outofbounds
Thank you sir!!
You may run into some tools that are clearly not mid-1920's vintage and not date-coded (e.g., some pliers) for whatever reason. The logo can provide some help in those instances.
Snap/on - through 1946
Snap/on - ~1947-1949
Snap-on - 1950 to ?? (I don't know, I don't collect it)
Wow! You may have to abdicate your "Bay Area Bishop of Barcalo" title and become "Snapdad"! Nice haul, Don.
Thanks, guys!d42jeep,
Nice haul for sure.
I was never temped to use this, so it may be 9/32” drive. I’ll check it out.I snagged this 9/32-inch drive No. M-40 at a used tool store on Friday.
What I am a little befuddled by is the "BLUE POINT" marking!
These M-40's were offered from the beginning to the end of the 9/32-inch drive era, which, in commercial catalog terms, ran from 1935 (Cat KA) to 1942 (Cat P), before 1/4-inch drive took over in 1945 (Cat Q). But all the pieces are marked Snap-on, as far as I knew. I understand they continued making 9/32-inch drive for military contracts after that perhaps into the early 50's. I am speculating that at least some of that production was Blue-Point branded.
Does anyone else have any Blue-Point branded 9/32-inch drive tools?
That's the same spinner I just found and showed in posts #1938 and #1939, snapmom. And, if I am guessing correctly, the same spinner Don just showed in post #1940. What I am wondering is why its marked "BLUE POINT". What I am asking is if anyone has any other 9/32-inch drive tools (i.e., not the stubby M-40 spinner) branded Blue-Point instead of Snap-on. Doesn't anyone else think it's extremely odd that ALL the 9/32-inch drive tools - including the other spinners (M-4 and M-45)! - are marked Snap-on except for the M-40 spinner?there were at least two BP 9/32 drivers made. here is one.
That's the tapered handle one only shown in the 1935 cat.The pic. posted on the site.
I forgot, that wood handled M-4 and the tapered amber handled M-40 that disintegrated on snapmom appear on the same page in the 1935 catalog. The earliest production. That actually helps my theory. I think they were probably getting them both from MTF/Blue-Points. They started making the M-4 and M-45 on their own, but continued getting the M-40 from that plant for some strange reason. And I say strange because other than the length of the shank, there's really no difference between the M-4 and the M-40.I do have one with a wood handle marked bluepoint. All the others are snapon.
Technically, it was meant to be plugged into the female ratchet, no? You held it steady and worked the ratchet and the swivel grip turned, right?I think that is the predecessor to the thumb wheel ratchet.
Otg, Snapmom,
What is the longest 1920's era Snap-on Tee-handle you have ever seen? The No. 3-A was 24", but did they make an extra extra long one? I saw one that was at least 36" maybe longer. No markings, but all the classic mid 20's Snap-on tells. Not in any catalogs.
You should have got it. The 24 is hard to find
Would have loved to have seen that
Thanks. That's it. It may not be too late to get it. Most people probably don't know what it is. I recognized it from the drive stud, the rotating grip, and the stops holding the rotating grip in place. Where are they measuring that 24" from? OAL (end of drive stud to top of Tee handle)? Or just the shank? I swear it was longer than 24 inches.a 24 tee
