Above 1200 Sq/FT T-Handles Workshop (The final destination??)
T
T-handle
Northern Ostrobothnia Finland
Scary looking creature :wtf: I hope that encounter with that creature was friendly.
That's a really spacious storage, everybody should have something like that...
Yes he was a friendly one, offered me some candy:lol:
Thank's Mikkeli:thumbup: There's never enough storage space.. I had to make a special hole in the wood pile for the light switch:lol_hitti
I have build several houses for the customers and almost every time I've looked the plans and there's no place for firewood storage. That's good to have here in north:thumbup:
don long
southern california
"T" I noticed that you use the mirka sand paper. That is the same stuff I use here in the US It is great for the Vacuum system I have for sanding bondo
I just ordered $700.00 worth tonight (I was running low)
T
T-handle
Hi Don! Yes the Mirka autonet or abranet is a great product:thumbup: It's nice to sand without the dust and the shop and lungs stays cleaner.
You are super productive man Don so 700$ worth of sandpaper makes sence:beer:
Unruh
Silverdale, Washington
Nice work on those Hex and Torx stands! I may have to try my hand at them. I also really like the swiveling stool. This is the problem with Garage Journal, every time I read a great thread like this, I get two or three new projects to try out for myself!
T
T-handle
Thanks Unruh:thumbup: Those stands have proved to be very handy. They are nice to pick on the "worksite" when needed.
Swiveling stool is nice too, it's out of the way when needed and all the cords, airhoses and cables stays safe under it:thumbup:
Yes I feel you, tons of ideas and inspiration on this forum:beer:
Jayman17
Seattle, Wa
Wow T-handle, super job on the whole shop! I really like your style, everything cleaned-up and organized. :thumbup: Love that electrical chase you installed on your workbench, it really incorporated there nicely.
Looking forward to more updates, hope your back is on the mend. :beer:
Jay
T
T-handle
Jay
Thanks Jay:thumbup:
My back has been great for many weeks. I'm wearing a kidney belt a lot, it helps when the weather is cold.
I have been working in the shop and updates are coming:beer:
T
T-handle
I went through some hammers and mounted them on to the welding cabinet.
I washed them with hot water/soap and when they dried handles came loose. I made couple new wedges and glued all the handles with epoxy.
Then I sanded all the handles clean and sprayed tree layers of satin varnish on them.
Then I refaced the faces with belt sander, polished and painted the heads.
I mounted a pegboard on to the welding cabinet. Covered all the holes too that someone had drilled on to the cabinet. Two stones with one bird:lol:
I also cleaned my shop brush and mounted it here, so I can clean the things I'm hitting. Not so much dings on the hammer faces:thumbup:
Looks nice and now they are ready for work.
Have a great week everybody. Couple days to weekend:beer:
Ronin22
BA
I can't believe how gorgeous those hammers turned out. I wouldn't want to use them now lol!
T
T-handle
Thanks Ronin22! Yes those turn out nice. I use them a lot but sometimes they deserve some love:lol:
And now the "U can't touch this" tune is playing in my head all night:lol::lol:
That looks great! I have been slowly cleaning up some of my hammers but they hide in drawers so I don't get that warm feeling as often.
Thanks Bob! Yes you said it perfect, it's the nice warm feeling when you come to the workshop and use your fixed tools. Brings a smile in your face :thumbup:
Ronin22
BA
Mission accomplished :lol_hitti
Have a great weekend :beer:
T
T-handle
Hi everybody!
I made a fast and cheap door for my garage when I build it 8 years ago. I've been dreaming of a thick lift door or a folding door. My door opening size is 3x3 meters (10x10ft) so there's no ready standard model for it. Normal Finish garage door size is 2.1x2.4meters.
So it's going to be a special order door, that means more money. I did some searching and the door will cost about 1000€ to 2000€ depending about windows, electric opener etc.
Only problem is that all the commercial doors is about 40mm thick. I can buy a 70mm thick folding doors but that's 3500€:rolleyes:
My temporary (8years):lol: doors have 70mm of hard foam in them and the overall thickness is 110mm. (over 4 inches) and they are very warm when the weather gets cold. Only problem is the weather strips. They hold about 3 years and then they start to separate from the wood.
I was about to order a lift door but then I started thinking, what if instead ordering a new expensive door I use a little bit time and money for the old doors:thumbup:
First I removed all the old weather strips. I removed also the old foam between the frame and the door frame. Then I adjusted the door straight with laser. I used wedges and 6,5x110mm corrseal bolts about 50cm spacing.
Now it's solid as it can be and hopefully it doesn't move with weather humidity.
I sprayed the caps with winter PU-foam.
Then I sanded and painted the doors from inside. Doors were painted with water based latex paint inside and they were impossible to clean. Now I used a urethane alkyd paint so it's water resistant.
The color is same that my moldings. I painted two thin layers.
I figured that if I make a sheet metal covers for the door frames the weather strips will stick better.
First I made a kick panel inside. I mounted all the metal parts with high tack glue and screws.
Here is the side parts with seals glued on them, I cleaned the metal with acetone and the seals sticks very nice.
