Sawmill
R
RivennHewn
PNW
No small feat.
Can’t reach up from underneath due the the ram/mounting brackets.
Had the bed up and down a dozen times.
Raise, brace it up, work, lower, be on the top and bottom at the same time, lower/raise, work, repeat.
Need a couple longer bolts to go through the main support member.
LXCam
Reminds me of when I redid the double Bimini top on my boat. The company I had make the new unit just wood screwed it to the gunnels. So I made a bunch of backing plates and machined a piece to hold two Phillips tips that locked into the bracket so I could crawl into the bowels of hell and install the plates and nyloc nuts by myself.
Much alcohol was consumed and a substantial amount of cussing happened that day.
This is probably a bit too late 😖
When I did my enclosed trailer I welded bolts to a backing plate then held that up with some tekscrews so I could drop the winch in place and nut it off.
R
RivennHewn
PNW
Yes. The detachable mounting will happen.
I’d rather it ride in the toolbox until needed.
But I was trying for a quick and dirty install in case I need it this weekend.
And, boat work *****.
R
RivennHewn
PNW
Fab’d up a little bracket to mount a roller fairlead on the back of my flatbed. I’ll feed the winch line through this to pull log directly towards the back of the bed. Then the mailman brought me some log skidding tongs.
One more package containing some additional mechanical advantage coming soon!
Firebrick43
West central Indiana
A lot of oil field bed had a headache rack mounted winch, and welded on a piece of 3 or 4" half pipe (split length wise). The pipe protected the cable some what and helped get the skid mounted equipment on/off compared to the sharp edge like a standard bed did. Of course many had gin poles as well, that they would lift up the front edge of a piece of equipment and back up until it was setting on the back edge of the bed. Unhook the winch from the gin pole and directly to the skid and drag it the rest of the way on the bed.
R
RivennHewn
PNW
That’s kind of where I’m heading.
I thought about a gin pole setup/log arch for the flatbed, but not ready to commit to welding up a structure for that.
I love having an uncluttered flatbed, so I want everything removable.
I have a max log size on the mill, so I’m gearing the setup to that.
Firebrick43
The truck I had the gin pole was completely removeable. Two sets of two tabs stuck up (say 3x3x3/8 with 3/4 gap between) were up by the head ache rack on either side of the 10 ton pto winch, another set were in little trap doors up about a foot and a half from the back on the sides so you could flip the door close and have a clear bed. The tabs had holes for 1" pins with spring clips.
I would pull the pin on one rear pole, top and bottom and remove. I would then attach the hook to a bail on the back of the boom pulley head and take the weight off the other back pole and remove that one. Then I would use the winch to lower the front arm/boom pulley to the deck and unhook those arms from the bed. Those two arms were welded to the boom pulley plates into an a frame. They were some what ungainly and I would hook to a post and drive away. I would use a spreader cable to drag it back on but with a smaller truck like yours it wouldn't be that bad by had I think.
R
RivennHewn
PNW
I just may need to order a second one to permanently mount to the workbench.
Anybody else have a crane on their workbench?
R
RivennHewn
PNW
At my end of the scale, you don’t get machined bearing surfaces and bearings. You get 3rd rate welds, with splatter, and glumpy powder coating.
The pivoting arm was less than wonderful.
I cleaned up the bearing surface, then added a well greased disc of UHMW to bear on.
Rides smooth now!
Edit:
Of course, just as I think I’m happy, the zirk breaks off😜
R
RivennHewn
PNW
Pulling logs out of the channel is easy.
Getting them into position to load on the mill is a little more involved.
R
RivennHewn
PNW
After trimming the rotted ends, it measures 16’ 9” X 24” diameter.
Estimated weight 2500 lbs.
Should net me just over 400 board feet. Currently +/- $10 per BF. (Best case)
LXCam
How long do you have to dry them out for before they can find a new home Riv?
