promethean-in-fl
I suspect this Grade 5 3/8"-16 new steel bolt bottomed out in this blind hole in this old cast iron marine exhaust manifold and was torqued until the bolt head sheared off.
I've read quite a bit on here about bolt extraction techniques. Based on that, I'm inclined to go the route of welding on a nut, lubricating with beeswax or Kroil, and trying to back it out with a wrench.
However, I'm unclear what female thread damage is likely and whether it argues for going straight to drilling out the bolt rather than further trying to unscrew it and possibly further damaging the female threads.
So far, I soaked it with PB Blaster overnight, double nutted it, and only got it to move about 10 degrees with a wrench on the bottom nut. It felt springy like it might break if I torqued it further. Then, I heated the surrounding area to about 195 deg F with a heat gun, melted some beeswax at the base of the exposed bolt, sprayed the exposed bolt only with MG Chemicals Super Cold Spray, double nutted it, and the bottom nut slipped without turning the bolt (not sure why it slipped, maybe contaminated exposed threads with beeswax or the cold spray).
My auto mechanic wants to MIG weld a nut on and back it out. Some mechanically inclined guys on a boat forum I'm on think I should talk to a machine shop given how it got stuck.
This is at the gasketed mating surface to a riser.
Thoughts?
CORRECTION: Broken bolt is Grade 2, not Grade 5.
Thoughts?
