Above 1200 Sq/FT Craig's Colorado Car Condo
C
Craig Balzer
Colorado Springs
Took a break from restoring and did some fire mitigation on my lot. That entailed renting a scissors lift (got one that was all-terrain with out-riggers) that also worked well to reach my 14’ ceiling to install some piping to distribute compressed air. Got about 80% of it done; 100% of the piping in the14’ high room.
Between the trimming of limbs and installing piping, I spent three days climbing that scissors lift.
To make maneuver room in the garage for the scissors lift and not bump into things, I moves benches, tables, engine stand, etc to one side of the garage
1 - Pushed tables and benches to middle of garage1920×1920 443 KB
I not only installed piping, but hung some banners
2- to have room to hang some Banners . . .1920×1920 297 KB
That fitting in the above photo is open – haven’t decided if I’m gotta cap it there or install another drop around the corner on the left of the photo
The kit I bought was easy to hang and connect. Of course, I haven’t pressure tested the system, yet.
3 - and installed distributed air pipes and walls . . .1920×1920 308 KB
Also installed a leg to bring compressed air above my lift. The one section got a little crooked. The open end of the pipe in this photo will lead to the compressor (just out of frame to the right of the traffic light) and then to the small room (with 10" ceilings) and the dirty – none of these elements require a scissors lift
4 - and ceilings1920×1920 372 KB
Took advantage of the open floor to sweep/mop
5 - took advantage of empty floor to sweep and mop the floor1920×1920 283 KB
20220516_1652111920×1920 462 KB
fouckhest
Greer, SC
Looking great, I really need to get my air hooked up in my shop, been debating how to make it look nice, but still be functional.....
C
Craig Balzer
Colorado Springs
Fouckhest
Don't feel like the lone ranger on that score: I think I had that tubing and the boxes of fittings laying around my shop for 7-9 months.
The real trick is that I still have about 6 lengths of the tubing -- at 19' 2" each.
Go ahead and try to store those -- even in a shop with 14' ceiling; that'll really be an incentive for me to finish up the install
Craig
fouckhest
Greer, SC
LOL! Thanks of the reinforcement!!
I would really like to find a way to run a 3/4" header/hoop around the shop in the attic, then drop down at certain spots, i.e., near my welding table, by the lift for a hose reel, by the work table, etc....
Sorry, won't clutter your thread anymore, keep up the good work :beer:
C
Craig Balzer
Colorado Springs
I think such an approach would be very clean - but also pretty pricy.
I don't know which kit you are considering, but with my kit I needed to order a special fitting to pass the tubing through a wall.
I imagine you'd need one such kit for every drop coming through the ceiling. How close is your roofline to the walls in your attic where the vertical lines will run -- do you have enough clearance to get close enough to the wall?
Your comments do not clutter any thread -- all comments are more than welcome.
fouckhest
Greer, SC
Yeah, which is a big reason that I haven't started down any given path.
I really haven't looked at any specific kits, I have some sort of 1/2" line kit that I got when I purchased my compressor from a buddy years ago, its a blue flex tube (coil) with push to connect fittings. Unfortunately seeing that line, between color and not being straight would drive me nuts....
Good question on the wall clearance, I will need to get up there an look. My thought was always run the hoop/header in the attic, then drop down into the garage with black iron pipe....but we shall see what other options I may be able to come up with.
At this point, I am in the middle of a master bed/bath remodel, in the final wedding planning stages, so it will likely be the fall before this becomes a priority; post wedding.
Thanks, appreciate that and the advice.
C
Craig Balzer
Colorado Springs
It sounds like your kit may be Rapidair MaxLine -- while this kit from Northern tool is 3/4",
and they also carry 1/2" lines.
I share your aversion the coils looking like **** UNLESS you can straighten out the tube perfectly. Hard to do.
I used the Rapidair FastLine aluminum tubing.
fouckhest
Greer, SC
Thats exactly what I have today. I do like that they make a 3/4" version, that might be a good option for my supply hoop.
I will certainly look into the fastline tubing kit, that would be great b/c it could then be painted, thanks for the heads up!
C
Craig Balzer
Colorado Springs
I used this last week to deal with several errands: picked up my re-newed header tank (re-soldered, pressure tested and painted a non-runny black), finally linked up with the guy who owns and is chief mechanic at The Differential Shop re timing for him to rebuild the innards, and a few other items/issues.
