Connect LVL beam to 8 by 8 post
Bangon61
BC
I have a 7 inch by 16 inch 4 ply LVL and wondering what is the best way to connect it to my 8 by 8 inch post. 20220115_152808.jpg
Bangon61
BC
The notch is for the 3 ply 2 by 12 beam that continues over to the wall 8 feet away. That section will be cantilevered.
matt_i
SE Michigan
Always I'd like to see the full assembly setup that way you can cross-connect.
Welded steel is my preference. If you thru-bolt, do so at the neutral axis (vertical centerline of the symmetric cross section).
A part of the question is whether the post has any moment-bearing abilities or its just a pin joint to (or sitting flat on!) the floor.
Bangon61
BC
It is in an 8 by 8 post saddle with a pin into the concrete slab. The concrete slab at that specific point is 3 feet deep and measures 2 feet by 2 feet with plenty of rebar. It was preplanned before slab and rebar was put down
theoldwizard1
SE MI
What I suggested above or like a Simpson Strong tie APVT6 should be fine, assuming the other end of mezzanine joists provide lateral stability.
Concur !
I would also add a couple of 4"+ GRKs from each side of the post to insure that it won't split.
Bangon61
BC
Yes. The other 9 feet after the post will have a 3ply 2 by 12 going to the wall. With 2 by 8 cantilevered out 2and half feet . The cantilevered joists will be parallel to the joists attached to the LVL. If that makes any sense. I kinda figured the big Tee from Simpson. But I always look at options as long as they dont affect the structural integrity
FredWanaker
NorCal
The real issue is that the building permit will probably want the engineer to sign off, and stamp it. What he/she will put on the plans is unknown. If this is DIY then all bets are off when it comes time to getting city to sign off. And if there is no permit then why ask on the garage forum? Just do as you want cause you will do that anyway regardless what we suggest here.
billconner
Thousand Islands NYS
So floor joists are hung from side of LVL and sit on top of the triple 2x12? Makes sense. Are the sides of the mezzanine other than along this beam all at walls? Just trying to get sense of lateral stability.
Bangon61
BC
Yes. It's a 30 by 30 square shop. Am building a mezzanine in half of it. One side has 8 foot garage door and otherside has a 12 foot door. Am building mezzanine on the same side as 8 foot door. Click on picture
Bangon61
BC
The floor joists hang off the side of the LVL and attach to wall 14 feet away. The triple 2by12 is an extension of the LVL and that small section will be cantilevered
Bangon61
BC
The reason I ask is because you cant have enough information but you can have not enough. It never hurts to ask and see what others have done. I am very knowledgeable as I have been in construction most of my life. Thanks for your concern and assumption
billconner
Looks good!
Forgive me if you have looked at this but the most like failure is the band attached to I studs. The connector is usually only in shear. A couple of lag bolts (showing my age) or structural screws (stronger) in every stud. I would not trust any amount of nails. Probably well detailed and executed already.
Bangon61
BC
Looks good!
2by8 ledger band held to studs with three 4 inch structural screws every foot. My studs are one foot on center
theoldwizard1
SE MI
20220112_142041-jpg.1592248
In general, I don't like to see ledger boards "applied" to a stud wall, but I think you have more than enough fasteners !
The Bean
Delaware Valley (SE PA)
It looks like the only concern is keeping the beam directly over the post...
Drill a few holes and use vertical dowels. There's no way it's going to lift off. Now it won't drift either.
PoorUB
Fargo, ND
billconner
I still like 2 pcs of 2x8 maybe 24 to 30" long sort of "clamping" both beams and post with structural screws. Looks strong. :) Also hides the gaps. I'd probably chamfer the edges so it looked even more designed.
Bangon61
BC
