I’m going to start framing my garage when lumber drops a little more.
I’m wanting to use pole barn metal for the siding with conventional framing. The best thing I can come up with is to build my exterior walls with 12’ 2x4s, sheet with osb or plywood, then wrap that with house wrap. Then running horizontal 2x4s around at 3’ increments to attach my metal to.
So I would get a good tight structure and still have 1.5” of wood or the metal siding to screw into and air could travel behind the siding to keep it dry without air leaking in my garage.
my stem wall is 6” so I have the room to do this.
has anybody tried this or have a better idea?
I don’t trust the metal to be screwed onto thin osb or plywood. It gets crazy windy at home.
Thanks
Thanks
