JimVonBaden
I know this has been covered before, but I thought I would make a few comments, and show a few pictures.
As some of you are aware, I put VCT in my main garage 7 years ago when I bought my house. The Build-out is covered here: https://www.garagejournal.com/forum/showthread.php?t=128013
I like the VCT for cost and ease of install, but since I work in my garage a lot, it tends to be pretty high maintenance to keep looking good.
New:
In use:
Clean-up:
In the mean time, because of all my **** and bikes, neither car will fit in. So, the solution is a new workshop to fit the **** in. See here: https://www.garagejournal.com/forum/showthread.php?t=346116
Built, insulated, painted:
[URL=https://imageshack.com/i/pmt5fu66j]
[/URL]
Finally, to the floor. Since this will be a working workshop, I wanted it to be able to take some abuse, but also clean easily and look good for future sale when we retire in 10 years.
The solution? Porcelain tile.
I have done tile on my porch, and it was mid summer and miserable. This time, 50-60 degrees, and I had a wet saw, so much less miserable.
layout, measure, measure, measure, and cut!
Next the install, thinset, back butter and lay in a reasonable pattern to minimize waste.
Then grout with a synthetic grout, darker to avoid stains.
Up to date. This started December 7th, with initial help with the structure, a guy helping on the drywall, and paint.
Today I start moving in all my ****, after cleaning drywall mud dust off if it.
New:
In use:
Clean-up:
