Reminder : Drain your air compressor tank !
rlitman
Long Island
Are the end caps made from the same steel as the cylinder? Are they just stamped into that shape and then welded onto the cylinder?
I’m asking because I prefer vertical tanks. I’m guessing the end caps are more likely to rust through because of the smaller surface area compared to a horizontal tank.
I’ve had my Craftsman vertical since about 1999. No signs of imminent failure, but I suppose it could start anytime.
The end caps are generally made from thicker steel. Also, with a vertical tank, the weld isn't sitting underwater as it is in a horizontal tank. That's why I prefer vertical tanks.
lbhsbz
Long Beach CA
Newer compressors should at least have stickers on them stating when to remove them from service. My 2015 year model says to remove the tank from service in 2025 for example.
What type of compressor do you have so I can make sure to avoid that brand? 10 year lifespan for a compressor tank seems absurdly ******.
welder4956
Birmingham, AL USA
Please post a photo of the sticker. I have not seen this before.
I would think that if someone was worried about corrosion the tank could be hydrostatic pressure tested at 10 year intervals to 1.5 times the MAWP stamped on the nameplate, the same way that compressed gas cylinders for welding are tested.
The Fall
Austin, TX
No one at the cabinet shop has ever thought about this issue. I know some of those compressors are from the early 1990s because my dad bought them new. They're still going strong and everyone is still alive. People regularly drain them, although they're transitioning away from pneumatic tools. It's the table saws that have done some damage. (Knocks on wood.) If you've been around cabinetry for more than twenty years, you lose a lot of the bravado because you've seen top-tier guys get injured. That's why I use SawStop table saws. It was always table saws and installers getting hurt on ladders. God, the former was the worst.
Dodge
Illinois
This is a good thread. It reminded me to check and drain water from my compressor. It is a 60 gallon Quincy, about 4 years old. I have drained it before, but should do it again. Easy to forget when about, when you don't use something a lot.
mfewtrail
It's a cheap Porter Cable. I'm sure the tank sticker is a liability thing more than anything else considering there's tons of similar grade compressors out there still in service much longer than that. The average person probably does not drain a tank ever. I've removed gallons of water from some in the past...:shocking:
Not my picture, but the same exact sticker printed on a Dewalt compressor:
https://pixl.varagesale.com/http://...arge_uploader_thumbnail&w=640&h=640&fit=crop&
dutchgray
Dorset. England.
My cynical mind would suggest its actually a "We want to sell another compressor even though the last on is still good" sticker, though it may limit their liability if a real old one does blow up.
I don't like horizontal tanks although I have a couple small portable ones, much prefer a vertical, there is an old (1958) vertical at work, which is now the spare as there is a much higher output modern compressor that does most of the work, but its an English branded T30 pump on a tank made out 1/4" boiler plate with 5/16" ends, pressure tested to over 400 psi, runs on the slow end, quiet and you can run it all day without issues.
driz
Northern NY
Just stick an autodrain on it and let her go. Nothing to see but a stain on the floor. Cheap and simple is a great combination
Dodge
Illinois
Good idea. I'll have to add that.
sberry
Brethren, Michigan
I see this thead for a few days, meant to do it but got distracted. Sanded and painted a big job a couple weeks ago. Keep posting, maybe I will remember.
Skin
Boston
Here's my 1993 Craftsman DeVilbiss. Should I be worried - it's 27 years old (my how time flies. I remember buying it brand new. Seems like yesterday).
If you don't have the means or desire to hydrotest just bash it in a few spots with a hammer. If its compromised it will crumple like a piece of sheet metal. Tanks that rip open violently are so thinned out you could of put a screwdriver through it.
Benw455
WV
I have a 6.5 horse with a 60 gallon tank. I keep my bottom valve cracked ever so slightly and it drains itself.
