Above 1200 Sq/FT Fantasy becoming reality in DFW
wtfovr
After a decade of lurking and dreaming, we finally broke ground YESTERDAY!!!
I'm in the north Fort Worth Texas area in a gate community with an HOA. Save the "I hate HOA's". We actually have a good one but they have rules that I agreed to so I will abide. The general attitude in the neighborhood is NO METAL BUILDINGS. So the HOA designed the building materials matrix to model that sentiment. They didn't expect people to BRICK a metal building like I am about to do :)
This would have been erected last year during covid but foundation issues on the house soaked up my garage money. I overcame that this year and even accounted for the increase in building costs, so we are underway.
Building is a Red Iron welded in 35'x50'x12' with a 4:12, single 16'x10' and a 8'x8' insulated residential garage door, a french door for the future patio and a single man door with windows. We are doing spray foam, coated floors and a subwalls, full brick exterior, tying into our septic, etc, etc, etc. I negotiated with my wife and we put the building in the back of our lot with an 88' driveway; new build also.
Garage is a primarily for our racecar and another street car, 4 post lift, shop area, a gym area, a full bath with a URINAL, and a bar area.
We are stoked. I had a final meeting with the builder on Friday last week, we built up the pad with 6 truck loads on Monday, started forms on Tuesday, located electrical (that runs UNDER THE DAMN shop site) on Thursday, and dropped the plumbing in on Friday. Hopefully we are in concrete by Wednesday!! Builder says we will be dried in by mid December!!!
Pics to follow. Might be slow though, I am working 9hrs away in New Mexico. So all my management is being done remotely and with my Father-in-law and neighbor checking on their work.
W
wtfovr
You look like you have planned it well, My only recommendation is an 18 foot door instead of a 16.
I looked at it, but reality is I will never be 2 wide at the door and wanted to get the most of my wall space.
W
wtfovr
My view from a Nest camera I put on a pole to watch the progress.
Pad work. Took 6 trucks to bring up 14" on the back end.
Forms started. A one man show it seems.
2 Plumbers came out and roughed in the drains/feeds in a few hours. I have a neighbor coming tomorrow to check out the work before the pad goes any further. But hopefully if all is well, the builder can start making serious headway on Monday.
W
wtfovr
Where we sit on the property.
Since we don't need permits or inspections, I drew it all up on PowerPoint for my builder to use. Better than a napkin.
Playing with layout. Tons of left over space for gym, and hangout area
W
wtfovr
Forms are in
Footers are dug
"Tornado room" footers are dug and extra wide
Pad for a mezzanine center pole dug
Ground is prepped
Plumbing all in and mapped out (3 hose bibs, shower, toilet, urinal, 2 sinks)
Rebar going in tomorrow....nothing over Thanksgiving, and we are scheduled to pour concrete on Monday. 4" at 3,500psi
W
wtfovr
Job site before the day begins 24NOV21
I was thrilled to see they delivered the building yesterday. So as soon as the slab is cured, it can go up! Might have this thing dried-in in time for Christmas
W
wtfovr
Extra footer for the "storm shelter" room that will have 8' tall concrete walls and ceiling
Plumbing appears to be spotted in where I need it all. I really hope they measured a dozen times.
I had a extra footer pad poured for the mezzanine center support
View from the opposite side looking at the house.
W
wtfovr
Close of business on 24NOV21 and the vapor barrier is in, rebar complete, forms have the provisions for brick ledge, all my conduit in the slab for electrical and comms cable are in. I went a little overboard and put in extra 2" conduit coming up just in case I need them in the future.
Concrete scheduled to pour on Monday!! It would have been tomorrow but dang holiday getting in the way.
Today's pictures will come tomorrow.
jbrentd
Northeast Oklahoma
Looks like it'll be nice. There are a couple full-bricked (for HOA) metal buildings in my neighborhood. They were built for large RVs and are so tall the metal roofs can't be seen from the road. Otherwise they would have required shingles to match the house.
APEowner
Sunny, New Mexico
Cool build. I'm looking forward to seeing it come together.
Can we have some pics of the Cobras you show in the plans? I like pictures. And, Cobras.
W
wtfovr
My original 1995 Cobra vert with 31k miles. Was 100% factory original then got a full Maximum Motorsport suspension, Dart 348ci, AFR185 heads, 76mm turbo, T56 trans, full Holley Dominator ECU, etc, etc, etc. This made 750rwhp at 5,000 rpms with 10lbs of boost and zero timing on 93oct. We couldn't keep a clutch to hold and couldn't tune past it.
Then I got the itch and bought a 1994 Cobra coupe. Stripped it down to the shell, used it as a roller, welded in a 12pt Chromoly cage, mini tub, tube front end, etc. I pulled the motor from the vert and went to a 4R70w trans with transbrake, it went into the new coupe (racecar). Since then, I bought a pair of 76mm turbos and hotside that will swap out the single. And the racecar got a ton of other updates....basically built another car when the original plan was to just move power plants over and run it.
My wheel cribs that built all of the vert and most of the racecar before I bought a QuickJack 5k.
Yes the roof will be welded back on but once we get other bugs ironed out.
