Of the three brands listed, i would opt for Proto. I don't care for the wide in the hips thick boxed ends of SK. I don't care for the almost zero offset boxed ends on some wright wrenches along with their standard length, so that leaves Proto. Proto are quite nice but, the satin finished ones won't win any beauty contests. I like the length of Proto Wrenches, their balance, and fit. The Proto anti slip end is less about teeth and more about a couple of well placed notches.![]()
all of this hubbub about wrench length. i find in most cases it is a non issue. i have a variety of length wrenches. in most sizes 3 or 4 lengths and in some maybe 8 sizes. sometimes a slightly shorter or longer wrench is better and honestly an extremely long wrench is not that handy in most cases. an sk wrench is shorter than some but is long enough for most jobs.
Seems to be an overwhelming number of you liking the wright and sk but more so the Wright. They were my top 2 contenders . What Wright sets seem to be best value and what vendor did you use? Summit has the sae set for around 200$ after coupon. The metric set is pricier there than others though.
http://www.wrighttool.com/distributor-locator.htmlAppreciate the the photos. I do like the look of sk but more seem to prefer the Wright . Wish we had a local place to check them all out.
I agree in most cases it is not an issue and most folks will never notice a difference. However I encounter it on a regular basis to where every little bit of length matters significantly with old rusty farm equipment.
Except the proto open ends are practically useless. The notches are stupidly placed on the ends which just promotes end spread. COO aside? I'd go Carlyle long....
i agree 100%!
sometimes a little extra length makes a huge difference. the flip side of that is that quite often the slightly longer length of some wrenches make them just a pain in the **** after the initial breaking force is used.
so in essence, on a regular basis i find the longer wrenches too long and the slightly shorter ones significantly easier to use.
to wrap it up. i find it silly that people are arguing over or on this quest to find a wrench that is slightly longer when there are other features that are equally or more important. if i had to pick one feature on a wrench that was a deal breaker, length alone is not it.
Zoro has the metric 758 set for $185 with 20% off coupon. Summit has SAE 758 for $206 with coupon code. I just ordered both last week.
I was looking at Williams vs Wright vs others. I went with Wright based on the overwhelming feedback here. As for the shorter length on the Wright, all sizes are longer than the Craftsman RP that I’ve been using for 25 years so they should be fine. I have plenty of other really long stuff.
Aesthetics aside, the SK SuperKromes do not have any type of off corner/"flank drive" design. Considering that off shore brands are now touting these features, SK is really behind the curve on this.
Pros and cons to chrome vs satin finish. I have personally never had an issue holding onto a chrome wrench, but I don't deal with a lot of a greasy environments/parts. I wipe all of my tools after after a project, so I like the chrome for the simple fact that it's easy to clean.
SK Tools: 1-3/16" 12 Point Fractional Regular Combination Chrome Wrench
Details:
- 1-3/16" 12 Point Fractional Regular Combination Chrome Wrench
- SK wrenches are Drop Forged for maximum strength and durability with a High Carbon Alloy steel for precision, power and long life.
- SureGrip® drive design drives the side of the fastener, not the corner, to provide increased strength and avoid rounding of rusted or damaged fasteners.
- SuperKrome® Plating delivers toughest finish with high polish plating which results in jewelry-like finish providing long life and maximum corrosion resistance.
- 15 Degree offset and thicker shank with rounded edges for comfortable grip.
I have a set of Proto ratchet wrenches and the ASD works very well. Mine are Taiwan so I can't personally speak to their USA combos but if they are functionally equivalent I'd have confidence in their open ends. SK on the other hand... not so much.
Sorry, doesn't work. I tested a bunch and Proto/MAC does no better than a standard combo before it rounds. You should try FD+ or Opti-Torque Pro. Its night and day. The latter two will rip the corners off the bolts before they round.
I recognize that it's not on your list, but based on your initial post I would throw the Tekton hat into the ring. Their full polish 8-22mm set can be had for right around $40, they're made in Taiwan and seem to be a pretty healthy quality based on my use.
You can definitely tell what kind of tool user I am from my post history, but to save you a couple clicks I'm a home mechanic doing a little of everything, from oil changes to engine swaps. There are some instances where I think it's worthwhile to buy high-grade (I'm shortly going to pick up a set of Blackhawk/Proto flare nut wrenches from seeing a buddy's HF flare nut shatter).
I actually ordered a set of tekton to compare to the sunex stubby I ordered. They do look great for the money but I have not messed with them yet.
On the other hand. Had a set of Wright 915 sae show up today. Pretty disappointed in them off the bat. The 7/16 is quite warped while all the other lay flat on a bench. Also there is one that is not marked 2.0. Not sure if it is an old stock or what the deal is with that. I try to keep everything matching so that is not a giant deal but for the price I would expect all the same. . All the other sizes look greatly finished aside from the other small issues.
Id certainly email/call whoever you purchased them from for sure, or possibly Wright themselves. Obviously no reason you should have received a non 2.0 wrench with a batch of 2.0 wrenches. I assume they'll send you two new wrenches. Really annoying to deal with tho, I've had some poor tools show up the last few months and its always a little disappointing.
I'm also curious how the notches promote spread.
One thing to keep in mind if what your working on if it matters if you mark up the fastener. If it does, then the SK set is the way to go. (not sure what other quality brands don't have the "grip" feature).
If it doesn't matter, your crazy to get wrenches that don't have some sort of "grip" (wrightgrip,FD+,ASD, pick your flavor....)
My Wright 915 SAE set arrived while I was away this week. I didn’t pull each one out of the roll to inspect, but the couple I pulled look and feel good. The only wrench not marked 2.0 in the set I got from Summit is the 5/16”. Not that it’s practical or necessary for my stationary use, but I do like the roll for storage.
My 958 metric set from Zoro shipped today, so I should have it late next week.
