stickshift
Update: If you've been following along, just skip ahead to post #81 for updates.
OP:
I'm looking to add several circuits - 3 x 120V 20A lines and 1 x 220V 20A line. Is that possible with this panel - seems there is some free space underneath the existing breakers. Meaning, can I either extend the main line feed strips that the breakers connect to (not sure if they make extension kits), or can I replace the existing breakers with slimmer breakers? The existing breakers are ~1" tall (the bottom ones are connected together, and some of the others are split into 2 separate circuits).
Or is the better option to set up a sub-panel, and move one of the existing circuits over (to free up a slot to feed the sub-panel), and add all the new circuits to the sub?
OP:
