didnt know that vaco slapped their name on an adjustable
I'll have to give that a try. Thanks!Use BLO
Me too.Glad to see this thread back from the dead!
Wow I really like the idea of that finn, does the lever just allow more torque to be applied to the adjuster or does it actually lock in place?
I have always wanted a metric adjustable wrench.
i did not try it but i imagine it would give "vise grip" tightness if you cranked on it, vs an actual mechanical lock. the lever is directly connected to the worm when pulled out. if you push it in a bit, it free wheels so you can put it in the home position next to the handle.Wow I really like the idea of that finn, does the lever just allow more torque to be applied to the adjuster or does it actually lock in place?
Some of those look like Xmas gifts. Usually when all the new **** inventions flood the market.
What the hell when else will I get to talk about these?
from top to bottom, little baby crafstman, surprisingly bulky but comes in handy occasionally.
Lobtex W-zero, in my quest to find a crescent wrench that doesn’t **** this absolutely takes the cake, spring loaded two piece worm gear to keep position/remove play, flank drive style corner cutouts, quite comfortable and well finished.
craftsman re-flex, absolutely useless, worst POS they’ve ever released let alone continue to sell. Supposed to be “ratcheting”, WAY too much backdrag for that feature to ever kick in after the bolt is broken loose and if you use it on a bolt that takes any Significant force the jaws spread and round it. The day I see a laminated tool worth more than it’s weight in dirt I’ll be impressed.
stanley maxgrip, it is what it looks like, vise grip handle clamps it down on the bolt, eliminates the worst of the inherent problems with crescent wrenches, like it and use it a lot.
no name chinesium amazon buy, I kinda like collecting these wacky gimmick tools if you couldn’t already tell. Has a flex head and also has that “ratcheting” feature again, ironically this one works far better than the craftsman or most others I’ve used and you can turn it off by lifting that pin. Flakes a little chrome foil every time you use it, luckily it’s too thin to cut yourself with
finally that crescent tools thing, most bizarre one I have but certainly has it’s niches, mainly being the gripping and turning of irregular shaped objects. Wheel on the back if the head opens and closes the jaws (though the amount of force you can put on there leaves something to be desired) and it ratchets normally, glad I have it for those odd cases it’s useful.
Iridium rand said:"...that crescent tools thing, most bizarre one..."
Interesting didn’t know about that one, looks functionally identical besides adding the ratchet feature, maybe could get a better grip using that thumbscrew over the tiny wheel in the crescentIt's kind of funny that Crescent would elect to revive a design that is well over a hundred years old. That unit looks somewhat similar to early "wagon" wrenches made a century ago.
One example:
Looks like a metric adjustable wrench to me.
What is special about it?
Well, maybe nothing special. However for those guys, who are interested in the history of toolmaking, Belzer is known for the inventions and quality. I shall say - this wrench is of superb quality.What is special about it?
