rooster4321
- Joined
- Jan 22, 2018
- Messages
- 62
How do I search this thread for a 2 and 1/2 gallon wet dry vacuum from Harbor Freight
Sent from my KYOCERA-E6560 using Tapatalk
Just checked the 20% coupon in the magazine/coupon book that comes in the mail. You're right, Central Machinery excluded. Guess that's the new policy going forward. Eventually everything in the store will be excluded.
Do the coupons depend on the HF location or personnel to get used? I used them for years but lately there 20 or 25 % off do not work for much. I went to buy a roll of mig wire and they would not let me use the 20% because they called it a welder. Cashier said they could not override the computer. I understand their intent on using it on welders or high priced items but the wire was just a welding supply. Is this also why they are name branding more of their merchandise? by the way the wire went back onto the shelf. If i'm going to buy Chinesium wire Menard's is 3.00 cheaper.
why? Do they not work? Get loose, what?
I was thinking about getting these
I have the Lowe's variety, they work greatThey get leaky.
They worked great for me, for the first couple weeks, so I bought more to outfit all of my garden hoses and stuff, and then, of course, started breaking down/leaking.
I don't think it's limited to the HF ones, either - I've bought them at a couple other locations thinking that it might just be the HF ones, but they all ****.
Shame.
1/2 In. Grommet Installation Kit 104 Pc - Pass
I bought this kit to put tie down grommets in a canvas cover I made for my jeep's winch. I used an arbor press to punch the holes and peen the grommets. The punch was sharp and the grommets peened perfectly. I only wish the grommets were brass instead of aluminum. But for my purpose, they will be fine.
Can you give the details on that winch? I've been trying to find something similar to lift the ground tackle on a boat. If it can pull a Jeep, it can pull 300lbs of anchor and chain off the bottom.
Thanks.
Same here, used the Lowes quick connects professionally with an electric pressure washer flushing HVAC coils and they never leaked.I have the Lowe's variety, they work great
Harbor Freight just lowered the price on this socket set from $39.99 to $29.99:
https://www.harborfreight.com/64-Pc...d=mEmail_s1021_3719b_5off50&lid=3,144,689,245
Does anyone know the range of socket sizes?
Is this any good?
I don't know the range of sizes, but I will say I'm generally not a fan of their round head ratchets. It's likely that they're the same sockets they sell on their lonesome, which have been holding up just fine for me. I'd get the Pittsburgh Pro ratchets though.
Either way, for $30 it's not a huge gamble. I keep a HF set of 3/8" sockets in my AX bag just in case.
Thanks.
What is an AX bag?
Well played. AX = autocross, think "honey I shrunk the road course". It's racing accessible to everybody, and it's a hell of a good time for not a ton of money.I'm ready to pull the trigger on a HF horizontal/vertical band saw. As is typical, they have two stock numbers; is either 93762 or 62377 preferable to the other?
I'd like an ammeter. Anyone have experience with the Harbor Freight Cen-Tech Clamp Meter?
https://www.harborfreight.com/digital-clamp-meter-96308.html
I don't have any experience with this meter but you might want to consider a meter that measures DC through the clamp if you ever want to use it for automotive or electronics. It will cost more than the HF one but the DC clamp is so much easier to use.I'd like an ammeter. Anyone have experience with the Harbor Freight Cen-Tech Clamp Meter?
https://www.amazon.com/Meterk-Multimeter-Auto-ranging-Capacitance-Non-contact/dp/B0721MKXBC/ref=sr_1_1_sspa?keywords=clamp+on+DC+ammeter&qid=1569170394&sr=8-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEyOEhYWEJKRE4wV1dXJmVuY3J5cHRlZElkPUExMDM0ODIzMlpIUjc0S0dSNEhBViZlbmNyeXB0ZWRBZElkPUEwNDU5NTM3MTlIQ1BNRUdKOTIxSyZ3aWRnZXROYW1lPXNwX2F0ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
I had one of these years ago. Complete waste of money if you are doing anything other than sheet metal.
I had one of these years ago. Complete waste of money if you are doing anything other than sheet metal. Tried to upgrade the band/blade itself (made a small difference) and it just wouldn't have it. Band was always jumping off the wheels, took FOREVER to cut though 1" square tube stock, not much better on angle iron. Adjusted it every which way. Less tension on the lever to cut with any speed and the band would jump. Adjust it to where it didn't jump - not enough weight to make a speedy cut. I'm talking several minutes.
I ended up selling mine on C'list for $50. Left it outside when I was gone and told the buyer to put the cash on the wiper of my truck. Ran an extension cord so he could plug it in. I wouldn't have cried if they had just taken it away.
If you are cutting bar stock, angle iron, tubing, etc., do yourself a huge favor and buy a quality metal chop saw. I found a top of the line Dewalt on C'list for $125 barely used. Put a good blade in it and save yourself all the headaches you'll have until you actually get fed up and do it. I made do with the HF chop saw ($49) and that band saw. Should've bought that Dewalt years ago.
Buy once, cry once. Buy cheap and cry forever.
