jar944
Jar: i'm sure you'll figure it out and maybe save a couple for your favorite machines if you do get more power if that's what you like (if you can afford it).
ALL: so i've been building a fence around our property (again). the last time I built one was about 25 years ago and this one has been in the plans for a while now. I bought all my cedar 6x6's, 2x6's, 2x4's and 1x6 fence boards at a local mill and hauled them home wet and put on big racks to dry (stickered each row) so I didn't have hardly any boards warp or twist.
my question to all you that know much more about wood than i do is this: i'm notching the top 2x6's into the 6x6 posts and i've been leaving about an 1/8-1/4 inch gap for the wood to expand since i'm usually doing my work outside when the sun is shining and it's warm. i'm also planing each board and cutting and routering out the notches. do I need to do this?
here's a few pictures of my new cedar fence and we (my bride and I) really like this PPG (was Sikkens) stain and even though the can says only one coat we like 2 coats best. We've also been brushing on brown Copper Green paint/stain on the ends and tops to maybe help keep them from rotting as quick.
Unless the boards are bone dry (and if they are treated wood they are not) you wouldn't need to make the notch oversized. Tight to the rail should work as i would expect shrinkage not expansion.
