CARBed Air Fittings
dnschmidt
Phoenix, AZ
You should be using type V fittings anyway. That's really the reason. With respect to air fittings in general I prefer Prevost. To LXCam: Just you try buddy I'll rat you out.
Snapped-off
Indiana
I’d have to echo mikes question.
But if ya need snap, I’ll risk life and limb for you and smile smuggle some in. I ain’t afeared of no damn tree hugger. 😎
That's admirable. I did manage to order some. I just don't know how they relate to CARB.. Maybe they're going to ban air tools next.
Firebrick43
West central Indiana
Maybe in california they have taken to putting quick connect fittings on their bongs and crack pipes? And since most of the fittings a made with leaded steel and leaded brass they are protecting the health of their constituents??????
Snapped-off
Indiana
Scratch that. The vendor I ordered from just canceled my order under fraud suspicion. Back to the hunt for some F'ing air fittings.
Edit: Overpaid for the stupid things on Amazon. I tried...
Wrench97
Southeastern Pa
Sacramento County I believe is what the article I was reading named.
Not sure how CARB would be involved unless they think you can use them to spray paint..................................
Minor repair and maintenance of farm equipment or vehicles and similar equipment, for personal use or as a hobby use, may be permitted in all zoning districts for the benefit of the owner or resident(s), subject to meeting the following criteria:
  • Minor repair and maintenance of vehicles and similar equipment shall include brake part replacement, minor tune-up, change of oil and filter, repair of flat tire, lubrication and other similar operations.
  • Minor vehicle repair or maintenance does not include body or painting work of vehicle or vehicle parts.
It shall be unlawful for any person to engage in, or permit others to engage in, minor vehicle repair or maintenance under any of the following circumstances:
  • Using tools not normally found in a residence;
  • Conducted on vehicles registered to persons not currently residing on the lot or parcel; and,
  • Conducted outside a fully enclosed garage or accessory structure and resulting in the vehicle being inoperable for a period in excess of 24 hours. (See Section 3.2.5, Table 3.2 (I) of the Zoning Code)
seber
Deep East Tx.
Probably does not have a cancer warning on the package. Anything sold in California is known to be a cancer causing agent and must be labeled as such.
Al Borland
We got plywood in with a California Warning that it "May contain wood fibers, which are Known to cause Cancer in the State of California".
First, I would HOPE my plywood contains wood fibers.
Second, Does the cancer only occur in California, and how does it know to not cause cancer anywhere else?
Snapped-off
Indiana
I got an email back from Acmetools stating it was due to a changeover issue to their new website and I could order the fittings over the phone. That doesn't explain Summit and the other site though. It probably does have something to do with prop 65.
Too bad Amazon already delivered them.
Firebrick43
Even coffee was mandated to have a prop 65 warning by a judge a few years ago. Alas some cooler thinking head(still nuts in California) overrode that judge. But still.
mike93lx
Richmond, VA
It isn't like coffee isn't processed before we get it brewed. Definitely chances for **** to get added that makes it cheaper or faster for them to process and package it
Firebrick43
The main issue is with acrylamide. A chemical produced during high temp cooking, therefore many of the foods we consume.
mike93lx
Richmond, VA
And if that is known to be a possible cause of cancer, I'm glad it is highlighted, even though most will blow it off.
Don’t get me wrong, I'll still drink coffee and in significant quantities
2ndGearRubber
Pittsburgh
Pretty sure everything - possibly - causes cancer.
Multiple peer reviewed, double blind, studies? With reproducible results, which are statistically significant? Then we can make some signs.
Firebrick43
:headscrat So lets make industry spend who knows how much money (probably millions) to place prop 65 stickers on everything just out of fear of lawsuits, so most will blow it off, even admittedly you??? MMMM, Makes sense to me. :lol_hitti
mike93lx
Richmond, VA
Yes, you captured the entirety of my opinion on the matter in your post. 👍
