C_F
That steering wheel is worse than the one on my '70 Charger when I bought it in '86. This one was even glittery.
Dude, that wheel is groovy, and far out
Nothing says '70's street rod like a metalflake steering wheel.
Nice work Riven![]()
Thank you. It's coming along.
As soon as I get this door prepped, it's just about ready for paint. Then I can put the interior door panels in, and all the door seals.
Really looking forward to being done with the paint and interior
Then it will be onto some oil leaks and a new exhaust.
Also need to tighten up the steering. Anybody add a front end sway bar to one of these old trucks?
I added a bar to my ‘66 and it’s unreal how much difference it made.
Nice to see progress! I have owned at least 10 diff 73-79 trucks and really like them. Ordered a new 1979 loaded Lariat trim with 460 and it was 7400.00. Still have order form.
Nicely shaped blob; looks exactly like the dark side of the moon.![]()
RivennHewn I believe the part that rusted away is the air pump check valve. Does your engine still have an air pump? The air pump system pumps more air into the exhaust to help burn fuel that was unburnt in the combustion process. It does not go into the intake system to help warm up the engine.
That EGR crossover tube along the back of the heads were a PITA to work around. On my 1988 F250/460 cid I had one break on vacation and had to change it in a parking lot in a small town in Colorado one year. Access was less than ideal to say the least.
while shopping online, I saw the rubber boots. They were cheap, and should help the truck go faster.
Better watch yourself, Riven. Besides making it go faster, they will also improve handling, your gas mileage, and the cool factor will make you a chick magnet.
Didn't realize it had completely rusted out. Engine started running and sounding really bad. Must have been failing for some time.
I believe it's the Exhaust Heat Control valve, but the PO just capped it off.
I could be wrong. I don't really remember working on one before.
Help me out if I'm wrong.![]()
I think it now qualifies as a race truck.
That's the AIR injection manifold and valve. It's connected to the air pump on the engine.
I don't know if replacement parts are available.
Thanks. The PO deleted the pump, and plugged it.
Maybe why it rusted out.
“Limited access”
Been awhile, figured it was time for an update.
Haven't had time/energy to post much lately, but I'm finishing up a project at work and hoping things will slow down a bit.
Finally got the wallet in shape to get it into a paint booth, could use a recommendation in the Seattle area.
Truck is running great. Well, kind of.
Started having an issue that's got me stumped.
Runs fine while running around, but when I get out on the freeway it starts cutting out.
1st I lose power, then a backfire out the tail pipe, then the tach will max out at about 8K rpms. The engine isn't doing 8k. At speed, it turns just over 2K.
I put it in neutral, and coast for a bit, then it kicks back in for a bit then repeats.
The tach comes off the coil. I've replaced the coil. I've replaced some shoddy wire connections that feed the coil.
It will also have the same problem going down hill, using compression to slow me down.
Any thoughts?
Any thoughts?
Where did you get the shocks and brand?
Also steering stabilizer?
Thanks, CT
Cant wait to see her all painted upTruck went to the paint booth, won’t be back til next weekend.
