What's this for, a mezzanine?The notch is for the 3 ply 2 by 12 beam that continues over to the wall 8 feet away. That section will be cantilevered.
YesWhat's this for, a mezzanine?
It is in an 8 by 8 post saddle with a pin into the concrete slab. The concrete slab at that specific point is 3 feet deep and measures 2 feet by 2 feet with plenty of rebar. It was preplanned before slab and rebar was put downAlways I'd like to see the full assembly setup that way you can cross-connect.
Welded steel is my preference. If you thru-bolt, do so at the neutral axis (vertical centerline of the symmetric cross section).
A part of the question is whether the post has any moment-bearing abilities or its just a pin joint to (or sitting flat on!) the floor.
Concur !What I suggested above or like a Simpson Strong tie APVT6 should be fine, assuming the other end of mezzanine joists provide lateral stability.
Yes. The other 9 feet after the post will have a 3ply 2 by 12 going to the wall. With 2 by 8 cantilevered out 2and half feet . The cantilevered joists will be parallel to the joists attached to the LVL. If that makes any sense. I kinda figured the big Tee from Simpson. But I always look at options as long as they dont affect the structural integrityWhat I suggested above or like a Simpson Strong tie APVT6 should be fine, assuming the other end of mezzanine joists provide lateral stability.
Actually that is a great idea. Thank youConcur !
I would also add a couple of 4"+ GRKs form each side of the post to insure that it won't split.
Yes. It's a 30 by 30 square shop. Am building a mezzanine in half of it. One side has 8 foot garage door and otherside has a 12 foot door. Am building mezzanine on the same side as 8 foot door. Click on pictureSo floor joists are hung from side of LVL and sit on top of the triple 2x12? Makes sense. Are the sides of the mezzanine other than along this beam all at walls? Just trying to get sense of lateral stability.
The floor joists hang off the side of the LVL and attach to wall 14 feet away. The triple 2by12 is an extension of the LVL and that small section will be cantileveredSo floor joists are hung from side of LVL and sit on top of the triple 2x12? Makes sense. Are the sides of the mezzanine other than along this beam all at walls? Just trying to get sense of lateral stability.
The reason I ask is because you cant have enough information but you can have not enough. It never hurts to ask and see what others have done. I am very knowledgeable as I have been in construction most of my life. Thanks for your concern and assumptionThe real issue is that the building permit will probably want the engineer to sign off, and stamp it. What he/she will put on the plans is unknown. If this is DIY then all bets are off when it comes time to getting city to sign off. And if there is no permit then why ask on the garage forum? Just do as you want cause you will do that anyway regardless what we suggest here.
2by8 ledger band held to studs with three 4 inch structural screws every foot. My studs are one foot on centerLooks good!
Forgive me if you have looked at this but the most like failure is the band attached to I studs. The connector is usually only in shear. A couple of lag bolts (showing my age) or structural screws (stronger) in every stud. I would not trust any amount of nails. Probably well detailed and executed already.
In general, I don't like to see ledger boards "applied" to a stud wall, but I think you have more than enough fasteners !The floor joists hang off the side of the LVL and attach to wall 14 feet away. The triple 2by12 is an extension of the LVL and that small section will be cantilevered
After you toss the other beam up there, add a couple angle irons screwed into the column and both beams.
Yep. Was going to do that as well. With the big "T" attaching the beams and post to each other . I always try to overbuild.After you toss the other beam up there, add a couple angle irons screwed into the column and both beams.
I seriously do not think it will need much, unless someone rams it with a car, otherwise, where is it going?
https://embed.widencdn.net/pdf/plus/ssttoolbox/2xzvd44qzr/C-C-2021-p301.pdf
