Ultimate Barn Find
R
Robert Haas
Something very exciting is about to happen
R
Robert Haas
6 hours later.......
:rocker:
Copymutt
Colorado
Hi Bob, just read the thread. I run an original 265 in a 55, 210. Come on over to Trifive.com.
Great bunch of pros and newbies. Don’t have to sign up, you can just lurk.
Jim
R
Robert Haas
Jim
Thanks, I am a member there too. :rocker:
R
Robert Haas
Getting the firewall ready for the big block.
First the passenger side.
R
Robert Haas
Firewall fab is complete. Not bad, 3 days after work and I am done
R
Robert Haas
Are the cutouts required because the block is longer, or are you moving the engine further back?
The BBC is a little larger in most dims, but the heads are much wider and the roller valve train I am using requires a slightly larger valve cover. I am mounting the engine in the "stock" location. Same position as the small block.
Seagoon
Scunthorpe. UK.
Thanks. We don't learn much about V8's this side of the pond.:)
R
Robert Haas
Front suspension is torqued and fully assembled.
Not to shabby for part time work, got this far in 15 days:rocker:
R
Robert Haas
Sunday was A fun day. All sheet metal going back on and getting ready to get after the mechanical, electrical and trim it out.
R
Robert Haas
Now this delivery is getting me all misty eyed. :)
R
Robert Haas
damn exciting couple of days.
Not that any one cares but the firewall modifications, custom headers and oil pan have the Big block nesting in very nicely. :rocker:
pwschuh
Mid-Atlantic
Maybe I missed this, but do you have the missing passenger side trim or is that still on the list to hunt down?
derek_m
Really nice car, love the plans for it. Only thing I would've done differently is added a radius to the edges of the firewall clearance to make it blend in with the rest of the firewall, as if it came that way from the factory.
R
Robert Haas
it is nearly invisible once the engine is in there.
R
Robert Haas
blew off the bottom of the body and applied a rubberized undercoat. (this should aid in keeping some sound out of the car}
R
Robert Haas
That gets me to last week.
The engine.
Starting off with a Mark V block.
Using a Scatt forged steel crank
Scatt forged H Beam rods
Icon forged pistons gets the bottom end and short block covered.
Up top I am using Edelbrock 118cc square port heads that have been CNC port matched to a air gap Performer intake. A Comp cams hydraulic roller cam, Comp cams roller rockers.
Will be firing it on the test stand this afternoon.
:rocker:
don long
southern california
Somebody is having a lot of fun. Your progress is good and you gota love that rotisserie when you need to get under the car. the motor looks good sitting on the frame by its self.
You will be crusing it soon.
stinkity stoink
New Jersey
That’s going to be fun to drive. Nice progress
On the undercoating did you use just regular cans or did you use a system like lizard skin ?
R
Robert Haas
painted the motor, installed the clutch and transmission.
Will be dropping it into the chassis today
