I finished digging the trenches and glued up the sprinklers. Feeling confident, I back-filled the trenches and put the concrete squares back (after soaking the soil. I'll give it some time because the squares are not even with the adjacent rows yet. I'll flood the patio a couple of times to see if that helps. I didn't take pictures because it doesn't look like anything was done.
Last week the 30-year-old fan in the bathroom took quite a while to start. It's the builder's cheap model but with a bladed fan rather than a squirrel cage so it's noisy. I decided it was time to replace it (it's in the 70s so I can venture into the attic). I might have held off for another 30 years had I realized where the fan was located. It's connected to that flex pipe and the path to get to it is under the air conditioner air handler.
When I first tried to get to it, my knees gave notice they weren't happy with the 2x4 pad. Went to the workshop and found a 25-inch 1" x 14" shelf and screwed it into the rafters. Still not a comfortable position but laying on my chest was only annoying. The fan came out with two screws and some foil tape on the duct. Those Harbor Freight LED lights are real handy!
I measured the old fan box before ordering a new one and chose one the same size. In that size the fans are rated at 50cfm. Because our house is always either heated or cooled, the humidity never gets real high and we've never had the mirrors fog up even after a long shower. It's just the two of us so bathroom fumes taking more than a few seconds to clear is covered in article 18 of our marriage contract. To me, a box that doesn't require a new opening is a good deal.
In my haste to get the new fan installed, I bent all four tabs on the box. I was forgetting the side with the mounting flange couldn't fit that way -- easy-peasy unbending in the attic. I thought I was on the home stretch hooking up the wires and putting the cover back in place. Turns out the nut on the Romex clamp interferes with the opening so I can't get the cover installed. Disconnect the wires, go to the workshop and grind the nubs off the nut. That worked! Re-connect the wires, stuff everything inside and mount the box -- all while laying face down a few inches above the dust that passes for insulation.
What I thought would take an hour at most was well into the second hour and the attic was getting warmer. I managed to get the box screwed to the truss -- not perfectly but I was no longer in the mood to re-do it. Also managed to tape the adapter to the flexible duct using foil tape. Ducts turn out to be the one place you never use Duct tape. Pushed all the cellulose/dust insulation back in place and crawled out. Without even testing the fan, I unscrewed the shelving and placed it in its new home in the attic. It's the perfect work platform for the attic trusses and I'm sure I would use it for a project if left in the workshop.
Back in the bathroom, I plugged the fan in, re-installed the mounting screws and turned the circuit breaker back on. This Delta fan is much quieter than the one it replaced. Supposedly it has a noise level of 1.0 sones and therefore needs a light to tell you it's running. It ain't THAT quiet but Liane is happy.
Are we talking the same Bob? With his mental state, I'd think it was more like "Abbynormal".
: I said something dumb and it gave me a retort and went back to the song. it is nice for music or to tell you a joke and a bunch of other stuff I haven't tried.
mode.
