I have an 816 that has been around my shop for a while, and I am just getting around to trying to get it operational.
I have already made a couple of repairs. One of the eccentric screws for the horizontal adjustment was stripped due to someone using a nyloc nut on it and making it too tight. I repaired it by making a bushing to hold the unthreaded section behind the threads so that I could hold it in my lathe. I slid the bushing on, built the threads up with weld, then turned it down and rethreaded it. Sorry, no pics of that.
One of the guide arms looked like it had been left loose for a long time, and there was almost nothing left of the upper reference surface. I didn't take a pic before I fixed it. I built it up with silicon bronze tig brazing, then machined it back to spec.
I am having an issue with out of square cuts though. I am going to do some more messing around with spring tension, but I don't think that is the issue. It cuts perpendicular to the base of the machine, but out of square to the vise jaw. With a 16 inch framing square it looks almost perfect to the vise jaw, yet the cut is almost 1/16th out of square over 4 inches. I have seen the mention of shaft bushing, and those are the next thing I'm going to look at.
I found the manual on vintage machinery, but it was nice to find the sheets for inside of the wheel cover, as somebody painted over them.
Does anybody know if you can still get the brushes? I haven't had any luck finding them. The holders were still there, but no brushes.
