Ayuh,..... I've been buildin' blacktop roads, parkin' lots, 'n driveways up here in far northern NY with 26 seasons behind me,.......
The "State" mix is what the State uses on hy-ways, but isn't the same topcoat used on some driveways,.....
Up here in Jeff Co. We get 3 basic choices of mix,......
Type 3 Binder, the stones can be as big as yer thumb, the entire thumb,.....
Type 6 top, aka: State mix, the stones are as big as yer thumb nail, maybe the 1st joint of yer thumb,.....
Type 7 top, the stones are no bigger than the nail on yer pinky finger, or smaller,.....
Of course there's variations of these mixes, from type 1 base with stones the size of yer fist, to tennis court mix, which is sand, 'n dust,....
For "Rich folks", We'll put down 3" of type 3 binder, then an inch of type 7 top,......
For the rest of Us, We put in type 6 mix, 2" is standard, 3" can be done, but is rare,....
Parkin' lots, 'n roads usually get atleast 3" of binder, then capped with an inch or two of type 6,.....
The "Strength" of asphalt is like other concrete, the bigger the stones, the stronger the mix,.....
The 6" base, I feel is minimum,.... 8" to a foot is where I like to be,......
Add a layer of fabric under it, if it's a "Soft" spot,.....
Proper drainage of the dig-out, or box-out, as well as the stone, 'n asphalt is critical,.....
