SarcasticDwarf
Got the first sheet of drywall up on the ceiling (only took three hours) and then realized I need a laser level or something to keep the screw lines straight.
I just went through this too. Had read somewhere to put something reflective near where they keep trying to build the nest.
I have a crumpled piece of aluminum foil hanging right where they kept going. Haven't had to pull a nest down in a couple weeks.
First time installing Dewitt radiator in little red LS3 swap. Found out the bottom outlet rests on the sway bar. SMH Aftermarket part fit. 1982 Corvette
I'm surprised it has a clearance issue. We put one of their radiator/electric fan combos in Jeff's '70 LT1 and it fit perfect. I got one of their radiator/brushless fan combos for my Malibu. It's supposed to be a drop-in other than getting larger rubber mount pads. DeWitt's makes great stuff and they're great people. They gave me the quote for my radiator/electric fan combo over two years ago and when I ordered it last fall, they honored the original quote, even with upgrading to the brushless fans and making a custom shroud.
Tommy
Get better soonest SDM and Mag!.
Well wishes Sawdustmaker - you'll be making sawdust again in no time!
Picked up the $150 off Husky 52" tool box. I am impressed and glad i chose it over the HF box. No knock on HF but I just have a thing for matte black and gloss black combo.
Soft close drawers and comes with liners.
And i didnt get a picture of ALL the packaging, but the last pic is just half of it.![]()
Sent from my SM-N950U using Tapatalk
Thanks! It *could be* a bit of overkill, eh? I mainly picked it because of the rounded corner
Soft close drawers and comes with liners...
I've been watching that one too but was reading that the top and bottom go on sale around Memorial Weekend for about $300 off so I'm sitting and waiting right now.
Having made my first MC ride of this year (a weekend run to the TX hill country) I was reminded of previous frustration with my gadget-charging troubles.
I seem to have too many gadgets, cameras, etc and everything these days uses USB charging cables. My setup was desperate for upgrading, needed more and more powerful ports and hopefully a bit higher quality pieces for plug retention.
I looked at a bunch of hubs with lots of slots, but they all were hampered by being connected by a single cable, and really low current capability. I found these “marine” port assemblies and powered them with a hefty cable, switch and fuse.
Each port is rated 2.4A. There are six ports so max draw (if you actually had full load on each, simultaneously )would be about 15A. My previous setup could only deliver 4A (total for four ports, using adapter).
Two of these new ports are actually QC compatible for up to 30V! with certain devices.
The first one has an LED voltage display and they are all switched do that I can shut off the bank of ports when parked for a while.
I should *finally* be able to reliably charge batteries while riding without the silly things taking forever AND becoming unplugged from jostling around.![]()
That's a cool idea, maybe squirt a little bar oil in the holes.I have been trying to come up with a cool way to store my chainsaws so I decided to make this chainsaw tree from an old 6x6 and plate of aluminum I had laying around.
The wood is very dry, so rust shouldn't be too much of a concern. I hope.
That's a cool idea, maybe squirt a little bar oil in the holes.![]()
Lay a rubber snake on top of the track.
If that's a *treated* 6-by I'd definitely oil it!
oh boy would i be peeved if i coulda saved an additional $100 on that. But i am going to go over to the Homedepot deals page and ask those fellas if there is a time frame for doing a return/rebuy to get the better deal.
