Above 1200 Sq/FT Bad a$$ barndomium build- in progress
shortykorte
Tallahassee, Fl
Definitely will give the look you’re after. This looks like a door to the inside so I meant keeping the cold AC from escaping.
fartymarty
Fort Worth
I'm curious about this as well, especially since you chose to hinge the door offset ...so one side of the pin will seal on the inside and the the other on the outside...correct?..and maybe some sort of doughnut seal at the pins?
Regardless, it's a great looking door.
...also "subscribed" :bounce: although I'm not sure why anyone would care about that, not like it's youtube. :dunno:
Mgnu
Valley of the Sun, AZ
New Dutch door being installed. Build it out of old reclaimed wood that came out of a burnt down flour mill in Oregon.
Wrapped in 1.5” steel angle as to “control” expansion of wood. It pivots 8” from the side and has flanged bearings inset with 1” pivot pins.
Ordered a double pane Evergreen glass that will be inserted within the upper portion.
Love that Dutch door, might be my favorite pic in the whole thread. :rocker:
T
Tozlakes
Paso Robles, California
Garage doors going in. Lots of bracing needed as these things are massive in size and weight.
In addition, the door in the living room to patio needs to be modified on site as the springs and opener would have been in the middle of the upper windows and blocking the view as it will open vertically straight up. Instead we are lowering the lift mechanism and recessing into the wall by using pillow lock bearings on the side beams and installing the Liftmaster in the middle of the springs and shafts instead.
T
Tozlakes
FartyMarty, on the pivoting Dutch door the best method I have found to seal around the pin is like you said with a doughnut type or “S” seal. As the pivot makes things much more dynamic, I will have molding on the outside of the door where it will seal from the handle side “up to the pin”. From there the molding and seal will be installed on the inside as seen in my original drawing attached.
fartymarty
Fort Worth
Thanks!
I hope I'm not being too problematic with my questions..?
..but.moving on to other doors....although I think I understand your solution (sounds ingenious, can't wait to see if reality matches what I've mentally pictured) to the living room door ...the double door photo (looks great, I love that shot) generates another query; Am I seeing 4 springs on one door and only two on the other?...if so, why?
T
Tozlakes
Yes good catch. They somehow only sent me one shaft so waiting on arrival as to complete the second large door. Not looking forward to the winding of the 4 springs of 18 revolutions as it is always touch and go not to mention It just feels dangerous!
T
Tozlakes
Started laying the 36” stacked stone wrap around this morning. Wanted to keep it mostly grey yet wanted some browns in it also in the case we get any kind of rust dripping from the siding it might not be so noticeable.
T
Tozlakes
About 95% complete on the vertical garage door installation. Had to totally reengineer the shaft,spring and opener location as it was originally to be installed at the top of the rails in the middle of the second story view.
Took a break to hang for a few days at the vacation home on the Colorado River near Laughlin, NV.
fartymarty
Fort Worth
Looking forward to the details of this when you are through. :)
T
Tozlakes
Fartymarty, will take some pics this week of the Door opener details with some explanation of how we are able to make everything work while still looking like a professional, or better, install.
Just received a pair of 3” pulleys as to control the cables from the lower door section up to the main cable pulleys on the shaft. Will fabricate some adjustable brackets as to play with cable tension and feed. These are the kind of steps in the build that take up so much of our time but also what makes this build so impressive to everyone who sees it. Well worth the time to do it right!
T
Tozlakes
Here are some of the details of the Living room to porch glass door opener installation.
The original design had all of the springs, shaft and opener directly in the middle of the second story view windows and was not going to fly.
Decided to reengineer a system that took all of this mechanism downward and inset into the wall. Took 7 days of trial and error with spring tension adjustments, additional pulleys and placement of the opener motor into the center instead of hanging off one side (after drilling through a structural beam that would not pass county inspections) as to get it to work as intended but in the end the time was worth it to get the desired result.
fartymarty
Fort Worth
Nicely done! :bowdown::rocker:
Thanks for the details! For some reason I thought that you'd need pulleys at the top and extra long cables, but I see now that would be silly.
Is there shaft support between the spring and the opener or just the opener holding up the middle?
