MikeF2316
How fast does it inflate?
From post 19048:
Mine took exactly 5 minutes to fill a 245/45R18 tire from flat to 33 psi. And the tire had a sizable leak.
From post 19048:
The inflator is great I think.
Acme has it for $59 now:
https://www.acmetools.com/shop/tool...b7smA7RYqPDp4VjAu5_ESOKFfBnqNwhgaAtvsEALw_wcB
I’d rather pay $79 and get a 5 year warranty than $59 for the recon unit.
Does that heat gun have a lock to keep it running without holding the trigger?Almost forgot to post have to build it up again
I consider myself a Milwaukee addict, I have a ton of there stuff and for the most part love it. But I recently purchased a couple of their new m12 angle die grinders, and a m12 straight die grinder and are very dissatisfied with them. No power, they shutoff all the time. I have pretty much given up on them. I have pretty much replaced the air tools in my shop with Milwaukee m12 and m18 tools, but the die grinders don’t make the grade. IMO.save your money on theses units.
Greg
Glammers, are you using the bigger batteries with them? I've heard the smaller 1.5 and 2.0 batteries don't work as well with those.
I love mine! No issues with anything I have tried yet, but I'm a DIY guyHow about that 3” cut off tool? I’m thinking about getting that first before getting another m18 cut off tool again. Not that I had any issues with the m18 version.
I have one of these that needs to be replaced, 220 ft-lbs.
https://www.milwaukeetool.com/-/media/Products/Power-Tools/Cordless/Impacts-and-Fastening/2759B-20_3.png?mw=461&mh=422&hash=DC6B50FEA5A7CB65AA85A4C377EA7B0FEFB8825E
I'm in construction and most of my work is with 1/2" bolts, this thing has enough power so i'm thinking of moving to the stubby as it is rated for 250 ft.-lbs and is much lighter.
Would the m12 stubby really be better than the m18 wrench?
[IMG]https://www.milwaukeetool.com/-/media/Products/Power-Tools/Cordless/Impacts-and-Fastening/2555-20_2.png?mw=461&mh=422&hash=501C1DFCC7F2AC61C9C03578E0DE1000E3957B11[/QUOTE]
Surprisingly yes. My compact M18(With 5.0) struggled with 100 ft/lb lug nuts, my M12(With 4.0) stubby works on my 150 ft/lbs lug nuts...In fact, the stubby struggles LESS on 150 ft/lb lugs than the M18 struggled with 100 ft/lb lugs. I ended up selling my compact M18.
I recently got a 3/8" Stubby. They are close for sure. I have always liked my 1/2" M18 "B" compact impact wrench (but not the 3/8" version just doesn't seem the same at all)
IMHO you wont disappointed in performance at all if you switch
Do you see much performance difference from the CP vs XC batteries? I'm asking due to the comments about disappointing performance that a couple members have voiced over the past couple pages.
I've been eyeing up the "get a free XC6.0" kit that HD has been advertising for the past couple months, but with spring yardwork coming up I might end up diverting the tool budget to the Fuel Hackzall with a pruning blade
The question is mainly whether the smaller battery will be an issue. Stubby rocks.
I have the 3/8 stubby as well. I've used a CP3.0 pack with it, an XC3.0 and XC6.0. With the CP3.0 it did struggle a bit the remove lug nuts torqued to 100ft/lbs and I was disappointed with it. It still got the job done, but felt like it was barely able to do it. With either XC pack it took them off no problem, no hesitation, no pounding away, just pulled them right off Big big difference in performance with the XC packs.
However, when doing brakes on my girlfriends car, the stubby couldn't break the lugs free as the shop that put her new set of tires on just pounded the lugs on full bore with their impact. I had to use my M18 high torque which pulled them off nearly instantly. That was the only instance where the stubby failed, but I'm not upset given the circumstances.
So, if you do get the stubby I highly recommend using an XC pack with it. It does give it a pretty significant performance boost. There's nothing wrong with the CP packs, just not the same amount of punch which in certain situations can be a good thing.![]()
This is what I was hoping to hear. The one user a couple pages back who had issues with 100lb-ft lugnuts with a CP2.0 had me questioning my desire to get one. Your experience above suggests that battery choice was his issue and will give me some peace of mind in getting on.
I had a similar experience recently. My dad grabbed me a Baer hi-torque corded impact gun from HF for my birthday since I no longer have access to air and didn't have any intent in getting into 18V tools just for the purpose of having a hi-torque gun. First thing I tried it on was my wife's jeep which had recently been into the local meineke for inspection. It had to hammer for a few seconds to get the lugs off and I was initially disappointed. I later tried it on my F150 which I had torqued to 150 myself and it zipped them off with a light bump of the trigger, which spoke to how greatly over-torqued the lugs on the Jeep were
I think the 3/8 stubby will make its way into my arsenal eventually. I'll have the big HF corded 1/2" gun for really tough stuff that the stubby can't handle (crank bolts, axle nuts, etc).
If you already have 1/2" impact sockets and not a 3/8" set, I'd get the 1/2" - it's said to get more out of the potential of the motor than 3/8" with the additional mass of the 1/2" anvil and sockets. (I got the 1/2" for that reason)
Yet another post of mine talking up the 3/8 stubby, I know I know
Anyway, I just finished up replacing the rear wheel hub on my 2009 Subaru Forester. Original hub, original axle nut which was torqued to 162ft/lbs from the factory. I used the 3/8 stubby with a 3/8 to 1/2 adapter, 32MM deep well socket and XC6.0 battery. I wasn't expecting it to remove the axle nut, but it did and with barely any struggle. I was hugely surprised that the stubby was able to remove the axle nut. That thing keeps impressing me.
Also as M635_Guy said, if you already only have 1/2 impact sockets, go with the 1/2 stubby instead of the 3/8. Regardless, either route you go you'll love it.![]()
I have a 1/2" deep set and a 3/8" shallow set, so it's a toss up for me. My thinking was that if I'm needing a stubby, space is tight and a slightly smaller 3/8" socket might be beneficial. <shrug>
Thanks for the input![]()
