mobiledynamics
witty. Got it. the festool, mak, in your pics. Those are made my Sortimo.....
I'm going to pretend I didn't see that for a while...Added the 12v Jigsaw and Rotary Tool (Dremel) to my toolbox. Got a chance to use the rotary tool yesterday and I was pleased. Plenty of speed and torque for the project.
what is the resale value of m12 charger and the bags that come with most m12 kits?
Levi
Levi
Levi
CORDED is dead....Ha. I still have my corded Metabo's grinders, a corded Hilti Reciprocating that got some poooower for DEMO, and the only other corded is just all my woodworking and hilti rotary/hammers.
Today, I took out my good 'old USA cordered Super Hawg, cleaned her up, and sold her. Been holding onto this tool just because of some 'usa nostalgia.
Saw a review of another bright green 18-volt TTI inflator. Still hoping Milwaukee will bring out an M18 inflator. Like more power than the M12 and have more M18 batteries than anything else. Be handly to have something cordless and most large compressors have warnings against using them for low-pressure applications like footballs, basketballs, potato launchers, etc. Ryobi has a handful of 18-volt inflators, and Ryobi and Rigid both have 18-volt portable inflators.
{snip}
Ok 2 questions here tonight...
First what do you all think of the the 28-22-2889 screwdriver set?![]()
It's regular retail is like $40 @ the Home Desperate and even more at ACME Tool. I seen a sale for $20 on it at Blains
https://www.farmandfleet.com/produc...html?utm_source=criteo&utm_medium=remarketing
Quick question for all of the battery gurus here...
I know in the M18 lineup there are batteries ("HO"?) which make use of a different cell to allow the battery to provide improved tool performance. With regards to the M12 line, do the XC packs make use of these higher performing cells or not?
I had read that the higher performance cells are too large to fit in the M12 packs, but it wasn't clear if that statement was in regards to CP packs, or XC as well. I ask because the M12 CP3.0 batteries are consistently ~25% cheaper than the XC3.0 batteries and I can't for the life of me think of a reason that someone would spend extra to get the same capacity and same performance in a larger package
https://www.homedepot.com/b/Tools-P...fault&storeSelection=6175,6177,6845,6957,1255
I've been calling Milwaukee speaking with support a few times.
Things I've learned
There is no other -experienced dept- other than 1st line customer care, and then support.
Support have fairly broad knowledge about their products and what they don't know, they try to get the answers from the tech sheets or parts, etc if they have said documents available.
There are no - industrial sales/tech gurus - to answer questions, about some of their higher $1500+ tools. So one , like me, is left at the mercy of trying to piecemeal some high level questions about said tooling.
Eh, it is what it is, but man, I was thinking there would have been at least 1 live person who was a guru in Wisconsin that they could transfer me to....
Things I've learned
DFB, there is a dude on eBay who custom machines angle grinder adapters for the polisher. Search around there or in this thread using Google. I know I posted them here.
There are no M12 batteries that have the "HO" newer 21700 cells yet.
I have a small set of Milwaukee tools (four) and they never leave my garage.
I only have to M18 batteries and two M12 batteries. It strikes me that the easiest way to rotate them is just to throw batteries on the charger when they need charging and then just leave them there until the next set needs charging, and then swap.
I know it shuts off when they are fully charged, but is it OK to just leave fully charged batteries on my Super Charger indefinitely, until they're needed?
Do they ever shipThis returns center currently has a lot of Milwaukee product available. I have no connection to them. I have purchased from here a bit over the years and have received decent working tools. I also have received non-working tools within warranty that Milwaukee repaired free of charge. I have never purchased a pallet, so no advice there. Bids on some items seem to be a bit pricey.
https://www.theselectsource.com/search?parent_id=&keywords=Milwaukee
I will have upcoming project(s) so it will get used.Impulse buy. HD had a promo for free HO XC8.0 battery with certain tools. I had store credit so the pair was around 170 out the door.
Still haven't used it yet...battery takes FOREVER to charge on the regular M18/M12 charger thoI will have upcoming project(s) so it will get used.
I didn't weigh them back to back, but the saw + batt seems to weigh less than my older Milwaukee made in USA corded circ saw.
They both use 18650 cells. The 3.0cp has 3 3000mah cells, and the 3.0xc has 6 1500mah cells in it. In something like a light, radio, or any low draw item they should give you very similar battery life and performance. However in some tools the XC batteries will provide more power to the tool. The 6 cells being able to deliver more amperage than 3 cells. For most tasks your not going to notice much difference, but when your pushing the tool to it's limits the XC packs will be able to do things that the CP packs can't. The circular saw may struggle to go through a 2x6 with a CP battery but cruise through it with an XC pack. Or a drill struggle or fail to run a 1" paddle bit through 2x material, but with an XC pack it will work just fine.
As far as the cost goes the 1500mah cells are cheaper than 3000mah cells, but there are still twice as many of them in an XC pack. I wouldn't reccomend anyone buying the 1.5cp or 3.0xc packs unless they get a screaming good deal on them. The cost difference is pretty minimal when compared to the newer 2.0 and 4.0 packs. And even the 3.0 and 6.0 packs have gotten to be a little more reasonable in cost when they're on special, or buying from ebay.
