The Abrasive Blasting Resource Thread
dkmc
NYS--Upstate in the corn fields
So I have a thought on Dust Collection.
If I should post this in a separate thread, I will, just let me know.
I've never seen a dual cyclone dust collection system and I'm wondering why not.
Most more elaborate commercial systems, Siphon or Pressure have a "Reclaimer" and then the fines go into a dust collector with some sort of filter bag, pleated paper, etc. The fine dust clogs up the filter so quickly, there are features in place to clean the filters mechanically, or with a blast of air.
The woodworking crowd uses a cyclone to separate out all the chips, dust, and fines, and then sends the mostly clean air to the filter element, which keeps it clean-er and lot longer.
I'm wondering why the commercial systems don't use a second cyclone after the reclaimer to catch mostly all the fines, and then send the mostly clean air to the filters.
The filters would stay much cleaner, and time would be saved without having to clean them so much. Any blast cabinet that gets used a fair amount, would benefit from reduced labor and downtime and from less frequent stops for cleaning the filters, and the filters would last longer, so cost savings there. Filter bags, or the large cylindrical pleated filters are costily to replace when they wear out. Every time they are upset with cleaning methods, (mechanically shaken, or air blast) they wear out a bit. Seems like the second cyclone separator would pay for itself in not a very long time.
Any thoughts on this, please lets hear them.
O
OccupantRJ
Eastern North Carolina
Good points, but on the empire type system that I copied for my cyclone separator, the fines get ejected into an upright filter bag with a 5 gallon bucket at the lower end. They go a decent amount of time with little attention. Other than tapping on mine occasionally i remove and beat it a bit like cleaning a rug, then turn it inside out and blow it off with a long air nozzle. Mine is made of duck fabric.
The Empire brand factory bag on the unit where I worked got cleaned about every several years and it lasted about 30 years before being changed out. That unit was used several sessions daily.
O
OccupantRJ
930dreamer
Amarillo,TX and Stinnett,TX
600 cfm for $2000??? I'm sure 30 gallons of compressor lube oil isn't cheap.:thumbup:
dkmc
Fuel tank capacity: 90 gallons.
Yikes!
That's near identical to the one I had with water damage in 2 cylinders.
It sat and lingered in the lost projects file. Then we went to plan B and scrapped it out. Hey, it 'seemed' like a good idea at the time.
lis2323
I came to my senses and decided to list the Quincy rotary screw I had planned to use. An out of town buyer picked it up yesterday.
I was hoping he had a flat bed so that I could load from the side but that didn’t happen.
Thank god for long forks. [emoji1]. Terrific buyer and another smiling face [emoji106]
lis2323
Extended forks ROCK.
I could have used the forks on the telehandler to reach past the lowered tailgate without the vertical mast restriction but I was too lazy to walk to the other end of the farm for a two minute job.
lis2323
That one is our spare that I keep around the maintenance yard.
They are sooo handy.
We also run a Kesmac. They’re pretty cheap now (Kesmac) and I wouldn’t hesitate considering a used one)
Moffett is the most popular and kind of the industry standard.
My conventional shop forklift has wide front tires and runs on packed gravel lots okay.
This pic was of a set of new tires but you can see part of the Kesmac on the rear of the deck. Kind of....
930dreamer
I'm going to look at this in the morning, condition unknown $200.
Strouty
Southern Maine
I would think that those compressors would see 100k hours, so it could be 109k. I bought one that had 55k and it was considered lower hours.
930dreamer
Kellogg American 462 in PA;
dkmc
That's massive.
I went to an engine show last weekend, and was happy to see a line up of oldie compressors.
930dreamer
I'm a bit short power wise to get this up and running, FB for sale 50hp.:shocking: Couple it to a diesel engine?
930dreamer
I like these also;
