It might not be a flare.... It just look like a join (sleeve) preload with solder.. those... except the in port seems to be deform from playing with the monkey. You might have to find a way to make it "round" and "great" again. Solder is fine for Hot water / water/
The out port just looks like it's been tinned for your convenience.
wipe the joint with a rag when your done and it is hot. it will look prettier
That's what all the pros do. It gets rid of the drip. But at this point I wouldn't heat it up again. It looks fine to me.
Dog nuts
Good idea. But i just completed the 2nd joint. No pin holes in the first joint. 2nd joint didn't turn out as well. It was pretty out of round and I felt I re-rounded it slightly too big.
I reheated this 2nd one and felt it took more solder.. reheating may be a no no, though.
See pics. Thanks for all the feedback.
I used to use a wet towel until a plumber showed me to use a dry one. Wet towels steam up and get hot. A dry towel, so long as you move quick and don't burn it, will stay cool to the touch.
I reserve wet towels for when I need to freeze solder quickly (not something that comes up much).
LOL not sure if that is a pro slang for those things...or
I just wipe those with a wet towel while it is still hot.
