Craftsman Drill Press
rrich1
Re: The Classic Craftsman 100/150 Drill Press
Got my drill press up and running. So happy with how it turned out. 4ff9800be0df23be1c265c43f2f236b8.jpg4e8833f06e63eb5f7a59a15c468cf8ea.jpga593c47eaeee17d85dcddcfdc7e9991f.jpg
Sent from my Pixel XL using Tapatalk
andylew
North Jersey
Looks great! The cover on the motor is slick.
Question, do you have the dimensions on the taper pin for the table? I'm currently using a #7 I had in a box of parts, but it's too big.
rrich1
Thanks
Ya I can get some dimensions.
eb369bb4a622b9c8c445f6f64549fb2c.jpge5dc3682809046d9228f1beca1edab0f.jpg43589d4be652f5d7a4167a258e0a3c66.jpg7f02aa1aeb3c8153bcef0c3f47f8e185.jpg
F
FrankLee
seMI, 48317
Hub/Pinion/Spring/Feed Handle Assemblies
Based on the size of the classic style of Craftsman drill presses, there are various designs of the spring/pinion/hub/feed handle assemblies.
Hubs - 1948-1949
ndfan6464
All over
So starting round two version 2.0 of the replication of the pulley cover for the 103. I did finish the other one but wasn't completely satisfied with it. So I started over. Found away to make the roll which is coming along. Hope to have it completed this weekend.
rrich1
Looks good!
ndfan6464
All over
Well made some more head way on the cover. Version 2.0 is definitely better. Couple more spots to weld up, prime and then paint.
Cruzan80
Denver, CO
Ndfan, haven't forgotten about the measurements, just been busy.
Sent from my VIVO IV using Tapatalk
rrich1
What is the correct chuck key for the 33 jacobs chuck? the one I have (not original) is a k32 and the pin is a lot smaller than the hole. making it slip out and i fear it starting to strip the gears.
ndfan6464
All over
That cover is looking great! What did you do on the round corner? Bend and cut on some tubing?
@Outlawmws; thanks brother! The cover is a mixture of 16 gauge steal and trailer fender. I made some bending dies to match the drill press diameters on the front and motor. Bent the base and pounded it out till I got the desired shape and tapper. The top round is where the trailer fender came in. I used the curve in the fender. Cut it out and then just shaped it till I was happy with it. Then just welded it to the base. Hopefully it'll be done this weekend. The hardest part was getting the hinge to work right. But figured it out. Used piano hinge from Lowe's. Cut two relifes in the base. Shaped the bend and welded the hinge in. Looks almost like the original from what I can tell by the pictures you all sent me.. which thank you to everyone for the help. Without the pictures I'd still be guessing.
F
FrankLee
seMI, 48317
Warped5
Northwest Indiana
IIRC from when I did my DP, I saw (somewhere?) a table of Jacobs chucks and the key that fit each ...
rrich1
ndfan6464
All over
So here's my attempt to recreate the front of the Mohawk. Off pictures I am guessing the horizontal bars are 1/8 inch wide and spaced about the same
ndfan6464
All over
ND, I'm confused; doesn't it say "Craftsman" vertically there?
On the front of the main body of the drill press it does say Craftsman like in the picture. But on the mohawk it has this bar on the front which helps keep the molded sheet metal together. I am assuming that's what it does by going off pictures. I've never seen one in person, just in pictures.
Nope I'm wrong, the Dunlap version had that; the Craftsman... Proceed! :beer:
ndfan6464
All over
I wonder if that covers the OEM's name? :dunno:
I am not sure. I wish I could see one in person. But I be looked all over for one and can't find one so I proceeded to make a replica to the best I could off members photos and measurements they sent me. What I am trying to figure out what model is in this picture? Mine and others don't have the word Craftsman on the body. Just the ball bearing wings. If mine is supposed to have e the word Craftsman then I'll have to have one made. But every 103.0305 I've seen doesn't have it. Any ideas?
Not me I haven't seen one in the flesh. AFAIK, that is the only Catalog they surfaced in, then the US was in WWII and production of that one ceased, or didn't, but was war production...
ndfan6464
All over
It's the only catalog I've seen as well. Well maybe one day we'll get to see one in the flesh, same as a return spring and cover..Lol.. I'll be fabricating those as well this weekend
Craptain
Tampa Bay FL
Mine does NOT have the Craftsman name on the side and no sign of having been there. I can also say that there is nothing under the front trim. The only reason I have to assume the manufacturer is the model number.
Sent from my SM-G900T using Tapatalk
ndfan6464
All over
That's good to know about the craftsman label. I am assuming you've never taken the trim off?
rrich1
Looks killer @ndfan6464
bubinga
can't help ya on the Craftsman name on the side, But as far as the cover, You're happy Right?
I think it's awesome.
ndfan6464
All over
I am.most definitely happy with the cover, now. Lol.. I am really picky about my work. Attention to detail. And without all of you sending photos, measurements and knowledge I wouldn't have been able to do it. So huge thanks to everyone. I'll be painting it today so it'll be finished by the end of the day. I'll be using automotive self etching/filler primer then a couple coats of paint them off to bake in the oven for a bit.
Craptain
Tampa Bay FL
Yes, I took the trim off once. There's nothing but flat metal under there.
Cruzan80
Denver, CO
The trim is to cover where the sheet metal joins. No sign of Craftsman on the side of mine either, but my guess is that it was an artist rendering that never made it past prototyping that way. The pictures in the '42 and '43 catalog are the same, so they didn't re-draw it for the new year.
And they were actually in two years' worth of catalogs, '42 and '43. But '43 required a special permit to get a motor as it was already into wartime production.
