- Joined
- Nov 4, 2017
- Messages
- 10,470
Nice spot! I am always looking in piles of tools for those details.
Actually they are 5 points but most folks classify them as a 6 point. Even in the 1986 Bonney tool catalog on page 20 they are classified as 6 point. The 12 point flare wrenches actually only have 10 points but that is naming convention on flare wrenches.Don’t see the 6 points. At least I don’t.
I think the proper term for your statement is ****. Just like my post!The bolt head or nut on which it fits is 6pt, hence the convention.
To be truly picyune, there are no points at all on that wrench - those are called interior angles.
That's not picayune. It would be picayune to point out the typo in picyune.![]()
A little update as I had a EF1214H 3/8 X 7/16 flare wrench. Anybody interested in a SK 3/8 X 7/16 flare six point wrench just private message me. I am also looking for a high polish EF2022H 11/16 X 5/8 six point flare wrench as the RF53 is a 12 point
I will continue to call it the same as the catalog calls it as it is the accepted naming convention and has been in use for the well over 50-75 years. No question in my mind and it gets the 6 or 12 or 18 quadrillion points across. I just could see it as I walk over to my co worker mechanic and ask for a 5/16ths 5 interior angle wrench and get my **** laughed off the face of the earth or have a strange look from co workerTo be truly picyune, there are no points at all on that wrench - those are called interior angles.
Which sizes are you missing? I may have some duplicates.Working on putting a whole set together of the LD series with an "AL" mixed in.
I haven't kept track of early socket postings, MR. X, sorry. 1927 is indeed the year they started blasting the trade mags with detachable socket wrenches and handles and they added socket wrenches to their TM in 1928. It's strange, but they apparently stopped date coding sockets fairly early. I have never found any forged-in/embossed sockets, but none of the early script CV sockets I have and none of the 30's and 40's sockets I have bear date codes. Your other uni joint doesn't have one, for example.looks like the embossed one is an S code 1927.....about as early as Bonney sockets get as far as I know.
I pm'd you, thanks!Which sizes are you missing? I may have some duplicates.
I hope I was clear; I meant to justify the naming convention, not criticize it.I will continue to call it the same as the catalog calls it as it is the accepted naming convention and has been in use for the well over 50-75 years. No question in my mind and it gets the 6 or 12 or 18 quadrillion points across. I just could see it as I walk over to my co worker mechanic and ask for a 5/16ths 5 interior angle wrench and get my **** laughed off the face of the earth or have a strange look from co worker
Just making sure that I am was clear on how I used normally accepted naming of things. I can say since bit drivers came into being I tend to use screwdrivers more for prying then I should but I still call them screwdrivers.I hope I was clear; I meant to justify the naming convention, not criticize it.
I did not and do not advocate calling it anything other than a 6-point, Mike. Just as I would not suggest you call a screwdriver something else because it does not have any screws on it, or a waterpump wrench something else because it doesn’t pump water.
Picked up a maybe/sorta 10” Automobile adjustable today - my first. Paid antique store price for the thrill of derusting.Won this 6" stillson in an auction. Paid waaaaay to much for for it.
DSCF3749 (2) by wvwheaties, on Flickr
The FOE5S set is all original that I bought in 1983. I can say I never lost any in this set but in metric set I did of course loss the 13-14 MM one. I hope you good luck in finding a complete set of these as I only seen one on eBay in the last 4 years and it went for a crazy high pricePlease show more of the FOE5S set. Really want a set like that
