rlitman
Are the end caps made from the same steel as the cylinder? Are they just stamped into that shape and then welded onto the cylinder?
I’m asking because I prefer vertical tanks. I’m guessing the end caps are more likely to rust through because of the smaller surface area compared to a horizontal tank.
I’ve had my Craftsman vertical since about 1999. No signs of imminent failure, but I suppose it could start anytime.
The end caps are generally made from thicker steel. Also, with a vertical tank, the weld isn't sitting underwater as it is in a horizontal tank. That's why I prefer vertical tanks.
Thanks sberry.
