Need Freeze Plug Installation Tool Made, Have Drawings
bulletpruf
San Antonio
Fellas -
I have a 1994 Ford 7.3 IDI turbo diesel (not Powerstroke) that I need to rebuild and install new freeze plugs in. These are supposed to be really tricky to install without causing leaks, and I don't want to have to pull the motor to re-do.
Rotunda made the tool, but it's NLA and I can't find one to buy, new or used.
Someone was making these and selling them, but he quit a few years ago.
Here are the plans -- anyone here interested in making one? http://www.dieselwarden.net/temp/freezeplugtool.jpg
Thanks
Scott
larry4406
Northern Virginia
How is it used? BFH used to drive in the plug?
I’m thinking a piece of 3/4” black iron pipe which is 1.05” outside diameter for the long stem. Thread it into a coupling, chuck it in your lathe, and bevel/machine the coupling to your dimensions.
bulletpruf
San Antonio
Yes, used with BFH to drive in.
Thanks
isb cornbinder
Those plugs are core plugs. They have a purpose as part of the casting of the block.
I use a liberal layer of Permatex Aviation Form a Gasket on the outside circumference of the plug before installation. Driving the plug into place should not require a specialty tool. The machine shop I worked in had made a tool, but it was little more than a fitted steel punch that fit the inside of the plug. A machinist hammer and some carefully placed blows should seat the plug.
I hope, for your sake, you have had that block and the heads machined for flat and true. Those engines tend to change shape from heat cycling over years of use.
bulletpruf
San Antonio
The block has not been machined yet.
lilredex
Toronto
Many moons ago I worked in an engine rebuild shop and we installed "millions" of those cup type frost plugs. We had a machined stepped plug driver to drive them in flush with the surface. A liberal coating of gasket goo and staking like in the picture kept them in place.......never had a failure that I was aware of. In the years since I've used a flat washer welded on a punch to do the driving.
83VillageRepair
Merkel, Texas
I would find a 1/2 or 3/4 drive socket with the right OD and carefully grind the profile you need and then use a sacrificial extension and bfh. I will be interested to see what you come up with as I have an IDI project waiting in the wings and I use a turbo IDI as my primary tow vehicle.
65ranchero
Danville, VT left NJ forever
True Story
this expansion plug install reminds me of a install go bad.
While I was working in a dealer a flat rate flat rater ( also known as speedy) was given the chore of installing a block heater in a customers car. Being it was a simple task that would only take about an hour ( all that had to be done was drop the starter on a 4 cyl and knock out the exp. plug and install block heater.
Well this guy tried to knock in the FP straight in and being it was too close to the cyl wall so he could not move it to grab it by the edge for removal.
At about the same time the service manager was walking by and the tech commented to the SM that he cannot remove it.
SM said "drill it out" so he did but he was no paying attention and drilled right through the #4 cyl.
So this tech had to buy a short block and donate all his time .
isb cornbinder
It is common for a machine shop to install core plugs. It might cost you another dollar to have the machine shop do the installation. If the plug leaks, the machine shop should take responsibility. A good machine shop will want to clean the block with the plugs out.
Picture #1 sows a prepared core plug opening in an IHC LB stationary engine. Picture #3 shows using a hole saw to clean the core plug hole. Picture #4 needs no explanation.
JHenke
You can rig up the radiator and pressure test your work.
This is a Jeep 4.0 being tested. Spray each core plug with soapy water, radiator tester pumped up to 15 - 18 psi.
bulletpruf
San Antonio
Yep. I'm familiar with the process. Have rebuilt a few engines and usually have the machine shop install freeze plugs. Having said that, I'm inclined to do these myself unless I manage to find a shop locally that has experience building IDI's.
One of the guys who specializes in IDI's - R&D IDI - uses a hole saw to remove the step that the freeze plug sits on. Once that's done, he installs normal cup style brass freeze plugs. Video here -
Thanks
Garage Junkie
Cleveland, OH
If you do decide to continue looking for someone to make this tool for you, I just want to point out that the dimensions as stated on the drawing are not accurate. I'm not sure which dimension is incorrect, but the drawing shows a chamfer of 45 degrees on the face of the tool, yet there is a .275" difference in diameter with only a .175" change in length. This will need clarification for a machinist to follow.
For another alternative to what others have posted- for less than the cost to have this tool made, you could go pick up the harbor freight seal installer tool kit. The 39.5MM head is close to the dimensions you are looking for and could be hand machined to the spec quite easily. Chuck it up in a drill press and grab a file. Just a thought.
bulletpruf
San Antonio
Thanks! That's something that I can handle. I'll also need to check to see if any of the seal installers that I have on the shelf might work with some minor machining.
gorilla
If you study that installation tool it becomes clear that the length of the two parts controls the amount that the freeze plug is expanded. The difficult part would be machining the radius on the bottom of the larger tube. Heat treating would be a difficulty for a home shop I'd guess about two hours to machine and about $100.00 materials without heat treat.
ChevyEFI
Phoenix, AZ
Why does it need to be heat treated for a one time use? Unless you are a shop that plans on doing this job multiple times.
I have had a specific transmission application bushing driver (OEM tool and tool truck tool discontinued) turned.
I agree with the above messages. When you have the emgine in front of you, and the time, explore an off the shelf driver, or turn your own, or have one turned if it needs a tight dimension.
metlmunchr
I agree. That tool is designed to produce a specific amount of expansion once the plug bottoms on whatever lip is cast into the holes. Trying to get the same results from standard bushing drivers is unlikely.
I did notice a post on another site where an owner of one of the original OTC tools gave a couple details that are missing in the OPs sketch. He said the 1.5" OD on the tubular piece is undercut by about .030" on the last inch or so to make sure the piece doesn't jam in the block opening. Also, there's a flat about .060" wide on the end of the tube before the 3.5" radius starts such that the end of the tube doesn't have a sharp edge on the end.
Wrench97
Southeastern Pa
It's been quite a few years but I have done several on T444E IH engines pretty sure they take the same plugs without a special tool.
