Let's see your Herbrand!
outofbounds
Another Herbrand in my drawer thanks to the generosity of one of our fellow GJ members. Many thanks, my friend. And, wouldn't you know it, Herbrand is trending on the forum.
This thing is in near mint condition. A 3/8" drive ratcheting adapter. I don't know how common this type of mechanism is. Most I've seen have some form of toggle switch. This one uses the uppermost plate (the narrower band of knurling) as a rotating switch. It was a bit puzzling at first understanding the mechanism but it actually works very well. Low tooth count of 20 tooth.
Hope you're well too, Lardy! I'll look forward to that post-corona cup of coffee.
Shelbylex
I got some Herbrand tools which I finally cleaned up (from the 8/30/20 purchase - I am well behind)...
HERBRAND 1/2 drive
1” Short, S-132
13/16 Long, D-26
7/8 Long, D-28
57/64 Long, D-28B
15/16 Long, D-30
1” Long, D-32
Extension 10 1/8” S-28
I doubt I will ever use 57/64 - first one for me. If I remember correctly, it's for Spark Plugs, but I do not remember for which engines...
ConductorChris
Hopefully this is of use to someone on here. Herbrand HP-710 Air Hammer parts list.
The product of a Herbrand bender (double pun intended).
S-18 1/2” flex speeder
and
S-12 1/2” speeder ratchet
I was happy to pick up these pieces.
Slackmaster G
Here is a big old herbrand engineer wrench
Fred Knox
Nor Cal
In one of my buried boxes of tools, I recently uncovered these bunch of Herbrand tools that I can not identify. Would any of you know what they are and what they are used for? On the sides, they are engraved:
HERBRAND
MADE IN USA
VAN-CHROME
No. 370 or No. 372
Many Thanks.
MR.X
Really interesting tool. Go to toolarchives site Herbrand 1940 catalog p.40
outofbounds
The first 1/4" drive Herbrand I have stumbled over. M-22 (5-1/2" Extension) and M-516 (1/2" Tall Hex socket)
c1504
I can’t imagine the triangle stuff is that sought after but I had never come across any before these
bonneyman
Desert SW
I've never seen a Herbrand so marked with a triangle in the logo like my Bonney's before.
Some 1/4" stuff20210309_025715.jpg
Thanks! Box looks similar to that awesome carb set you posted, but no special carb stuff.
humber2
Downunder
HERBRAND 1/2 drive
1” Short, S-132
13/16 Long, D-26
7/8 Long, D-28
57/64 Long, D-28B
15/16 Long, D-30
1” Long, D-32
D-28B, the B is for Buick, a super thin one for Spark plugs only.
humber2
Downunder
Do you know which Buick? My experiences are with the straight eights, which either use the 7/8” or 13/16” sizes.
Has to be the inline eights as the set was offered in my 1939 Catalog.
I suspect the stated size being 1/64 larger than 7/8 was a decoy to alert the shade tree mechanics that it was thinner and weaker for other uses.
The spark plug socket table in Herbrand catalogs has little symbols next to numerous sockets with annotations below the table.
In 1937 the annotation for the DS-28B (57/64") socket reads: "Extra Thin for Buick."
In 1942 it reads: "Extra Thin for Buick up to and including 1940."
In 1948 it reads: "Extra Thin for Buick, prior to 1938."
So, go figure.
The 5/8" socket (DS-20) annotation reads: "For 1941 10 mm in Buick, Cadillac, Chevy, Packard"
The 13/16" socket (DS-26) annotation reads: "Fits A.C. 10 mm Plugs."
The 7/8" socket (DS-28) has no annotation.
Ricky Joe
Roanoke, Va.
Interesting. I know Snap-On made a special socket for the 7/8” size. I have one dated 1937. The last two Buick engines I did were a 1937 and a 1934. My regular Bonney deep well fit down the tubes just fine. Snap-On number is s9803. I also have the Herbrand 57/64”. I’ve never used it, though I’ve worked on several Buick’s, from a 1929 “K” model to 1947 Roadmaster.
I don't see too many Herbrand socket drive tools around these parts, and 3/8-drive are even scarcer, so I couldn't leave this behind at the flea on Thursday.
leg17
Kentucky
Managed to put together a set of Herbrand 'shortie' DBE.
leg17
Kentucky
Terrific looking set there! How many individual acquisitions made that set up?
OOB I honestly can't remember. It has taken a few years.
But it is at least five, and probably six. One at a time. Got the last one about a a month ago.
LesserSon
PA USA
Some Triangle-era metric DOEs I picked up today. 8-19mm. Some chipped chrome. Posing with some close relatives.
Mintgrun
Kingston, Wa.
I brought these pliers home today. AA says they're from the twenties. It wasn't until I got them home that I noticed the Ford name on the inside of the handle. Sorry for the fuzzy photo of that detail.
Tom
I picked up an 1831 (3/4") "Obstructo" wrench at the flea this morning. Along with the 1825 (1/2") and 1827 (916") Obstructos I have managed to collect in onesy-twosy style over the course of several years, that makes a grand whopping total of three, so I'm slowly half way to a complete if decidedly imperfect set.
Imperfect not only because of the horrible condition of the 1825 and 1827, but because those are prewar "VAN-CHROME" (chromium vanadium) wrenches with the script underline Fremont, O. logo on the 45* heads, the part numbers stamped on the 90* heads, and the sizes stamped on the flip side. Note that the 1831 is a wartime wrench, with all the markings (brand part number, and sizes) marked on the shank on one side of the wrench, a simpler block logo, and that telling "8742" AISI New Emergency triple-alloy (Nickel-Chrome-Moly) steel composition number forged in and proudly proclaiming Herbrand's compliance with WPB steel composition restrictions (low chrome, low nickel, low moly, and no vanadium).
Given the frequency of my finding them, and the old beggars can't be choosers adage, I'll take what I can get!
For a glimpse at a much better partial set, see Jim C.'s in post #9 on page 1.
Snagged this early 1920's "S" wrench at the flea this morning. The milled openings are 11/16" (3/8" U.S.S. bolts and nuts) x 19/32" (5/16" U.S.S. bolts and nuts). The most interesting marking is the model numbering scheme. That's how Williams did it, forging the series number for short flat-shanked "S" wrenches ("66X") on the shank, milling the openings, and then stamping the number for the precise size configuration ("663A") on the minor jawface. I know that the industry eventually coalesced on Williams' part numbers as standards, but this goes well beyond that. In fact, if not for the script logo and the Diamond-H forge mark, I would've guessed this to be Williams, that's how much it looks like a Williams. I'm eager to see what leg17 and HeelSpur have to say about this wrench. I have never seen one before and the earliest catalog available in the public domain is 1937.
leg17
Kentucky
Lugz that does look suspiously like a Williams forging.
I will try to plunder around in the buckets and see if I can locate a Williams equivalent.
We sure need a 1920's Herbrand catalog!
ooba tooba
40s? 50s?
Especially with the "New Emergency" triple alloy steel number forged in on the shank like that. They really squeezed that on there. I have a lot of wartime Herbrand, but I don't think I have any DBEs with the AISI number placed on an angle like that. Nice find.
