Modifications to the HF 4 and 5 drawer service carts - what changes have you made?
Shootnjunky
Northeast Ohio
I am going to get a Blue one today at my local HF
Well I called today and they had one in stock in blue. even though mine I guess was coming tomorrow on the truck I stopped and snagged the one they had today.
All together and now just have to spend time organizing stuff. Which is not high on my list today :lol_hitti
NitroShark
Greenville, SC
Re: Remove Lid Lock but Not Permanently
I wanted to be able to open the drawers with the lid closed. There are a number of people who have done this. But I wanted the ability to add that feature back in when wanted/needed.
Thanks for this Mod. I been trying to come up with a simple solution and you nailed it.....
dodge610
North Canton Ohio
Just emptied my box out that i sold into the new yellow one :bounce:
ihateminimumwage
Went by HF to pull the trigger on a black 5 drawer yesterday (glad I didn't since there's a better coupon a page up) and was surprised the only black shelf they offered is the smaller one for the 4 drawer cart. I measured and it's too skinny to line up with the bolt holes on the 5 drawer black cart.
Any chance someone has the old Sunex shelf installed and could get the measurements of it? I know it fit perfectly on my old 4 drawer, but I sold that years ago. I just know I used the hell out of the shelf on my old cart with a diagnostic laptop and as a general catch-all.
ptgarcia
Alta Loma, CA
I have the Sunex prybar/screwdriver holder and the bolt holes do not line up. I don't know how it compares to the shelf, though. I can measure the width when I get home if its helpful.
ihateminimumwage
They offer color coordinated shelves for all the 5 drawer carts.
Well, I'll be damned. I just checked the HF site and found a part number for the full size black shelf. Shows me for listening to the local manager saying the little one is all they offer.
braxx
Dearborn Heights, Michigan
I've looked but I didn't see info for what tool chests fit in the bottom of the series 2 , 5 drawer cart.
I'm looking to pick on up tonight but I don't want to assemble it until I have a set of drawers to put on the bottom.
I found a pic for reference but I'm wondering if there is a "best" option of filling the bottom with drawers.
Super Mech
Bronx,NY
I’m curious about this too.
Hammer1963
Kentucky
I am anxiously waiting to some info on this subjects as well
toolmutt
Texas
^^^^^I don't know why but George Carlin's routine on bigger house / more stuff just came to mind. :lol_hitti
zanyad
NE Ohio
I have a small middle chest I plan to put in the bottom of my service cart. Haven't decided exactly how to mount it. Things to keep in mind when choosing a chest to insert in the lower shelf opening:
  • Width of drawers must be less than width of opening in cart
  • Total height of drawers fits vertically within opening
  • Allow for access to drawers, using one of two methods:
    • Design a platform that will both lift the chest to the correct height for access and block it in to keep it from sliding around
    • Cut lip to allow access (may need to reinforce shelf with angle iron or a piece of steel to replace strength lost to cut)
Some posts to check out:
toolmutt
Texas
That’s my box! No offense taken. I think you are right I just filled it up with stuff I think I need but in reality don’t use.
Just means you need a bigger box (house). Then you get more stuff. Then need a bigger box. Then get more....oh, you get the idea.
aka Larry
Eastern, NC
hoonjr
scissor
Flower Mound, TX
I set up my 5 drawer to use for amateur endurance racing. I'm hoping that this will simplify getting our tools on and off the trailer, as well as help us keep organized at the track.
I started by boxing in the bottom. Then added a 2x4 "bumper" to the back and wrapped it in some HD door mat. Made a couple of hooks to screw to the back of the bumper to hang an extension cord and air hose.
I borrowed TerryH's solution for my longest handled pry bar and breaker bar, and Rx7toAudi idea to use HF magnets to keep screwdrivers from rattling around. I also added a power strip on the bottle holder.
To keep ratchets and extension bars in the side rails, but also have them easy to get a hold of, I added some 2" aluminum angle leftover from the breaker bar mod to raise them up.
The top tray and all of the drawers are shadowed using HF anti-fatigue floor tiles. This should make it obvious when tools are missing, minimizing the chances that we send a car out on track with tools under the hood. I put all of the sockets on generic aluminum rails from Amazon and screwed neodymium magnets to the bottoms to keep them in place.
6 plastic ArtBin bins fit just about perfectly in the bottom section to hold consumables. I like having handles on the front and hinged/attached lids that won't go missing.
Oh, and of course a bottle opener for when the track goes cold.
