Jim_No_Garage
Millington NJ
I picked up a steel frame for a wheelbarrow at the curb yesterday as I have a wheelbarrow with a rotten frame. Today I combined the two into a single working unit.
I had to make replacement "wedges" to put between the rails and the tub as the original ones had a family of carpenter ants living in them. I used some PT 2 x 4 I had laying around.
The tire leaked so I "Slimed" the tube and will hope for the best. I still have the wheel from the rotten frame so I can always swap that one on.
Cheers
Jim
doorfx
Calgary ab. Canada
Tune up time for all small equipment
Weed walker, edger and blower all got the treatment as well lol7a22008a69f58005a38071a841e28ec4.jpg
protegeV
DFW
Pulled the motor in the truck I just bought. It was supposed to be a simple fix, but apparently not...
couch67
Ontario Canada
Built a metal cutoff bin, basically a cat litter bin filled with pvc tubes, works great for what I need.
There is a thread dedicated to this but could not find it, will post there once I do....
Motorman55
South Jersey
FWIW I doubt you will ever scrub that dress belt back to white and bleach is probably going to yellow it some. Not sure where you are located but if you want to display it I would just go online or to a nearby PX and pick up a replacement dress belt. This looks like a pretty decent deal https://www.marineshop.net/white-belt-for-male-dress-blue-uniform-500772
Thanks for info. The buckle was only displayed in one of my cases. The white belt was stored away for many years. I'll try to clean it anyway just because it was part of my wild youth.
soloz2
Western NY
swept out and reorganized the small garage I use as a storage shed for outdoor equipment. I've got to sell my old snowblower this fall to clear up some room since I got a new one at the end of winter. I also cleaned up my chainsaw and installed the metal dog I picked up for it. ef0afb89d1dcf874572de2061225d014.jpg
niget2002
Josephine, TX
Yelled a few profanities...
First time snapping a bandsaw blade. It was my fault. I broke the table insert and haven't replaced it yet. The wood got pulled into the opening and jammed.0bb679673aed51ead253a8416059d82f.jpg
Sent from my LM-G820 using Tapatalk
830singleshot
Built this portable grinder rig. I got this wreck of a 8" grinder and refurbished it. I saw somewhere on GJ someone adding a flap wheel to the end of the shaft, so I turned a little bushing to make it fit.
I've wanted a grinder to use under the shed part of my barn for a while. I took this discard 2 wheel dolly and everyone's favorite angle iron (bed rail) and built this. It's perfect for my needs. Now just have to replace the ballast milk crate.
Motorman55
South Jersey
Meet Polly, Motorman's newest garage mascot. This old salty sailor has seen lots of action out in the weather.
He's rough around the edges, but I'm not about to clean him up cause he's earned his patina the hard way. Still I think he might be ready for retirement.
Of course us retired types still need to spin our wheels now and then, or in the case of Polly, to spin his wings. So maybe we can find a place in the garage where he can catch a breeze.
Flat Thunder Channel
When you have a forklift..... You think everything is eeezy peezy. Uprighted my snowplow blade tonight to save space. Didn't figure out it was a bad idea until it was lifted teetering in the air. Don't try this at home folks! On a lighter note I can finally walk without stepping over a pile of boards and around a snow blade. Making room so I can actually walk around the shop again! Also pondered which breaker and wire combination I need for my Hobart 175 welder. Confused at best...:headscrat
WunTon
My house in Purcellville VA
Noticed my belt was about to fall off while switching clearance inserts so I pull the top and found the set screw on the motor pulley had backed out slightly. Got that sorted out and then took the time to check everything over and lube all the appropriate places before putting the top back on.
PhantomEB
Medicine Hat, AB, Canuckistan
Cut up new and old steel on hand for my new and improved ATV riser set up for my truck. The platforms pretty much will stay in the truck unless need the room, Ramps can sit in the Side yard when not in use. Aiming to spread them out to the 25” mark so I can lay the other ramps flat on box floor when the quad is in use. Will store a Jerry Can underneath one ramp platform and a second battery/Compressor underneath the other. Then a Kolpin on the spreader bar that will be on the inner legs closest to the firewall.
It’s gonna be way nicer not to have the constant roller coaster ride of the old ramps. Why this way? I intend to pull a RV trailer down the line.
Dan in Pasadena
Pasadena, CA
Couldn't do much because we had the granddaughters (2 & 6) the last two nights.
But I was able to paint a small cabinet of drawers and installed door handles on my cheap melamine cabinets. Cabinets were missing one and had mismatched white plastic and chrome handles otherwise. Found out I had a combination of 3" and 3-3/4" hole centers. DOH! Drilled some new holes and now I have some extra holes to fill and a little more painting to do.
You can see my flooring boxes stacked behind the cabinet of drawers. Can't wait to install it!!
Slednut
Washington state
Because we are working from home I spliced up a fiber panel today for a remote cabinet in my shop.
kaymccampbell
Upstate New York
Put a bunch of Stedlin anti thrash inserts on my air hoses.
Worked on the whole house fan.
Soldered up the shield board for the shop clock. No more breadboards.
PhantomEB
Finished off my new bigger and better as well safer ATV riser ramps for my truck. Made the Ramps removable then decided flip uppable so now they can rest on the tailgate and act like a sled deck for bigger purchases. As well I can put Costco stuff underneath the Ramps when it’s elevated. Won’t need to remove them period now.
Then I cleaned my bench before painting the Ramps. Will have an installed pic tomorrow.:bounce:
ZRX61
Solar Blight Valley, SoCal
I got ambushed on the way to the garage...
Yanno how you can walk around your house with the lights off because you know where everything is etc?
