2018 Lowe's deals/sales/clearance thread
Prichman38
Troy Bilt 2800 psi gas pressure washer on clearance from $299 down to $74.75
Item #806916
bubinga
didn't want to keep polluting the thread, but yes.
not all unions are constricting, e.g. https://www.zoro.com/zoro-select-hose-mender-38-in-barb-brass-6afh5.
and i've connected different sized hoses and pulled fluids out of all kinds of tanks. if you think rubber hose is too thick or has too high a wall thickness, use some flexible copper tubing. thread sealant helps there.
also, pro tip: viscosity thins when warmed.
i honestly don't get the skepticism over an $8 tool that works a treat.
Great! Thank You!:thumbup:
danum1aaron
Lakewood, CA
Item #806916
Anyone in Alaska?
Store Quantity Price Shipping
Fairbanks, AK 4 $39.75
San Francisco, CA 5 $74.75
Missouri City, TX 1 $74.75
Hamburg, NY 3 $74.75
Sierra Vista, AZ 2 $74.75
Maple Grove, MN 2 $74.75
Camillus, NY 3 $74.75
Blaine, MN 2 $74.75
Rocky River, OH 1 $74.75
Ogdensburg, NY 4 $74.75
W. Jackson, MS 1 $74.75
Hibbing, MN 2 $74.75
Chicago, IL 1 $74.75
Oneida, NY 3 $74.75
Potsdam, NY 6 $74.75
Lake Elsinore, CA 1 $74.75
Matamoras, PA 4 $74.75
S. Jackson, TN 1 $74.75
Ithaca, NY 4 $74.75
Commerce Township, MI 1 $74.75
S.W. Tucson, AZ 1 $74.75
Clovis, NM 4 $74.75
Griffin, GA 6 $74.75
Missoula, MT 2 $74.75
Rapid City, SD 9 $74.75
Cranston, RI 2 $74.75
S.E. Houston, TX 1 $74.75
Modesto, CA 1 $74.75
Lake Havasu, AZ 2 $89.70
Rancho Cordova, CA 2 $89.70
dkroth
Rochester, New York
Anyone in Alaska?
Blaine, MN 2 $74.75
Oneida, NY 3 $74.75
Ithaca, NY 4 $74.75
Clovis, NM 4 $74.75
Can someone confirm the item number or provide a link?
I'm getting 806916 as "does not exist". The Troy Bilt I am finding is unavailable anywhere, including several of the stores above. That one is Item # 961611 Model # 020712
danum1aaron
Lakewood, CA
When items are discontinued you cannot input the item number into Lowe’s.com. Try to google Troy-Bilt 2800 Lowe’s, should come up with a link. Or try this link: https://lowes.com/pd/Troy-Bilt-2800-PSI-2-3-GPM-Cold-Water-Gas-Pressure-Washer-CARB/1000178201
kamilio
Criminal
Puget Sound
^^^^^ I noticed the price changed on brickseek for the local store that actually had some in stock, threw on some pants and ran out there. Got one, several more available.
Shelf price $104.65
Add sales tax
Minus mil mylowes
Total out the door was $102.66
homeschool
Was at the Commerce Twp MI store a few hours ago and they had two of the Troy Bilts left, along with two of a slightly better model for $87, down from $399. I passed because my dad already has one I can borrow, but boy was it hard to lol.
Spdfreak91
Mass
My lowes has the troy bilt washer for 119, but they said they would price match less, anyone have a shelf tag pic?
unslow1
Illinois
The LiquiVac has been a popular item on here. I just got mine in yesterday and haven't opened to check it out.
soloz2
Western NY
I too got one of the vacs, but haven't opened it. Too many other projects going on.
Sent from my ONEPLUS A5000 using Tapatalk
gamp945
About the LiquiVac: I think most mowers have an oil drain plug under the mower deck so draining the oil isn't too much of a pain.
But I think most (all?) Honda mowers do not have an oil drain plug. It is a real pain IMO to change the oil in a Honda mower because you need to elevate it on some kind of platform so that it is higher than the oil drain pan, then tip the entire mower onto its side, being careful not to let the mower tip right over while carefully aiming the oil stream. I'm thinking oil changes on my Honda are going to be a lot easier and cleaner now.
dkroth
Rochester, New York
I just tip my Honda mower over the storm drain out at the curb twice a year. Easy peasy.
mrvm
PA
Three hours and seven minutes for the first nibble. The fishing in this lake *****.
:thumbup:
:beer: phew! just placed a LiquiVac in the cart with expedited shipping for your late xmas gift
f575gtc
I picked up two liquid vacs one for gas and one for oil, these will come in really handy changing the oil on a Mercruiser V6 on the boat, the current drain is so slow it takes several hours for it to drain out.
Jacan
Pembroke pines - Florida
My store showed 6, they only found on and the pump was missing, so they canceled my order
I can't find one for shipping in the stores that I tried, if anyone would let me know I will apretiate
I need more tooolsss!!!
Sent from my ONEPLUS 6T using Tapatalk
Mctiger1985
Louisiana
Should be any store with no stock
superskaterxes
Maryland
Has anyone seen these for lower than 299? My store has 2 in the clearance section both marked 299 ($10 off retail o_0). Waiting for it to go way lower. 0ca2416d92ed763709792e5a48e72fab.jpg
Jacan
Omg thanks, what a ******* I am all this time checking for stores with stock, at the same time i should question Lowes for restricting shipping on stores with stock
Hmmm
eljefino
I can't even imagine how small the hose would have to be to fit in my dipstick tube? Like someone mentioned earlier though, it would probably work great for a transmission.
I drained my plow truck through the dipstick tube b/c the drain plug is super buggered. Took 4 days using aquarium tubing. I didn't vac it, just sucked to get it going.
volpster31
SOUTH JERSEY
i got one for pulling the gas out of lawn equipment to winterize them,but it says it has leather seals inside...will gasoline destroy this thing????
