Ingersoll Rand 35MAX vs. Astro 1822 Nano Power Difference
CobraRed
The video:
I'm biased because I own a nano, but geez.
2nd episode which is Harbor Freight vs. Aircat just posted
WhataTool
So is he saying that both IR guns are rated at 450 but the old one made 1.5x the power as the newer small one, and the old one actually made 531 not 450?
C
CobraRed
Max is usually measured at the 10 seconds, so when the old IR was making around 450ft-lbs the 35MAX was making 276.
WhataTool
We never really invested much into mini impacts here, do these things hold up?
Benito
Eric O. has been using his for years without issue it appears. I imagine it's not an all day every day tool, but still.
redwrench60
East Tennessee
I’ve been using an IR35MAX since it came out and it’s been reliable. I’ve pulled untold amounts of transmissions and done loads of under car work with mine. It lets me do all but the toughest work with a lightweight compact 1/2” impact. It performs about like I thought it would given its air motor and hammercase size. I’m surprised to hear that one doesn’t make more power. My instincts tell me mine is a little stronger than that unit he tested. I could actually hear the Astro was going to be stronger than the IR in that video.
2ndGearRubber
Pittsburgh
Impact ratings lie, surprise surprise.
I can tell you my 35max ain't dreaming of 450. Put a swivel socket on it and it's basically a noise maker.
Idk why so many of these reviews sit and rattle on something for more than 5 seconds. If the gun cant move it in that amount of time, it's time to get a proper impact. I worked with a guy who used a 3/8 impact and flip sockets to remove lug nuts. Every single lug was 10 seconds of rattle and hammering.
demarpaint
Long Island
I can't speak about the 35 max, but the newer 36 max is actually pretty good, and according to their specs stronger. Both are 1/2" drive.
Mr_B
Reading
Some of these stubby and compact impacts are very good .
Real stubby ones never much more than 300 but the compact ones can be in the 500 range which does 95% of my work and I don't want be using bigger/heavier tool unless need to .
Other issue is you need good air setup and most don't, soon as you around 70-80psi dynamic you lost a lot of ft-lbs .
The Astro 1823 was a more useful all round package as had bigger hammers but that got discontinued and did seem have some user complaints .
The Facom/Mac stubby and compact range (MAC MPF990501C, Facom NS2500G) is some of best hitting good all round design/power to size, ACT also have a stubby I like using .
C
CobraRed
The Harbor Freight vs Aircat episode was also just posted, maybe an even more significant performance difference
Benito
Where do you even find a 36MAX? I haven't seen one for sale
Benito
I bought mine on Zoro with a coupon. Amazon has them as well. At the moment Amazon has two in stock. So there's no confusion use 36 QMAX for the search.
So is it 36MAX or 36QMAX the quiet one that's we're talking about, because the quiet ones are usually less power otherwise, correct?
