Thanks Hiball. I’ll tear it down later this week and get some pictures. There was no o-ring inside, just that plastic piece. I have been paying close attention to the fluid track (it was at the top before I tore it down but now right at the bottom).
In the meantime, what is that called (an oil seal)? And how tight is that nut supposed to be?
I’ll look at that loctite 518 as I’ve never used it (I have used permatex gasket maker), but again how tight do I make the tank nut?
Finally, is there something I should check on that weep hole or anything else having been overextended? I am not sure where the weep hole is.
The Oring on the reservoir wouldn’t be at the base, it would be higher up, generally they seal 1/2”-3/4” up. It wouldn’t be a oil seal, it’s more than likely just a poly/nylon compression seal. If it doesn’t utilize O-rings on the bottom or the top (normally on the outside of the tank nut) it will need to be pretty tight to seal. In regards to the weep hole, just look at the seal, sometimes in these mass produced items they don’t clean up the hole/groove and when that seal travels under pressure over the relief it will damage the seal.
Awaiting some pictures..