Walked from the main hallway through the laundry room to the garage in the dark. Halfway through the laundry room & slam into a cupboard door that was left open.
Three feet later I slam into another one.
Asked roomie about it & all I got was "I wish I'd seen that"
Yeah, so do I...
Slednut
Washington state
Nice looking work Slednut. Is that your own fiber splicer ?
No, it’s the oldest one the telephone company I work for has and was over $30,000. Our newer splicers are around $17,000. They have nice features but we’re constantly sending them in for repair. This one has always worked and I’ve gone through probably 6 sets of electrodes.
We’re planning on buying a ribbon splicer which splices 12 fibers at a time.
kaymccampbell
Upstate New York
Fiber splicing has obviously evolved a lot from the little guillotine, glue fixture, sanding block, and loupe.
Slednut
Washington state
Yeah, with all the high speeds we are replacing all the hand polished/mechanical connectors.
Here's some pictures of the splicer aligning, fusing arc and how big the fiber is. In the aligning pic you can see the core of the fibers which is where the light actually travels through.
Dan in Pasadena
Pasadena, CA
Not a lot. Too hot and muggy here.
Finished final coat on small drawers late last night so I could install drawer pulls. A long & short screw provided w/ea. pull; neither the right length natch - too short and too long! Had to cut & blend the threads to fit.
Mounted a long drawer pull to use as a hand towel bar on sink stand because it matches the door & drawer pulls. Good idea but didn't "stick out" enough so I added some blocks. Not sure I'll keep it this way but works for now. Mounted bottle opener & catch can.
Kevkx125
DOUGLASSVILLE, PA
serviced my generator and played with my honda mt125
skulldrinker
Bolingbrook, IL
I laid on my couch all stiff and sore from replacing the back 3 plugs and a coil on a toyota 6 cyl. 7 hour job.
Motorman55
South Jersey
Remove all the yard tools hanging on the 'inside' wall near the overhead garage door. This opened up a nice 3 foot wide wall space to which I then placed the Skat-Blast cabinet against.
Put the 'Frankenstein' air compressor against the 'outside' wall near the overhead door. Then I installed a shelf over it and hung up all my HF Portland electric yard tools.
After that I hung all the HF tire changer parts on the wall under the window. I can easily reassemble and bolt it to the floor should I need it. Meanwhile its stored out of the way.
Next I rolled the Hein-Werner 12-Ton Press in front of the side window. There's even enough room to slide my stainless tool tray under the press. Getting that out of the way.
Still a few more things to do....as always.
ZRX61
Nothing much, but heard on the local scanner that a mechanic in the next town over had a car fall on him (no details). There were no further updates, so it looks like it didn't end well.
PhantomEB
Second thin coat of rockerguard before breakfast then waited til 2pm and loaded up the new ramps, measured 3 times and checked each side for same spacing and secured it all down.
My measurements were bang on as the ramps ‘just’ sit on top of The tailgate for plywood or drywall. No need to remove these guys unless I get the bed lineX’ed in grey. Extremely happy the Aluminum ramps lay flat for trips out.
Box cover is next.
I finished the repair on my Bobcat quick attach mechanism. The bucket no longer falls off. Winning! :)
Check out the video:
didit
S.W. Ontario
I started mounting and designing the stretcher/shrinker on the pedestal so it can be operated with either foot, leaving the hands free for directing the metal. The pedestal was built to accept receivers for a buffing motor, wire wheels and the stretcher/shrinker in an attempt to save space in my small garage.
Motorman55
South Jersey
Hung Ole' Polly the Parrot from the ceiling. By the look of the smile on his face, I think he's pretty happy.
Dogmeat
S. Mich.
I swilled down some good ole' STROH'S....AND.....puffed on a little evil weed!!
It was a real "Joint Session"!!
ZRX61
Loaded car up with recycling for a trip to the *redemption center*. It was closed, didn't know they were closed Wednesdays.
Decided to leave it all in the car for another try tomorrow. On the upside, the car is currently worth far more than the $1.00 I paid for it.
jshillin
PA
Put the top on the shoe rack I'm making and put the drawer in it. Hoping to get the drawer face routed tonight and everything sanded.
67carl
California
I built a test box for a hinged door...
I had bought a mid century modern stereo console that didn't work, with the idea of using it my office to hold all my electronics. So I removed all the old electronics and modified the interior to suit my needs.
The front panel was never meant to come off but I needed regular, easy access. I found the panel was screwed in place to small blocks and taking those out meant the panel could be pulled out. It is a tight fit and not easy to do, so I wanted something easier. The panel is recessed, so it has to come forward first, then tilt out.
I came up with the idea to use hinges like the ones on those tilt out bathroom or kitchen drawers. The only problem is they are fairly difficult to install correctly. It's not so bad if you have rear access when to door is in place, but I don't have that, so I decided to build a test box and see where the pitfalls were.
It's a good thing I did as I learned a lot. At first I had the hinges mounted above the stop block, but found this moved the pivot point too high. When the door moved out then the top tilted out, the bottom tilted back too far and hit the stop block. So I know I'll have to cut the blocks out where I install the hinges. I also learned in the closed position the part of the hinge that attaches to the door isn't at a perfect 90 degree angle to the cabinet; it leans back. So I needed to mount the hinge a bit further back from the stop block, so that the door hits the stop block when the hinge is at 90 degrees (and isn't fully retracted).
Anyway, got it figured out. Also had the old parts I removed and decided to see if I could power up the lights on the tuning dial. No idea what voltage it needed, so I started out low and cannibalized a USB cable. The tuning dial has 4 black, unmarked wires, so I just started trial and error with the hot and ground from the USB (low voltage, no danger). Finally got the right combo and it works! Not sure what to do with it...
