CM Block Grinder bearing replacement - 3 meathods
torqueman2002
SE Michigan
CM Block Grinder bearing replacement - 3 methods
This thread shows 3 ways to remove, and 1 way to install bearings on a grinder arbor/shaft.
Feel free to comment and add other ideas.
I chose to place this thread in the Vintage Tool Discussion section, because I am more active here than the other sections; but, the methods can be used on newer grinders.
While this may seem basic to some readers, the question is asked on the 'let's see your craftsman block grinders' thread from time to time. http://www.garagejournal.com/forum/showthread.php?t=157794
It is an active thread with close to 8,600 posts currently.
So, to make finding answers, resources, suppliers, etc .... quicker/easier, I started 'Craftsman Block motor Bench Grinders - What's the Fuss (with resource information)' thread. http://www.garagejournal.com/forum/showthread.php?t=249539
This thread will be/is placed in the above threads.
3 styles of bearings, you may encounter. (L to R; Open, Shielded, Sealed)
Cross-sectional views.
NTN brand designations.
NTN brand numbering guide.
Pressing surfaces guide.
Bearing Cross Reference (NTN Website)
http://www.ntnamericas.com/en/
For additional information and resources, see: http://www.garagejournal.com/forum/showpost.php?p=5657009&postcount=73
Bearing Removal - begins on page 2.
T
torqueman2002
SE Michigan
Bearing Removal
Often, the bearings will remain on the shaft after the grinder is disassembled.
This can be for a number of reasons, some are listed below.
  • tighter interference fit to shaft than housing bore
  • bearing and shaft are seized due to rust
  • damage, debris, nicks, ... on the shaft
Before attempting bearing removal, inspect and correct for the last 2 above conditions. It is important the shaft surface be smooth, to allow the bearing bore to slide over the shaft during bearing removal.
On occasion I have used a fine file and/or emery cloth to 'polish' the arbor shaft surface.
Note: These methods apply to CM Block grinders with start-up relays. For grinders with start-up centrifugal switch, care must be taken to first disconnect and remove the
centrifugal switch before the arbor/shaft/bearing assembly is removed.
Note: The following Methods 1 - 3, are demonstrated on a CM 1/3-HP m-397.19580 Block grinder.
Method 1 - Soft faced hammer and vise. (my personal least favorite)
Important - To avoid damage to the rotor/shaft, use soft faced covers for the vise jaws. ie - copper, wood, plastic, ...
1) Install the rotor/bearing assembly in the vise, DO NOT tighten the vise jaws onto the arbor/shaft.
Note: To avoid damage to the arbor/shaft/threads, leave the shaft nut installed, with the shaft threads BELOW the top of the nut, not as pictured below.
2) Support the bearing/shaft assembly on the vise jaws, with the jaws as close to the bearing inner bore as possible. DO NOT tighten the jaws, the assembly should be free to move downward in the following steps.
3) Insure the 'lower' part of the arbor/shaft/bearing assembly is free of any obstructions.
4) Using the soft-faced hammer, hit the shaft nut, driving the arbor/shaft downward and away from the bearing.
Bearing Removal - Method 2, begins on the next page.
T
torqueman2002
SE Michigan
Bearing Removal, continued. Note: Before attempting bearing removal, insure the shaft surface is smooth, allowing the bearing bore to slide over the shaft during bearing removal.
Method 2
- Bearing Splitter and Puller with Moveable Jaws
Note: The pictures in Methods 1 - 3, are demonstrated on a CM 1/3-HP m-397.19580 Block grinder.
1) Install a bearing splitter as close to the arbor/shaft as possible, while allowing the shaft to move.
Either mounting method will work. The above ^^ method seems to support the bearing bore more.
2) Install the splitter/shaft/bearing assembly in the vise with soft jaw protectors and lightly tighten the vise to hold the assembly for the next steps.
Note: To avoid damage to the arbor/shaft/threads, leave the shaft nut installed, with the shaft threads BELOW the top of the nut.
3) Install the puller onto the splitter/shaft/bearing assembly.
4) Insure the arbor/shaft threads are protected with the shaft nut and if needed a washer.
5) Use the puller to draw the bearing 'up' the arbor/shaft, freeing the bearing from the arbor/shaft.
Bearing Removal - Method 3, begins on the next page.
T
torqueman2002
SE Michigan
Bearing Removal, continued.Before attempting bearing removal, insure the shaft surface is smooth, allowing the bearing bore to slide over the shaft during bearing removal.
Method 3
- Bearing Splitter and Puller with Fixed Bar and Bolts.
Method 3.1 - Presses.
I've seen a number of bearing replacements that use correct sized sockets/pipes and a press - arbor/hydraulic.
Presses and pullers use even force that are gentle on the bearing assemblies.
The key is to find the correct socket/pipe diameter and length to fit on the race and over the shaft - in the case of Block bearings.
Bearing Install - "Fire & Ice", begins on the next page.
T
torqueman2002
SE Michigan
I have used vise jaws, an arbor press, and a brass punch to install bearings on grinder arbor/shafts.
But after 'discovering' this "Fire & Ice" method, it is the only way I install bearings.
Note: Before attempting bearing install, insure the shaft surface is smooth, allowing the bearing bore to slide over the shaft during bearing install.
1) Place the rotor/arbor/shaft in the freezer until the rotor reaches about 25F.
2) Warm the replacement bearings to about 135F. A coffee mug warmer is shown below.
3) Install and lightly secure the 'frozen' rotor in a vise with soft jaws.
4) Install warm bearing onto cold rotor/arbor/shaft. The bearing usually 'falls' right into place against the arbor/shaft shoulder.
5) Assure the bearing inner bore is fully seated against the arbor/shaft shoulder.
Note: If the bearing is not fully seated against the shaft shoulder, use a soft metal (brass) drift and hammer to lightly tap on the inner bore, until the bearing is 'home'.
The above original bearings that were removed were:
NDH 77503 | ID=17mm | OD=40mm | W=12mm
Replacement bearings NTN 6203ZZC3.
http://bearingfinder.ntnamericas.co...ow-radial-ball-bearings?itemids=130253+130486
Edit - June 05, 2016.
Bearing Install - "The Steam Bath method."
I stumbled upon another way to heat-expand a bearing for installation.
Wrap the bearing in a damp towel and pop it into the microwave for about 1:30 min/sec.
Thanks for looking.
ex_nihilo
Texas
Very helpful thread. The fire and ice was awesome. Since I don't have a coffee warmer I just put them on a skillet on the stove-top at its lowest setting. It worked great!
