New Tool Idea......
freudianfloyd
Nowhere
Maybe somebody make such a thing, but if not, they should.
Basically a boxed end wrench that can only go on from one side so you can put a nut into it and it will not fall through.
For example, I was trying to work on my daughters car today, and deep in a narrow slot I needed to slid a nut in and hold it so I could tighten it from the other side. Usually I have to try to balance it on my fingertip and then get the nut started and then get a wrench to hold it.
I'm sure I'm not the only one who has had this problem.
I tried my finger, but the slot wasnt big enough, and if I bumped it on the way in, it would drop down into the door and rattle for eternity, tried needle nose pliers but they wouldn't make it through the slight angle, magnets wouldn't work because it was a stainless nut.
Do they make anything like this already? If so, I need to buy a set.
mr.lemons
UK
Wera have what you are asking but on the open end.
Old Man Roger
Palm Coast Florida
It can work with the open end too..
Check out the nut being held by a nut and bolt.
DFB
Southern VT/Western Mass
Oh I've done the tape on the wrench thing plenty enough times :lol_hitti
But is a ring wrench what your after though? :headscrat
Just stops the nut from passing thru
Especially handy for using a box end on a long threaded shaft
I've been hawking Mastergrip ring wrenches on my tool table for season or two :D
a reversible ratcheting wrench
Might have one set left :pimpflash
F
freudianfloyd
Nowhere
Wow! Great ideas. And I will keep an eye out for a set of ring wrenches. It seems like I need them often.
Thank you all.
NYBODYMAN
NY
I have a set of CMAN ratchet wrenches that only allow you to put the box end on a bolt/nut on one side.
FSrepair&fabrication
maryland
When I encounter this kind of problem I’ll put a piece of electrical or duct tape across back side so the nut can’t fall out. You can also accomplish this with a decent strength magnet
MikeF2316
Thornhill, ON
I've used tape around the nut/bolt head so it would jam. And I have a set of Craftsman / GearWrench ratcheting combo wrenches where the boxend has a stop as on some of the pictures above.
Nineeightyone
Pennsylvania
These are the kind of shenanigans I'm all about, some crafty suggestions!
Oem tools makes a ringstop set
OEMTools will also send you a second set of rings to replace the ones that ship in the wrenches, AND they're reversible. I'm a pretty big fan, overall.
Karl_B
Killeen, TX
Maybe I'm crazy, but that's when I would dig out a flanged nut. Those don't go through wrenches. I have used the paper trick with sockets to get into hard to reach places, though.