Here is the upper seal lip. There's one inside and one outside. Now every side has a double seal:thumbup:
I used EPDM D-profile seal. The thickness is about 7mm and it works for 3mm to 6mm caps.
For the doorstep I made a aluminum cover, there's a 70mm foam under the cover that separates the outer concrete from the garage floor.
There's a 20mm lip on the aluminum cover and the door seal stops to that.
For the outside I installed a rubber wiper so there's a double seal too. That's usually a difficult place to seal.
I made a 2-point latch for the door. It can be only opened inside so no lock needed. Little more exercise to open the doors, but I have a carport for the cars so this door stays pretty much closed. Project cars only:lol:
I saved the latch handle from some old door. I made the rods and the rod holders from hydraulic pipe holders. I made the long handles from a old snow barrier pipe and some pipe holders:lol: I also installed the things that keeps doors open on a windy day.
Here's the upper latch. I made the rod ends pointy so it closes like a fridge door with a little "hisss" sound :thumbup:
Here is what it looks outside, It matches the garage nice. I'm going to paint it next summer and I've been planning a little overhang with lights.
I had the hinges inside the door frame and the door but they were always loose so I bolted them from the outside with longer bolts. I have to paint those also.
I've been monitoring the door temperature with infrared thermometer and the new weather strips works great. Temperature in the garage went three degrees (celsius) up after the door was ready:thumbup:
I think it looks okay now too:thumbup:
Have a great weekend everybody!
T
T-handle
Restored four more hammers. These are some old bodywork hammers, Snap-on Blue point planishing hammer, Snap-on Blue point shrinking hammer and two Elora pumbing hammers from West-Germany. I bought these from yard sale, three euros a piece:thumbup:
Removed the rust with wire wheel.
Sanded and polished the heads.
Painted the heads with Maston Hammer paint. Boy it was hard to paint. I did three layers but you can still see true the paint few places.
Made new oak handles, I salvaged some old oak counter tops. Good material for small jobs like this.
Mounted the handles with epoxy and wedges. Handles have wax finish so they stay in hand when hammering:lol:
Came out nice:thumbup: I also made a small video about the restoring process.
Hammer restoration movie
Have a Great Holidays everybody and may everyone have a lot of tools for presents xmas :beer: xmas
bj383ss
TX
Those are fantastic. And I LOVE the handles you made!
Merry Christmas!
Bret
HotWire
Montana
I just read your entire thread start to finish. Amazing work and use of salvaged materials. You should be proud of your work. Beautiful!
T
T-handle
Great job on the hammers.
Thank You and Merry Christmas:thumbup:
This kind of tool **** should be illegal!
Thank you Ronin22:thumbup: NoNo It's (almost) the best **** there is:lol:
Four tools brought back to life - priceless! Video is great as well.
Thank you Bob:thumbup: Love those old tools, I hope that the Snap-on handles were better condition to save. Video was super fun to do. Only problem is my old computer. It crashes about 50 times when I was editing the video. I guess I have to update that before the next video:lol:
Nice job on those hammers!
Thank you Sir:thumbup:
Merry Christmas!
Bret
Thank you Sir:thumbup: I like too how those handles came out, fits my hand perfect:thumbup:
Merry Christmas!
Thank you HotWire! Thanks for stopping by. I like when I can use all my collected items and save some money. I always check the dumpsters when passing by and my wife hates that:lol:
Merry Christmas!
I have been building Legos all day. My youngest son had some Lego technic sets and needs some help, Great stuff to do and relax:thumbup:
I had some hard gifts too :thumbup:
Some Irwin Quick grips and good red stuff:thumbup: And some restored bodywork hammers:lol:
Well I guess I helped the Santa a bit:lol:
Happy Holidays everybody:beer:
TMcCay
SW. Oklahoma
Just catching up. I haven't seen all you have done since June. Amazing work, a real inspiration for sure.
T
T-handle
2020 goal is to get the welding area finished and maybe the machining area too, that's a lot of work. And to post the whole saga here of course:lol:
HAVE A GREAT YEAR 2020 EVERYBODY!
matt_i
SE Michigan
Happy New Year, T-handle!
Just got into your thread and I love all of the organization :) I need you to come here and help teach me :lol:
Beautiful work on those hammers, it makes it look like a much higher precision class of tool... I would feel like I was hitting something with a micrometer :D
C3L1CA
Those hammers turned out awesome and so has the whole workshop. Look forward to seeing how the rest of it turns out for more ideas on how to organize my garage someday
T
T-handle
Thanks Matt_i:thumbup:
I like how those hammers came out too. They almost look too nice to use but they are going to be used. I can restore those again after 20 years:lol:
Happy New Year to you too:beer:
Thanks:thumbup:
Thanks for stopping by, I'm getting back to organizing my workshop, I've been busy with other work fixing cars and my sons atv. We finished it yesterday:thumbup:
Kriesel
Afton, Minnesota
Awesome shop space, great attention to detail, thanks for sharing all the details as well.
Look forward to the project that this shop will produce.
