Prichman38
- Joined
- Sep 10, 2016
- Messages
- 81
Troy Bilt 2800 psi gas pressure washer on clearance from $299 down to $74.75
Item #806916
Item #806916
Great! Thank You!didn't want to keep polluting the thread, but yes.
not all unions are constricting, e.g. https://www.zoro.com/zoro-select-hose-mender-38-in-barb-brass-6afh5.
and i've connected different sized hoses and pulled fluids out of all kinds of tanks. if you think rubber hose is too thick or has too high a wall thickness, use some flexible copper tubing. thread sealant helps there.
also, pro tip: viscosity thins when warmed.
i honestly don't get the skepticism over an $8 tool that works a treat.
Item #806916
Anyone in Alaska?
Store Quantity Price Shipping
Fairbanks, AK 4 $39.75
San Francisco, CA 5 $74.75
Missouri City, TX 1 $74.75
Hamburg, NY 3 $74.75
Sierra Vista, AZ 2 $74.75
Maple Grove, MN 2 $74.75
Camillus, NY 3 $74.75
Blaine, MN 2 $74.75
Rocky River, OH 1 $74.75
Ogdensburg, NY 4 $74.75
W. Jackson, MS 1 $74.75
Hibbing, MN 2 $74.75
Chicago, IL 1 $74.75
Oneida, NY 3 $74.75
Potsdam, NY 6 $74.75
Lake Elsinore, CA 1 $74.75
Matamoras, PA 4 $74.75
S. Jackson, TN 1 $74.75
Ithaca, NY 4 $74.75
Commerce Township, MI 1 $74.75
S.W. Tucson, AZ 1 $74.75
Clovis, NM 4 $74.75
Griffin, GA 6 $74.75
Missoula, MT 2 $74.75
Rapid City, SD 9 $74.75
Cranston, RI 2 $74.75
S.E. Houston, TX 1 $74.75
Modesto, CA 1 $74.75
Lake Havasu, AZ 2 $89.70
Rancho Cordova, CA 2 $89.70
When items are discontinued you cannot input the item number into Lowe’s.com. Try to google Troy-Bilt 2800 Lowe’s, should come up with a link. Or try this link: https://lowes.com/pd/Troy-Bilt-2800-PSI-2-3-GPM-Cold-Water-Gas-Pressure-Washer-CARB/1000178201Can someone confirm the item number or provide a link?
I'm getting 806916 as "does not exist". The Troy Bilt I am finding is unavailable anywhere, including several of the stores above. That one is Item # 961611 Model # 020712
Came across these tonight at lowes. New to me. Didn't realize Irwin made pliers wrench. Anyone ever try them?
Sent from my SM-G965U using The Garage Journal mobile app
The NWS stuff was discontinued because it did not sell at 44 USD a pop.Made In Germany by any chance?
Assuming they are NWS Rebrands like some of their other pliers were
About the LiquiVac: I think most mowers have an oil drain plug under the mower deck so draining the oil isn't too much of a pain.
But I think most (all?) Honda mowers do not have an oil drain plug. It is a real pain IMO to change the oil in a Honda mower because you need to elevate it on some kind of platform so that it is higher than the oil drain pan, then tip the entire mower onto its side, being careful not to let the mower tip right over while carefully aiming the oil stream. I'm thinking oil changes on my Honda are going to be a lot easier and cleaner now.
I just tip my Honda mover over the storm drain out at the curb twice a year. Easy peasy
Really![]()
Three hours and seven minutes for the first nibble. The fishing in this lake *****.
Really![]()
phew! just placed a LiquiVac in the cart with expedited shipping for your late
giftI just tip my Honda mover over the storm drain out at the curb twice a year. Easy peasy.
My store showed 6, they only found on and the pump was missing, so they canceled my orderThe LiquiVac has been a popular item on here. I just got mine in yesterday and haven't opened to check it out.
I can't find one for shipping in the stores that I tried, if anyone would let me know I will apretiate
I need more tooolsss!!!
Sent from my ONEPLUS 6T using Tapatalk
im DYINGThree hours and seven minutes for the first nibble. The fishing in this lake *****.
I can't even imagine how small the hose would have to be to fit in my dipstick tube? Like someone mentioned earlier though, it would probably work great for a transmission.
I picked up two liquid vacs one for gas and one for oil, these will come in really handy changing the oil on a Mercruiser V6 on the boat, the current drain is so slow it takes several hours for it to drain out.
