RivennHewn
I may have killed it last nightWhere's my 12-pack ?
... mercy killing.I may have killed it last night
Yes. The detachable mounting will happen.Reminds me of when I redid the double Bimini top on my boat. The company I had make the new unit just wood screwed it to the gunnels. So I made a bunch of backing plates and machined a piece to hold two Phillips tips that locked into the bracket so I could crawl into the bowels of hell and install the plates and nyloc nuts by myself.
Much alcohol was consumed and a substantial amount of cussing happened that day.
This is probably a bit too late
When I did my enclosed trailer I welded bolts to a backing plate then held that up with some tekscrews so I could drop the winch in place and nut it off.
I resemble that remark.It’s really too bad you two antisocial bastards don’t have any friends willing to help.
Me too. Oh wait ..... got Shorty.I resemble that remark.
A lot of oil field bed had a headache rack mounted winch, and welded on a piece of 3 or 4" half pipe (split length wise). The pipe protected the cable some what and helped get the skid mounted equipment on/off compared to the sharp edge like a standard bed did. Of course many had gin poles as well, that they would lift up the front edge of a piece of equipment and back up until it was setting on the back edge of the bed. Unhook the winch from the gin pole and directly to the skid and drag it the rest of the way on the bed.Fab’d up a little bracket to mount a roller fairlead on the back of my flatbed. I’ll feed the winch line through this to pull log directly towards the back of the bed. Then the mailman brought me some log skidding tongs.
One more package containing some additional mechanical advantage coming soon!
That’s kind of where I’m heading.A lot of oil field bed had a headache rack mounted winch, and welded on a piece of 3 or 4" half pipe (split length wise). The pipe protected the cable some what and helped get the skid mounted equipment on/off compared to the sharp edge like a standard bed did. Of course many had gin poles as well, that they would lift up the front edge of a piece of equipment and back up until it was setting on the back edge of the bed. Unhook the winch from the gin pole and directly to the skid and drag it the rest of the way on the bed.
The truck I had the gin pole was completely removeable. Two sets of two tabs stuck up (say 3x3x3/8 with 3/4 gap between) were up by the head ache rack on either side of the 10 ton pto winch, another set were in little trap doors up about a foot and a half from the back on the sides so you could flip the door close and have a clear bed. The tabs had holes for 1" pins with spring clips.That’s kind of where I’m heading.
I thought about a gin pole setup/log arch for the flatbed, but not ready to commit to welding up a structure for that.
I love having an uncluttered flatbed, so I want everything removable.
I have a max log size on the mill, so I’m gearing the setup to that.
Nice save on the hatchet, Riv. You took off just enough to make it interesting...Free axe.
Cleaned it up a bit.
Works as good as my new Stihl.
No name, just some numbers.Nice save on the hatchet, Riv. You took off just enough to make it interesting...
Brand name on it anywhere?
Not yet.I just may need to order a second one to permanently mount to the workbench.
Anybody else have a crane on their workbench?
I just won’t believe that nobody on GJ has a crane on their workbench.Not yet.
Jumped in the SeaNymph, rev’d up my little Johnson, and brought home some big wood!
TMI .![]()
Please tell us this comment was intentional, LOL. We are to assume you were on the river and not in the red light district, correct?rev’d up my little Johnson, and brought home some big wood!
Isn’t there a little blue pill for that?2 minutes start to finish?
You might be suffering from
“premature entimbercapturelation”
So many variables.How long do you have to dry them out for before they can find a new home Riv?
Either way, he's having fun.Rule of thumb for air drying is a year per inch of thickness. You might see a quicker ROI from aged scotch than some of the beams.
Money grows in treesRule of thumb for air drying is a year per inch of thickness. You might see a quicker ROI from aged scotch than some of the beams.
