Firstly, welcome!Frank, any suggestions on how to disassemble the reeves pulley's on a vari-slo? I'm a good chunk of the way through a resto and really want to get them cleaned properly, but they're firmly stuck on despite my best efforts. Trying to figure out how I can get more leverage on them without damage.
Heck of a job on this one JoCoSawdust! It came out real nice! Plus i love what you did with the power panel... did you put a grounded plug on the back side ? Thanks to you , now i want to find a powr panel to mount similarly to my late 40's dp... Your lamp looks great as well! I have an edison led in mine to keep the heat down. It is a medium size to make it easier to change as well.
Ok, now i see what you did with that. I thought something look slightly off from the other powr panels I have seen. Still, I think most folks wont pickup on the fact that it isn't an original. Nice work!Frank, I agree, your DP #100 looks showroom floor new!
Thanks 11B. These lamps seem to fall into my lap for some reason. So far every Heritage era machine I've rebuilt has gotten one of them. I move most of the Heritage machines I do down to my son in law to outfit his shop. I just picked up a little 80 that I'm going to keep just because I like looking at the little guy. It almost looks like a salesman sample of a drill press.
Smokes: That's not an actual Powr Panl. I have several of the real deals but I don't like the fact that they're not grounded. I've seen a few "conversions"...they've all looked horrible in my opinion. What you're looking at on mine is an aluminum project box that I turned into a faux Powr Panl. It just houses the switch, which I like on the right side of a DP. I've got a single gang work box mounted under the wood top. It's wired to the service cord and provides power to both the DP and the light. I like how it turned out and that will be my go-to switch application for machines in the future.
Hoorn: That Delta you found is killin' me.........
This thread continues to inspire!
Frank DP #100 looks like it belongs in a Sears showroom. Outstanding.
Franklee- heck of a job on DP #100...how fitting that your 100th is such a nice example...even though it is emerson made, it still is something to be proud of.
Thank you all.Frank, I agree, your DP #100 looks showroom floor new!
Nice work on bundling ! That is totally something I would do.Well gentleman, I know in a previous post I mentioned going to work and not stopping at a local estate sale. I could not take it anymore and stopped by the estate sale on day 2 (Thursday). I went there expect to the drill press to be long gone. To my surprise it was still there so I asked what they wanted for it. $300.00 is what they said, and I told them no way. They asked if that was too much and what I would be willing to pay for it. I looked around and noticed a classic craftsman table saw sitting under an 80’s radial arm saw.
I really did not need the table saw but the table saw I already have is a crappy Delta that has a plastic housing. I almost never use it unless I need to rip some plywood but this was an opportunity to get a mostly complete classic table saw.
So I told them I would be willing to pay $50.00 for the drill press and $75.00 for the table saw but if they want to sell me both, I would pay $100.00 for the set. I believe I had the advantage of these items being in a basement that had no clear way to get these heavy pieces of equipment out, through and extremely overgrown back yard, up an insane hill to a very steep driveway.
They both came home with me. The drill press is a 103.24531 power bronze and is in really good condition with some surface rust but otherwise complete. The motor is not a Craftsman but a period correct Magna Motors 1/2HP.
The table saw is a 113.27520 10” tilting arbor table saw with a very heavy 1HP 113.19063 motor. The table extensions, miter, and geared fence were all present and at first glance the only thing missing is the blade guard that I would have never used anyway. The table saw was mounted to a heavy steel rolling table that will most likely be resold or tossed out, but it did have a Power PNL.
Not a bad haul for $100.00
The spring, disk and leather pad are installed in the inboard side of the feed handle rod.A couple of nice package deals Frank and 11B!
We laugh at those redneck engineering pieces but I always look at it as some guy making a machine or tool do what he needed it to do. Interesting to look at!
I'm rehabbing a little 80 that I picked up for 15 bucks 30 minutes from my shop. It's the no-frills, bronze bushing model that's complete except for the bits and pieces to secure the feed handle within the pinion. The PO had threaded the hole in the pinion and ran a length of all thread through it. The OM shows the feed handle being secured with a spring, a steel washer and a leather disc. There's also a snap ring on the feed handle. I'm not grasping what the spring, steel washer and leather disc do unless the spring just compresses against the feed handle and the leather disc is cut oversize and held in with friction. There's no lip inside the pinion to keep the leather disc from just popping out. Doesn't seem to be a viable set up to me. Does anyone have pictures of an intact 80 showing this assembly? Thanks.
Nice deal!Frank, coincidentally I got a three wheel K-S Craftsman bandsaw the same weekend you did. I paid $20 for the bandsaw and Craftsman tool table combination. I bought it strictly to use the table for the disc and belt sander I had also bought. Although I plan to sell the bandsaw as I have a 14" Delta, it's a solid, good machine.
I had one of those sanders but regrettably had to sell when I moved. Those are amazing and work very well....I would say you most certainly **** at that price!Frank, coincidentally I got a three wheel K-S Craftsman bandsaw the same weekend you did. I paid $20 for the bandsaw and Craftsman tool table combination. I bought it strictly to use the table for the disc and belt sander I had also bought. Although I plan to sell the bandsaw as I have a 14" Delta, it's a solid, good machine.
Smoke, the bandsaw/table was $20, the actual sander (attached to a really old cast iron table that weighed a ton) I bought for $70. I think $70 is an outstanding price for a sander of that quality and it cleaned up nice. I had intended to restore it when I got it, but it cleaned up so well with cleaner wax and fine steel wool I'm leaving the original paint as is. I didn't take a "before pic" but I got rid of 70 years of sawdust. Such a great, heavy duty sander, comically so much cast iron.I had one of those sanders but regrettably had to sell when I moved. Those are amazing and work very well....I would say you most certainly **** at that price!
Still at $70, you got a heck of a deal...I don't think you should repaint it...it is way to nice!Smoke, the bandsaw/table was $20, the actual sander (attached to a really old cast iron table that weighed a ton) I bought for $70. I think $70 is an outstanding price for a sander of that quality and it cleaned up nice. I had intended to restore it when I got it, but it cleaned up so well with cleaner wax and fine steel wool I'm leaving the original paint as is. I didn't take a "before pic" but I got rid of 70 years of sawdust. Such a great, heavy duty sander, comically so much cast iron.
+1What happened?
I lot of the photos are missing.
Where is the awesome first post with the links?