CGT80
IE, SoCal, USA
Manchester tanks can be bought from McMaster's with an epoxy lining. When I replaced a 1947 Westinghouse tank, I opted for the unlined version but installed a timed drain valve that opens when it is first powered. It is tied to the pressure switch on the compressor so that it drains every time the compressor runs, but never when the compressor is shut off. This is great for home or occasional use. My 5hp 80gal Westinghouse compressor is set to drain for 45 seconds at each cycle. It is plenty to keep up with any moisture, I can hear it working without ever having to check on it, and it never bothers me when I'm not working in the garage. Win, win. Also, I added spacers between the casters and horizontal tank, on my two, so the tank slopes slightly to the drain.
Sent from my SM-G955U using The Garage Journal mobile app
le6920
I wonder when the 10 year sticker thing became normal? I looked and my late 90s vertical Craftsman doesn’t have one.
ChrisLS8
I'm curious why manufacturers haven't started coating the tank interiors at this point
Toold_up
Attached
And when the coating starts to flake off and plug up air tools/fittings/hoses...............
This ^^^
And I imagine that tanks lasting a few life times would put them out of business. Sales ya know?
I went and looked at a used 60 gallon Speedaire a while back and I asked how it was used and if it was ever painted with. Seller didn't use it much so he loaned it to his buddys dad who used it in his shop. Didn't think that anyone ever painted with it.
I asked him to pop the drain on the bottom and it started gushing white milky water... Never painted anything white with it right? Air filter was also white. No thank you, good luck with your sale! Looked like his buddies dad wasn't all that honest with him. I felt bad about his garage floor and the big white stain he now has to deal with.
arms1970
One of the tanks where I once worked is a 1948 model, still in service. The tank is “inspected” every two years by the state boiler and pressure vessel division. They looked at the data plate, had me activate the pressure relief, then issued a certificate of compliance. See you in two years. Nothing but a state money game. If a tank has to be taken out of service, a plug has to be removed to show it as inactive. It it can then still be used as a motor mount and a new tank installed nearby and attached to the output line.
Went through that when i had a pressure relief area for rebuilding relief valves. Inspector would pass through every 2 years, also check the compressors. We sold the relief pressure side of the valve business. When i dismantled all the tanks for the guy who bought everything. Rust sludge was pouring out. The look on his face was like :shocking:
American Locomotive
Rhode Island
Almost every compressor I've ever drained has water that came out looking milky. It's going to happen - especially from the dissimilar metals in the compressor system. (Copper, aluminum, brass, etc...).
I'm also not sure why using a compressor to paint would matter at all? So what if there was some paint in the air-filter. That's what it is there for.
Industrial steel tanks are epoxy coated inside all the time without having a problem for decades. It's just you have to properly clean and prep the tank before applying a coating. It takes time and costs money.
darkzero
SoCal
This ^^^
Agreed. It's not uncommon to see a slight milky white color when draining the water. It's the condensation mixing with oil in the tank. A bit of oil from the pump will get into the tank. Not sure how milky the water was, if excessive then there may be excessive blow by but some is normal.
I would be more concerned seeing the drained water a rusty color than whiteish.
engineer2
Chicago burbs
When I work in a factory in the 70's, we noticed the air compressor was cycling more frequently than usual. Found out nobody had drained the tank for about a year. I filled one and a half 55 gallon drums. It was probably a 120 gallon tank. Ironically, we manufactured air dryers (which was after the compressor) and timed drain traps. I think we added a drain trap to the compressor after that.
4 FN 27
Minnesnowta
Back in the early 80's I worked in a shop that had a 250 Gallon Accumulator Tank mounted on the Ceiling. It had one of those Football shaped auto-drains on it plumbed with 1/2 inch Copper to a drain along a wall. The drip end was always dry.
One day a guy hooked up an Air Grinder to a drop along the wall and all he got was water. We dumped the air system and pulled the auto drain off. The Tank was half full of water. Who knows how long it had ben that way.
New auto drain and everything was good.
The Compressed Air system there sucked. They had a 100 HP Sulliscrew Compressor. I bet 50% of the air was created to fill leaks. All black iron pipe.