Ign
Butte Peak ND
I'm planning on using mine largely under a 2 post lift.
In my shop I don't need to lock it and I decided the lid was just too "muchy" open upright. It eats up Z space and means you can't come at the cart from any direction.
Folded back I still wasn't crazy about it, it makes the cart deeper overall and I could see the pockets of my pants catching on it.
So I just drilled out the rivets and removed it. I then removed the lock 'cause they did an impressive job of making it protrude way into the top tray.
Then I decided I wanted to de-badge it just 'cause. The adhesive is pretty serious. I easily got the badge off w a heat gun, then remove as much of the foam adhesive as you can with heat and a plastic scraper. Finally, chlorinated brake cleaner broke down the remaining goo (Goo Gone didn't touch it).
I might sell the lock with keys or the struts if anyone wants them. PM me
MushCreek
Upstate South Carolina
The older ones had a big yellow safety sticker on the upper right hand drawer. I tried everything known to man to get that stupid sticker off. I ended up damaging the paint by the time I got it all off of there, so I covered the damage with a 'Binford' sticker. Thankfully, my new yellow one didn't come with that sticker. I was able to remove the 'US General' badge just by slowly pulling it off. It didn't even break.
giants
California
There was a comment early on here that a nut can get loose and force shut all of the drawers. The poster suggested tightening the nut, but didn't explain where the nut is.
Can someone post a pic of that nut's location?
Thanks!
Handyandy23
Ontario, Canada
Where did you order the neodymium magnets from? I have those same socket rails and that looks like a really good idea!
BTW all of the modifications are really well done, nice set up!
seabeerob213
navy
HF magnet rails and steel wrench rack, HF socket rails. Through socket organizer is just a scrap piece of particle board with some holes drilled in it, and part of the package from the set screwed to it to hold the wrench and extension. May just make a new "rail" for it's sockets and put the wrench in the top with the ratchets. Capri bit sockets, and kobalts. Metric Capri and kobalts left, sae Capri right. Wera screwdrivers. Spray can tray mount up top for blades and brushes and the like.5693614894b764475744c42f66b1e1b2.jpgeb8e0ee2b7ac511b26488e7d12a41840.jpg8a12f914cc7b42b96320fbf8cc528975.jpg
Sent from my ONEPLUS A6013 using Tapatalk
Edit, just got another wrench rack and more magnets.93be736cced965897f08ee5ea9f137ca.jpg
scissor
Flower Mound, TX
Thanks everyone - this thread was an inspiration and the reason I created an account. The project was a lot of fun.
The magnets are from eBay. Something like $15 for 25 of them. They were pre-drilled in the centers so #4 flat head screws fit perfectly. They are brittle, so I put a washer between them and the rail to keep them from breaking when the screws were tightened. After that I haven’t had any issues.
giants
California
Thanks. Would you provide a link to eBay's listing?
scissor
Flower Mound, TX
Found the listing, but I don’t have enough posts to post links. Try searching for “25 50 Strong Countersunk Ring Magnets 3/4" x1/8 " Hole 3mm Rare Earth Neodymium”. When I search for that it’s the top result.
Muggzy
Orange Co., NY
Very nice mods
Sent from my Pixel XL using Tapatalk
For the magnetic tool holder,
is it possible to remove the plastic backing so that screws don't have to be driven into the cabinets and the magnetic back can directly attach to the cabinet?
I just knocked the magnets out of the magnetic tool holder and put them in some 1/2" heat shrink to hold them together.
I can't post a link because I don't have enough posts, but if you search "U.S. General Series 2 Tool Cart Lid Storage" on youtube I put a video up about it.
giants
California
Thanks.
Someone else said that he tried this and broke the magnet. What tool did you use to knock the magnets out of the magnetic tool holder?
jdewitt
Here!
You only need one more post to upload images. So get busy, 'cause we want to see pics. :bounce:
Will do!
Thanks.
I pulled the paper/plastic sticker that covers the actual magnets off, then struck the bar on the edge of my steel welding table (pretty hard) and they just popped out and stuck to the table. Started at the top of the rail and worked down it popping one at a time. They didn't have much adhesive holding them in.
Well, that was post #5, so now I can post the link.
<iframe width="560" height="315" src="https://www.youtube.com/embed/YH4muLXctSE" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
dalehsc
New Brunswick Canada
Super job creating a great set up!:thumbup:
Ign
Butte Peak ND
I'm SERIOUSLY considering moving the handle to the front and getting a second shelf, ie one on both sides