Then I got a weather-imposed work delay. All last week the temps were mild (upper 50’s to mid-60’s – 1 or 2 days even reached the 70’s and low 80’s. Then Friday the high was low 30’s and light snow mixed with sleet greeted the morning – it didn’t get better throughout the day.
Three photos follow -
5PM on Friday
6:30PM on Friday
8AM on Saturday (this AM)
5PM Friday 20 May 221920×1920 779 KB
630PM Friday 20 May 221920×1920 508 KB
830AM Fridsaturay 21 May 221920×1920 371 KB
HO HO HO - MERRY CHRISTMAS
Power went out twice last night – I assumed downed power lines
  • 2.5 hours from 0200-0430
  • 1 hour from 0830 - 0930
About the only good news from the last few days is I finally received notice that the parts I need to repair the boiler in my hobby shop (heats both domestic water and the coolant in the in-floor heating tubes) were shipped. Ought to have them earlier on next week. Just in time for the temps to return to the 70’s and 80’s.
C
Craig Balzer
Colorado Springs
I spent the last few days unpacking and cross-checking the inventory of the items I sent out for cad plating compared to what I received back.
Good News: a 100% match. No missing bits.
Bad News: some of the items have less than satisfactory finish. Exchanged several calls with the owner and I am expecting a positive result.
The following photos provide a few BEFORE/AFTER comparisons.
Overall, I am happy with the results. Sparkly stuff – not as sparkly as chrome, but pretty nice, nonetheless
Bonnet stuff
20220105_1312151920×1920 464 KB
20220606_1739591920×1920 319 KB
A/C Stuff
20220105_1317441920×1920 472 KB
20220606_1746321920×1920 218 KB
Door Stuff (plus)
20220105_1325031920×1920 518 KB
20220606_1800231920×1920 307 KB
Fuel Stuff
20220105_1326341920×1920 495 KB
20220606_1804001920×1920 191 KB
Misc
20220105_1351541920×1920 529 KB
The above photo shows 52 Belleview Washers (BW) – I kept finding more and more of them but didn’t retake the photo – just updated my notes for the plater
20220606_1825571920×1920 207 KB
I ended up sending 171 x BWs for Yellow Cad – today I found 5 more that missed the boat. There are plenty of places the BWs are used that are out of site. I’ll just clean them and use them.
20220607_1701541920×1920 654 KB
Tubing
20220107_1629501920×1920 462 KB
20220606_1655431920×1920 236 KB
Some of these are going back for a re-do
More Tubing
20220107_1633501920×1920 450 KB
20220606_1705051920×1920 161 KB
C
Craig Balzer
Colorado Springs
Sorry for the long time-spacing in updates.
Lots of small trip-wires that combined to form some long and irritating delays.
Here's some quick updates of smaller and small successes - culminating in prepped pieces waiting to be installed in/or the chassis
  • Removed separate Reverse Lamps and installed LED brake/tail lamps with integrated reverse light
  • Received polished stainless exhaust system
  • Ordered and Received new Radiator
  • Had machine work done on both heads
  • Had heads rebuilt with ALL new components (valves, valve springs, keepers, collets, valve seats, etc)
This kept me busy in June and July this past summer.
NOTE - this is a truly irritating aspect of this site. For the next half dozen postings I carefully ordered the photos with the bulletized comment(s). You know, so they followed in order and made sense and all.
Despite that, all the photos were loaded in apparently random order confusing comments and the related photo(s).
A real pain in the tookus.