Before the plumbing and wiring began
Most recent I could find. Was testing out the under hood service light strip. There are several lights like this that run off a Milwaukee M18 battery so main battery can be killed and still have light at night in the pits
W
wtfovr
COB on 25NOV21, ready for the gray sauce on Monday
I dropped extra conduit pulls just in case.
received_577887906651985.jpegreceived_235611831994761.jpegreceived_223579466586208.jpeg
Obligatory shop dogs. My poor old man Jett Bauer (13yr old Boxer) and big fat girl Mischa Brea (11 year old Boxer)
Jon69RagTop
Boxers, my favorite breed. You’re a lucky man to have them age so well. None of ours ever hit 10, accept one. Great progress on the garage too.
W
wtfovr
We are lucky to get every day with the boy. He's had a long good life but we know we don't have much time left with him. Or big girl is in great health...just a little fluffy.
Copymutt
Colorado
Just found your thread. Question on electrical. Are you tying to the rebar for grounds or stabbing a couple rods?
larry4406
Northern Virginia
Will be nice space!
I know you said no inspections, but please have the concrete crew raise up your rebar using chairs to put the bars in the slab vs at the bottom.
larry4406
Northern Virginia
Honestly I haven't got that far. But pushing a rod.
I would put in a UFER ground while you have the chance. Here is how I did my barn (see Post #5)
W
wtfovr
I watched a few youtubes, now I am trying to find clamps in stock to get it in before Monday's pour.
The BIGGEST hurdle here is I am not at home, I am 550 miles away or I would be able to make so many small adjustments.
W
wtfovr
Damn you Home Depot (shakes fist in the air).
32' of the Home Depot Heavy Duty cabinet system on order. I couldn't resist the 30% off!!
W
wtfovr
Concrete pour went well. Now we wait. Steel starts getting erected on Monday and we should be dried-in by next Friday. Time to schedule the spray foam and electric company to bring my power in.
W
wtfovr
Congrats on a significant milestone! What are you planning to coat or seal the floors with?
Thanks.
I'm torn between polyaspetic or racedeck style tiles.
It's going to have a decent sized gym, bar, hangout area that I'd like different flooring underneath than the work area.
W
wtfovr
This kid thinking she is going to mark out her territory in MY garage! She crazy!
He used a sunken plate system with 6 long bolts welded to the bottom upside down in the form to weld the uprights iron too
Not sure how I want to approach this. This is my water line that is coming up for the hose bib. It SHOULD be in the wall form. Missed it by 6-8" though. Now it is coming up my walkway.
The slab in all it's glory. Steel goes up on Tuesday.
W
wtfovr
Next up is Steel starts on Tuesday
Spray foam on the 16th
Floor getting coated on 22nd
Rescheduled power company to bring my power out on 22nd also. I need to build a temporary panel still.
We should be drinking beer inside under temporary lights on Christmas Eve.
lakelandcat
Nice build, have you thought about AC yet? I'm Ex-Arlington and I know it gets hot. Now is the time to build in DFW. I also put a French door in my Man Cave. I'm outside Memphis now and did mine by myself. Elec. Inspector made me pound 2-8' copper ground rods for my shop. I do enjoy my screened in patio and access through the FD. Take lots of pics you'll be happy you did.IMG_0913.jpgIMG_1504.jpg
W
wtfovr
Thanks.
I am at bedrock in 6' so I hope an 8' rod is enough.
As for A/C, my 3 car attached garage has a 2ton split unit and I can't imagine not having A/C in this new garage. It will probably be a used compressor and air handler unit that I will run a duct down the center.
I am building most of this remotely. Trying to get my wife and neighbor to take as many pics as they can
lakelandcat
Thanks.
I am building most of this remotely. Trying to get my wife and neighbor to take as many pics as they cajI
I use to tell Yankees you don't survive the winters in Texas you survive the summers. I saw 112f and it would take your breath away. I did like playing golf around Christmas. My build is no where near the size of yours, mine is a 20x16 and a additional 8x20 screened in porch. You really find out who your friends are when you build something like this, I have no friends! The only help I had was a neighbor who helped me raise the GD wall because it had a 2x12 header, and he held a corner post on the patio, I had someone do the slab and I had to have a lic. elec. pull a permit and hook up to the main house. Other than that I did everything myself, a lot of work but very satisfying. I still have some sheetrock to do and it has taken me 4 years. If you get a chance check out Mikes Man Cave. I can't imagine building from a distance, it must be hard. Good spouse and neighbors are a blessing. I thought about doing tiles but if one got screwed up it would drive me crazy so I'm going to paint. Mrs. Cat always reminds me "your not building the Taj Mahal" :cool: . My new project is a greenhouse build on the cheap. Anyone can buy the sticks and put it up but it takes a skill to do it cheap. (I just enjoy building but at 64 I'm slowing down). Keep up the good work and have a safe holidays. MikeIMG_1918.jpg
W
wtfovr
We got steel up!! These dudes moved fast and very efficient. In about 8hrs they got all the structure cut, tabbed, welded, up and ready for doors, windows and sheeting.
this was early afternoon.
by 6pm (wow that pic is terrible, screen shot from video zoomed in. :(
