
Now if I use any of my Stride-Imperial made strippers, they never break any strands. They're a pleasure to use.
JBH
If a wire stripping tool has "dies" for different thicknesses of wire, it's probably not a very good tool.
I don't know why Americans love those stamped holey things when these are easy to use and work with every thickness of wire and insulation.
f121
UK
This design must be patented by one company. Now that you shared this one I have seen it labeled under Irwin, Stanley and Klein. The Klein is a little different but it's the same design. Very interesting.
I think the patent has expired, but it may be owned by Stanley. Either way, they are brilliant and well worth the $20 or so. I do a lot of auto wiring, splicing looms into other looms for engine conversions, and they make life much quicker
silver2000
Those Klein's you have pictured are the ones I have. I like the way they feel in my hand but they're finicky with wire insulation.
I have also used those Kleins with the same experience. They messed up some wires I was working on one with very little to work with. Not good for me either.
Sine Swept
I didn't see a OLFA knife, 909's or the small yellow adjustable's that I used on most 18-14 gauge wire listed in there either.
The knife is great for #1 and larger. 909's can strip wire with the anvil cutter and the ubiquitous small yellow stripper's are great once you master a little muscle memory.
Wamsutta
Amarillo, Texas
These are the two best I've ever used. They strip the wire easily and never damage the strands. Imperial is the OEM for a lot of different brands. The IE-155 can be had under the Craftsman and Williams brand.
Imperial IE-110
Imperial IE-155
2manytools
Mt Pleasant, MI
Except those don't work with all, all the time, and don't work with NM (non-metallic) wiring insulation. They must be adjusted for changing strip sizes. If you are only working on one size, they are great, otherwise you have a little trial & error getting it just right. No idea where you are from, but I know some European wiring has round insulation so they would be fine for, but in the USA it is oblong. The easiest way is a stripper with "dies" i guess everyone is referring to, specially for NM insulation.
2nd image is NM. If you are a residential electrician in the US, you would probably be laughed off the job if you didn't have a pair. Commercial guys that have to run in conduit, would very likely never use them.
JBH
Except those don't work with all, all the time.
They pretty much do if one knows how to use them.
While I mostly use a Wiha-branded Pressmaster Embla now, before I bought that I never had trouble using the standard manual tool. Until the Embla it worked better than every automatic tool I've tried: the Irwin "self-adjusting" one with serrated clamps on top that never grip right, the one with two knives and different hole sizes that only works well with wires that are sized exactly right, etc.
By contrast, the forged pliers-style strippers work with every type of small- or medium-sized wire I've tried: from white or yellow Romex, speaker wires ranging from 10-16AWG (including with PTFE insulation), line level cables from 22-28AWG, etc. They are generally too small for really thick stuff, such as welding cable.
Or you just ignore the adjustment screw entirely. A human with functioning nerves electrically connected to a working brain can easily feel the difference between insulation and copper!
On solid core wire the only real differences are that the pulling motion to remove the insulation using the stamped holey thing is less natural, and that one has nothing to gauge exactly how much insulation is being stripped. But stranded wire varies widely in conductor OD due to strand thickness, strand shape (hexagonal vs. round), etc. So a tool with a 1-size-fits-something-random stripping hole is not going to cut as cleanly as an infinitely-adjustable stripper.
The shape of the insulation is irrelevant. It could be round, oblong square, spikey, etc. The only thing that matters is the shape of the conductor underneath it.
Or are you referring to the outer jacket? If so, neither stripping tool is called for. Rather, one uses a knife, scissors, or something like this:
2manytools
Mt Pleasant, MI
Well that's an entirely different tool than you previously pictured. The previous one isn't worth a hoot for Romex. Sure you can use a knife, but not the most efficient method. I love my adjustable strippers you first pictured, but using them by feel isn't how they we're intended to be used, otherwise they would save money & not put an adjustment screw in. Not as fast feeling, than knowing it is set just right, and just go at it.
Can you provide an example of what you mean by forged & "stamped holy things," as I read them as being the same, but the last post makes me think otherwise.
Wamsutta
Amarillo, Texas
The Imperial IE-123 can be used to strip the outer jacket of the oblong shaped Romex 12-2/14-2 cables:
Imperial IE-123
Imperial also makes a version for Klein:
Klein K1412
JBH
Yes. It's basically a safety knife to cut the outer jacket of a multi-core cable. You adjust the knife to the insulation depth, insert the cable in the vise, spin the knife around, and the outer jacket gets cut.
I think it's useful to take a step back and define terms. "Wire" and "cable" are different things.
Wire: A single conductor (solid or stranded) wrapped in insulation
Cable: Multiple wires arrayed inside a common jacket
If there are specialty tools that let an electrician strip both a Romex cable jacket and the wires inside it, then that is useful for electricians even if it's an objectively crude tool. I've never seen an electrician use such a tool.
Funny, I've used mine with to strip the ends off of wires in Romex multiple times. Obviously it's not designed to strip cable jackets.
If you strip a lot of different sizes and styles of wire you can go by feel. If you really only strip one size and style of wire, use the screw and I guess you can clamp-and-go.
They are different. One is a couple sheets of perforated sheetmetal with handles, and the other is a tool.
Using the same brand, here's an example of a "stamped holey thing":
and a forged wire-stripping tool:
jayrush13
Lebanon Oregon
I don't think they sell them in the USA if I click on that link it says page not found. If I try looking up the part number on knipex usa website it doesn't find anything.
***** because I would like to try them out.
