Looking For Specialty Hook Wrench
Rstark18
Los Angeles
I'm hoping someone can help me find a tool that would make some of my jobs easier.
I need a hook spanner/hook wrench with pins that engage on opposite sides. It needs to fit a barrel of about 1.5"
So The barrel has 4 receiving holes that are 90deg apart. I only need to engage two of these holes to unthread/thread the barrel.
I normally use a standard hook spanner but in some circumstances the ape that worked on the equipment previously torqued down the barrel far too much. THe barrel is made of nickel plated brass and is very soft. If too tight the single pin spanner deforms the receiving hole.
I've only come across one tool that is close to what I need but it is very expensive for the apparent quality. ( https://www.grainger.com/product/FACOM-Precision-Adjustable-Pin-Spanner-36U003 ).
Any other suggestion besides the above tool?
4xdog
Santa Fe, NM
Park Tool (a well-known producer of bicycle tools) makes a pin spanner that might work for you. Ten bucks.
Edit: Ah, I see you're looking for a side pin spanner, not a face pin spanner... That Park tool is obviously for pin holes on the face of the target.
eejack
the garden state
As an odd thought, you might be able to modify a C clamp to the task. Set an appropriately sized pin on the static end and grind down the moving end to a point. Not pretty and not a shiny new tool but...
R
Rstark18
Los Angeles
Thanks for the suggestion but I don’t have a way to fabricate the tool. I did think about adding pins to an adjustable wrench but again I don’t want to fabricate.
KnurledNut
n/a
R
Rstark18
Los Angeles
That is something to consider especially the Hozan BB tool. My concern with that is getting the pins round so that they don't chew up the part.
FYI here is an example of the part in question.
darkzero
SoCal
My first thought seeing the pic was just a common single pin spanner but after reading your original post now I understand why you want a wrench with 2 pins from opposing sides.
Here's a thought, how about making some new vise jaws. Drill a hole & press in a dowel pin on each jaw. Then bolt the jaws in place of the original jaws. I suppose you might be able to make the same thing as jaw pads/inserts but my thinking is it's better to have them secured to the vise so you don't have to clamp down on the part tight & risk slipping.
Or you can make something like this which should be pretty easy also.
510ebl
Southern New Jersey
I realize you don’t want to fabricate, but an adjustable wrench could be cross drilled and roll pins installed with nothing but a drill, drill bit and hammer. Welding/heavier fabrication may not be necessary. Forgive me if this is exactly what you DON’T want to get into.
What is the required diameter of the pins to engage the holes in the part in the image you posted?
510ebl
Southern New Jersey
Is this a purpose built tool for the job? I don’t know anything about scuba gear, but it looks similar to your application.
mikegt4
sw ohio
Pick your poison.
Al Borland
There ARE single-size fixed wrenches designed for this. (Pin Spanners) They look like a box wrench with a half-moon opening and pins sticking in.
And it's an excuse to buy a NEW TOOL!!!!!!!
Garage Journal Peer Pressure!!!
Get them NOW!!!
R
Rstark18
Los Angeles
I like the idea of modifying an setting the pins in the vice jaws.
Question. The image you posted. What tool is that? It looks perfect for the job
It is 1.5“
This is exactly what that tool is for and I already have that. The problem with that tool is that the lockdown screws are made from soft nylon. Under normal circumstances it works fine but when the body is over torqued it shreds the nylon ends.
Pick your poison.
I’ve already searched McMaster and haven’t found anything.
I already have fixed single pin spanned specifically for this purpose. This is what I normally use. The problem with the single pin is that it loads too much pressure on the one receiving hole and will deform the hole. Distrusting the force across two holes will lessen the chance of deforming the hole.
Hiball
Missery
I bet a fixed or adjustable “Pin” wrench would work as long as the Pin fits the Hole solid and isn’t undersized, Unless it’s damaged. What is the diameter of the Holes? How deep are they? They appear to be fairly shallow.
darkzero
SoCal
I'm not sure exactly, I think it's for dirt bike shocks. But it might be too big for your needs & it's expensive. Just found it on google to show as an example to make but I think you said you rather not make a tool? It's a simple design & easy to make though if you have the proper tools.
R
Rstark18
Los Angeles
I bet a fixed or adjustable “Pin” wrench would work as long as the Pin fits the Hole solid and isn’t undersized. What is the diameter of the Holes? How deep are they? They appear to be fairly shallow.
The pin in a single pin wrench for the diameter of the body (1.5”) is always too small. The pins are usually around 2-3mm and the receiving holes are about 5mm And a depth of 1.5mm.
Again based on 20 years of working on these I can tell you when they are frozen, a single pin spanner deforms the receiving hole. i have a high quality specialty set of fixed single pin scanners just for this application which is what I always use.
Hiball
Missery
Again based on 20 years of working on these I can tell you when they are frozen on a single pin scanner deforms the receiving hole. i have a high quality specialty set of fixed single pin scanners just for this application which is what I always use.
1.5mm depth screams specialty tool to me, I own just about every pin/hook tool known to man including the Facom model you linked in the 1st post. If it’s deformed or the Pin you are using is too deep, I can see it damaging the holes and wanting to cam out.
How have you gotten them out in the past when “frozen”?
R
Rstark18
Los Angeles
The specialty set I have is made just for this application and has shallow pins. On a standard service job it works perfectly.
Whenever I get a body in that that is frozen I add a leverage pipe to the scanner and can always get it off that way. This always results in some form of receiving hole deformation.
Hiball
Missery
Gotcha.. Well due to the size and pin depth, I got nothing outside of maybe a strap wrench over some properly sized wooden dowels or similar material that are cut down.
Or maybe just a strap wrench?
510ebl
Southern New Jersey
Is the ring also nylon on the specialty tool? Could the lockdown screws be replaced with a threaded “bolt” with the end turned down to the diameter and depth you need? I’d wager if you had a new nylon lockdown screw (or whole tool) to take measurements from, someone here could make one from just about any material you could imagine. Maybe even replicate the “ring” for you in something that won’t mar the stainless/titanium part.
That said, I like the vise idea better...
joecon
what if you used tow of the hook type of spanners one forwards and one backwards, if you drilled a hole and put a bolt in to make it like a pair of pliers it would put the load on both holes and help stop the deformation of the hole.
R
Rstark18
Los Angeles
Thanks for all the suggestions. I figured out what I'm going to do.
I'm going to have two separate ways of doing this using extended tip set screws (dog tip).
First is similar to what @darkzero suggested using the vice. I'm going to remove the mounting bolt on one end of the vice jaws and use the holes to screw in the set screws. The vice I use (Heinrich Grip Master) to work on this equipment has through holes for the jaws which will make adjusting them in and out very easy.
For the second solution I'm going to use the specialty tool (that I already have and never use) and replace the soft nylon screws with extended tip set screws. I'll add a small knurled knob to the end of these to make adjusting quick.
