JOE.G
Just wondering what drill doctor you guys would recommend for a Home owner that does wood working and metal work. I have not used one of these since the late 90's and I am assuming they have improved since then. Thanks
I also used one, not sure of the model. I couldn't get good results either. I went to sharpening them on a bench grinder with better results but still not great. I just buy new ones now for all the more I use drill bits at home and work. I have spares of every size so I never run out.I had the 500X model that did split points. One reason I bought it. I don't go through drill bits fast but liked the idea of resharpening and of course there's the 'new toy' aspect' Had a few good and more not so good results. Maybe my technique but too many inconsistent results. Gave up on trying to split points and just sharpening. Having to 'split the web' sucked and finally gave it away to a friend. I could have bought a lot of new drill bits for the $100+ cost of the DD. Just my story.
Yea, if they are a descent USA HSS bit that just needs sharpening. and you have a shitload of them. And you have time on your hands. And you have a hundred bucks, then by all means get a drill doctor, master how to use it and sharpen up all of those singles. Put em in your indexes, sell em on eBay, give em to neighbors. But, don't just shitcan good USA HSS drill bits.I have a lot of bits that I have in a can that really could use a sharpening, I don't use bits like I used to but its a shame to just throw them out. Figured I can try and bring them back and if not then toss em.
I have the 750X. Bought it to sharpen larger (up to 3/4”) bits. There is a bit of a learning curve (instructions pretty much worthless) but view a couple of u-tubes and it’s pretty easy. I’m happy with mine and would buy it again
You steely-eyed, protractor-handed, iron-willed "I sharpen drill bits with my TEETH" people show up in every drill bit discussion...none of them are good, best thing i ever did was trash mine and learn how to sharpen by hand
Yea, and what's wrong with that? Actually it greatly depends upon how far gone the drill is prior to trying to sharpen it. If all it needs is a touch up it's really quite easy to do as the angles aren't going to be much affected. If you let it go to the point of carnage then you need to get the angle and the lip height right and that's a lot tougher. One thing I did find out is that using a conventional grinder is much superior to using a belt grinder as the conventional grinder, due to it's wheel being round, is much easier to get the back relief you need.You steely-eyed, protractor-handed, iron-willed "I sharpen drill bits with my TEETH" people show up in every drill bit discussion...
Imagine if you are a girl saying that will never get you laid.You steely-eyed, protractor-handed, iron-willed "I sharpen drill bits with my TEETH" people show up in every drill bit discussion...
