Fedwrench
At least one thing that should ruffle some feathers
I'm intrigued!!! don't forget to bring some special limited edition garage Journal member swag.
Do you make different bits for the tire buffer quick change chuck? Mine came with the carbide buffer wheel and the quick chuck is nice. Wondering if you make some drill bits for reaming out nail holes or some other bits for the quick change chuck. I didnt see any in a quick google search.
Napa has them in their tire service catalog.
I own quite a few Astro tools and they have been used many, many times and never once let me down, especially the ball joint master set.
One request that you SHOULD make: a bi-directional OBDII scanner, preferably a 7" touchscreen or slightly larger. One that can program security keys AND tire pressure sensors.
Autel and Launch should be your targets. Put out a product that is slightly better and slightly cheaper and you will sell so many you will want to thank me later by giving me one.
-- Dave
Howdy!
Did Astro discontinue the 78820 Rear Axle Bearing Service Set?
speaking of astro tools, I bought the heavy duty hub puller set a few months back and forgot about it. I just did the front 2 on my pick up beating the hell out of one side with a small gearwrench puller. $%^&$%^^ noticed the astro sitting in the cabinet when I was putting the other set away. lol
Has anyone rebuilt a ASTRO nano yet? I have had mine for about 2 years and use it professionally and it laid down on me today while replacing a transmission. I love the gun and need it back up and running pretty quick. It is weak and sometimes just hisses.
I assime all I have to do is pull the four Allen head bolts on the rear to get to the vanes, I have actually never been in an impact before. And am I removing all of the springs or the offending onesChris has explained in the past that the vanes have little springs in the guides. You probably lost one and now it is preventing a good seal. Take them out and it will work fine or get some new ones if you really want to do a complete rebuild.
remove all the springs should that be your problem and clean/oil and refit .
Only for 1823.
For other nano's we would need to take a look to see what the offending issue is and replace.
Send me a pm MountainMan
when is Astro going to sell those drill bits that right now only MATCO sells?
Also interested.
Quick note about a few Astro items I recently bought. A while back I bought the 3082 0-60psi tire inflator and was super stoked on it. I needed higher pressure for my truck tires and airbags so I ordered the 3083 0-160psi inflator and wow what a let down. This thing looks like every other low budget import junk you buy at HF. Wish the two were the same because the 3082 is great and I’d love it if there was a higher pressure matching tool.
I purchased a set of AP pinless universal impact sockets (3/8” metric 78344) but I’m not that stoked on them. I have a set of Sunex pinned universals to compare and like them better than the pinless. I did lube the 10mm AP with some white lithium grease and spun it at max angle on my M12 stubby impact for about a minute to break it in before comparing. My Sunex set is also brand new and I didn’t lube it or do any break in. The Sunex works at a steeper angle, is slightly shorter, the socket head is slightly smaller, and it runs smoother at max angle. I had high hopes for the pinless, especially being smooth at angle, but at this point they are going back to Amazon. They seem well made and would do the job, but the Sunex seem more refined even though they are pinned. Am I missing something or doing something wrong?
My 40SLMAX light has developed an issue. It will not light up unless it is plugged into an outlet. Also, the charge light does not light up when it is plugged in (to indicate that the battery is charging), but will turn red when the dial is turned on approximately 50% when plugged in.
Any ideas?
I also am having a strange issue with one of the lights. I have a 40SL that I've used for at least 3 years that works great. I bought a 65SL that's been working fine up until a couple months ago. The charging light comes on, and seems to take a charge (I guess?) but it just won't light up. I ran it dead and since then, a couple months back, she's DOA. the 40SL is keeping on trucking though. So I'm not sure what the dealio is.
3082 is just the low pressure version of our long standing 3081. You need a 3081. 3083 is more for the DIY market..
Thanks for your response. I wish I had found the 3081 as I really do like the 3082 I already have.
As for digital tire inflators........ nah, no thanks. Just personal preference