T
Tozlakes
Farty, we installed and watched carefully for deflection in the shafts but felt the opener unit was stout enough in the center to support the shafts. On the Outer ends of this and the larger two doors we did add pillow lock bearings to the shafts at each end as they seemed to be deflecting more than I felt comfortable with.
ZRX61, I will take a ride on the Harley in the morning and pick up the orphan edgehog as it is less than a mile away from the house. We’ll give it a new home and send you pics of our family of hedgehogs and the new addition!
ZRX61
Solar Blight Valley, SoCal
Outstanding! :rocker:
btw, I had a brainfart so they're expecting a "Mr Tozlakes" to arrive on a HD :)
ZRX61
I dropped by the bar the night I was there. There was one group of people in the far corner & another group in the opposite corner so didn't stay after sticking my head in the door... but I'd already visited a few bars by that point.
T
Tozlakes
Chance Our Fox Red Lab is now back to a family of three hedgehogs!
Thanks ZRX!
T
Tozlakes
Having some unusually crazy weather in Central California with monsoons. Good opportunity to send the drone up for some video footage of the build.
Nutt, yes our Lab goes for the heart (squeaky bulb) in all of his toys. Most of his toys have duct tape around them at some point as to get a few more days out of them!
T
Tozlakes
Thanks for the feedback on the video. Wish I had more talent as a drone pilot as some of these guys can make videos that are so smooth and focused with no effort at all.
Kind of like my golf game. If I only do it once a year I can’t expect to be good at it!
T
Tozlakes
Barndo build has been on hold for a bit due to a reassignment to Alaska. In addition, been working all available time on our current house in preparation for selling it while the market is hot and interest rates low.
People going nuts for property in our area as we are half way between LA and SF and many are realizing that they don’t have to work in a corporate office but now can relocate and work from home instead. And have a vineyard to boot.
Started with the water tower and found out we liked the look of just knocking off the old paint with a stiff wire wheel better that covering in rusted metal. Not to mention way more economical. Secondly I was able to get the front half of the old 1901 barn covered in Corten rusted metal as seen in the pictures. Will become more evenly rusted with a little time.
Lastly will be mounting an old hay trolley on the peak of the barn to finish off the look we are going for.
ZRX61
Talking of water towers, there's a really cool looking one just North of the 46 at Whitley Gardens. Looks like a big egg with a hat
fartymarty
Fort Worth
T
Tozlakes
When looking through one of the woodpecker holes in the side, ours originally had a redwood tank in it. Huge Redwood beams as the supporting structure to hold the weight.
We also have a hand dug well that is 80 foot deep at the base of the tower. Scary to think about being 80 foot down loading a bucket full of dirt while someone up top pulled it up.:headscrat
mc4life27
With retirement coming in a few years we decided the time was now to build our dream
4200 sq ft home/shop. The plan originally was to purchase a piece of property now and build after retirement but got the itch and decided to pull the trigger and build a Barndominium on 8.5 acres we purchased in Paso Robles, California.
Working overseas for the past 20 years on a month on month off schedule makes the choice to be an owner builder an easy one. In addition, help from family and friends will make the project move forward more easily.
I wanted to document the build in some way and when running across some GJ member builds during research on the web, I thought what better of a way than to join and post right here!
We started with the grading a couple months back, installed the septic system, well and fencing at the entry to the property. Started with a few pics up to now with more to be uploaded soon.
Looking forward to uploading pics and videos as often as I can as to interact with other members and reduce the headaches that others have already experienced.
Updated video as of August 16, 2020 below:
Sweet project.
Btw your just a little north from me. I’m in nipomo. I wish I could build something like that where I’m at.
TTMotorsports
Lucerne Valley, CA
Nice project I'm an hour south of you in Santa Maria and would love to find a piece of property and build something like this as well. Dream setup
T
Tozlakes
TT you better get out on the pismo Dunes while you still can as rumors are flying once again of closing em down.
The purpose of this Barndo build is to be able to build some big HP toys once I retire.
We hang out at Dumont with our 700hp Tatum Black Widow as often as we can but occasionally at Pismo.
Dumont video:
