The Abrasive Blasting Resource Thread
dkmc
NYS--Upstate in the corn fields
In post 428, DKMC mentioned a pneumatically operated pulse valve in lieu of a foot pedal I assume to minimize flow restriction.
How do these valves work? Anyone configured one?
https://www.garagejournal.com/forum/showpost.php?p=7449080&postcount=428
So, a lot of the foot pedals that come with cabinets, have 1/4" ports and even smaller passageways inside that restrict flow. If you have a big enough compressor and want to take advantage of higher flows from larger air jets on siphon (or Pressure Pot) systems, some of the 1/4" pipe fittings and foot pedals might be the limiting factor to higher CFM air flow.
The Pulse Valves have 3/4" ports! I suspect they'll easily flow in excess of 100 CFM. The way they work is, they are spring loaded CLOSED. There is a 1/8NPT Pilot port on the valve that you apply air pressure to, which overcomes the spring, and opens the valve.
So, chances are you'll still use a foot pedal to control the operation of the Pulse Valve....but the Pulse Valve only requires air pressure with very little if any flow to operate. You may need to modify your foot pedal so pressure bleeds off the pilot line when you let off the pedal......
O
OccupantRJ
Eastern North Carolina
O
OccupantRJ
I refurbish equipment for a hobby during retirement, so prepping parts is a major part of the activities. These are pictures of a flywheel grinder I am working on that got wet during previous storage with grinding dust all over the work area. This one is a real challenge, but I’ll git ‘er done! I could not succeed with out my abrasive blasters. The round piece is for the blasting newbies to show their potential, before and after.
O
OccupantRJ
at what point I must change 1/4 hose to 3/8 hose in order to move media and air with a 8 mm gun ?
In my opinion, any suction style blaster needs 3/8” ID air feed hose and a 5/8” media suction hose. If by 8mm you mean the nozzle size on a suction gun, this is the size combination I use on my gun, which is 5/16”, or around 8 mm. Be aware, the air jet in a suction gun decides how much air is required, not the blast nozzle size.
Jvvmusme
Bogota, Colombia
yes the air jet is 4mm. and the nozzle is 8 mm.
what size hoses I need ?
I use 1/4 hoses with 6mm gun, but when will I need 5/16 or 3/8 hoses ?
Thanks
930dreamer
Amarillo,TX and Stinnett,TX
It's been almost a year and I'm no closer to a filter bag solution, the person that told me he'd send the plans for a conversion to a cartridge filter hasn't. New cost for originals are $1400 and I need to sh*t or get off the pot with this cabinet. :(
larry4406
Northern Virginia
What mesh size screen are you using to sift your media?
I found this chart which equates grit size to sieve size but I don't fully understand all the columns.
Watched this youtube video of his automated sifter and at the 2:08 minute mark he does a screen shot of the mesh he used but I can't find it.
O
OccupantRJ
I don’t sift the glass beads, just replace them as needed. On the aluminum oxide cabinet, I use a kitchen sifter as a strainer on the abrasive before using it in the cabinet, or if I open the feed portion of the separator due to an issue with flow. I drain that abrasive, then strain it before reusing in the cabinet. On the large portable blast pot I use standard screen wire in the bottom of a fill funnel to screen out any stray pebbles and such.
O
OccupantRJ
A part I am presently blasting in the alox cabinet. Rather heavy to turn and twist it while blasting. Notice the full flow attachment of the media hose of my custom built gun. There is no hose barb there to restrict media flow. It uses a compression o ring to hold the hose into the body of the gun. There is a link to this gun in post #1.
lis2323
OccupantRJ. I know it’s been said, but thanks for compiling this thread and keeping it updated. I find it an excellent resource and refer to it regularly.
O
OccupantRJ
You are all welcome. Feel free to input any information or experiences you have relative to blasting. I just noticed that this thread is over 5 years and going.
O
OccupantRJ
The compressor head on that one is completely different than the Gordon Smith design like mine.
O
OccupantRJ
I went on a road trip with my BIL today and picked up a blast cabinet to get him into the game. It was the Central Pneumatic industrial cabinet with dust extractor for $375, new price was at $1150. Catalog picture below. I think he did OK.
fwillison
Tulsa, OK
Siphon better than pressure pot for moisture issues?
I'm thinking about a siphon feed vs pressure pot blaster for outdoor use.
I've read that moisture is the most common problem with blasting, and using a typical hobbyist size compressor, this will be worse. Especially without expensive air dryers.
In this case, wouldn't a siphon feed be better?
The siphon feed doesn't put the moist air into the media, but rather adds air at the output/gun. Makes sense to me.
May be slower be less frustrating and less clogs.
dkmc
Re: Siphon better than pressure pot for moisture issues?
It may also be so much slower it'll be equally as frustrating.
There is no free lunch with Abrasive Blasting.
If you wanna do the deed, you gotta have the tools, depending on what
$$$$ you want to invest, and how much time you want to spend.
O
OccupantRJ
True. Blasting can be somewhat of a go big or go home proposition. I started out with a siphon pot. It was frustrating to say the least. For small parts, even a small blast cabinet is the way to go. For anything larger, you pretty much either have to go big or pay someone.
isb cornbinder
That Central Pneumatic industrial cabinet looks exactly the same as the MODUBLAST 2448, I paid $3000 for. (tax incl) Modublast make their cabinets in Edmonton, Alberta. I wonder if they make rebranded cabinets for other sellers.