C
Craig Balzer
Colorado Springs
July and August focused on
  • Restoring fuel sender assembly and such on fuel tank
  • Removing and Disassembly of front suspension pieces for cadmium plating - some Before /Afters
C
Craig Balzer
Colorado Springs
August/September kept me busy recerving more part$ and laying out interior kit by prepping the interior
  • Receiving replace windscreen
  • Laid out new boot under-pads foe gluing down - in prep to install fuel tank
  • Media-Blasted block for cleanliness
  • Cleaned / Vapor blasted Cam Covered in prep for customized Powder Coating by @CudaChick1968
  • Had connecting rods balanced as well as crankshank polished
C
Craig Balzer
Colorado Springs
Time intensive parts was inventorying complete interior kit and X-matting interior floor for heat reflection and noise/vibration reduction
The hard part was placing the under pads - no layout plan, no directions, no labels
C
Craig Balzer
Colorado Springs
Then laid out all the new engine components to ensure when a friend (retired Jag mechanic) travels to my place from Denver for the technical aspects of laying the crank and installing the timing chain with guides and tensioners that I have everything at hand
  • Pistons with wrist pins, circlips, and rings
  • Cylinder Sleeves
  • Rear Main Seals / Crankshaft spacer and cone
  • Main Saddles and Connecting Rods
  • Oil Pump and Oil Cooler
  • Crankshaft Pulley, balanced Harmonic balancer, bits and pieces
  • Timing Chain, Cam Shaft Gears, chain guides and tensioner
  • Pressure Plate and Clutch
  • Light Weight Flywheel
  • Large and Small Bearing sets
C
Craig Balzer
Colorado Springs
Some bits and pieces
Assembling front suspension; struggling with pressing new bushings into housing
Applied ACF-50 anti-corrosion to blasted aluminum bits to seal porous surface to help shed grease and grime
Built-in oil cooler (I have two so one photo captures both sides) - routes coolant through zig-zag oil passages. Cools oil by 20° C while only raising coolant temp by 2° C
C
Craig Balzer
Colorado Springs
Took time out to nearly check off Bucket List Item
  • Bucket List Item: attend Packer's home game at Lambeau and tour stadium
  • Near Hit - flew to DC on the 23OCT22 weekend that Washington Commanders were hosting the Packers. Closest friend works for a company whose CEO has an Execute Box at FEDEX Field. Watched Packers lose game in pampered comfort, Box included parking pass and pre-game field pass
C
Craig Balzer
Colorado Springs
Can't believe I missed the MOST striking change I made in the last 6 months (that's what I get for trying to cram 6-7 months into posting over several minutes)
Back in July, I decided to go with Ceramic Coating (not a wrap). It's hydrophobic, defeats sun fade, provides another layer of paint protection AND looks like fresh, wet paint for years.
I was, at first, a bit apprehensive when the guy said he was gonna start by cutting the paint. My painter used 3,000 grit on his final pass. I didn't want all that work undone. The ceramic guy said his pad was rated at 30,000.
Then a final polish to remove any/all swirls, and such
The guy had never
  • worked on a car that was in pieces (I had him ceramic coat the underside of the bonnet as well as some of the engine side frames that would be visible when I am done)
  • worked at a private residence (usually requires the car to be brought to him)
First, some befores (3). (IF they stay in order)
Mind you - the paint is only 6 months old and has (obviously) never exposed to road, stones, or sun. So there was no corrective work needed.
Then some During and Afters (6 more)
TMI
This outfit offers 4 levels of ceramic coating, based on length of the guarantee: 1, 3, 5, and 7 years and the cost of each depends on the size of the vehicle: small (mine), medium, large, and suburban assault vehicle
The five and seven year applications requires professional application. Not that applying ceramic is hard (as easy as waxing a car). The pro level is to ensure the substrata is polished and flaw free before "locking" it in under the ceramic coating.
Five and seven include two bottles of stuff
  • the first is chemically configured to adhere to paint
  • the second is chemically configured to adhere to the first ceramic layer
The clear liquid is applied with a 5" circular sponge pad on a 2x2 foot area and allowed to haze over (2 minutes).
The haze is polished away using a microfibre towel.
Can not let the car get wet for 24 hrs; fully sets up in 2-3 days
EDIT - YUP!!! - scrambled order AGAIN!
C
Craig Balzer
Colorado Springs
Well Guys --
It has been just over a year since my last posting regarding the restoration of my 72 Jaguar XKE V12 Convertible.
The first few months of the past year I moved forward apace. That is -- until I hit a stumbling block I was unprepared to overcome on my own. When my retired-Jaguar-mechanic friend came to COS from Denver to lay the crankshaft, he also placed the heads in place. May sound easy but each head is secured by 26 studs so getting each head in place requires some finesse.
He had to leave to take care of some errands back home so that left it to me to torque down the heads. Easy-Peasy.
One a Jag V12 block there are 14 major studs placed quite closely to the cylinder holes; they are inserted into the block inside the water jacket. Fortunately, all those took the 52 lb/fts of torque without issue.
The other 14 studs thread into the flange of the block interface with the oil pan (see photo). Two of the adjacent small studs spun in their holes while I applied the torque - both on the same head. SH!T. That was in mid-summer
That resulted in a series of delays and such preventing my buddy from returning to help and several aborted efforts to affect the repair without removing the head.
It is late December and I sill have been unable to link up with my buddy.
So I embarked on a series of efforts to make a pile of bits and pieces into a sub-assembly. In no particular order these are the small assemblies that were assembled. Once the engine / head studs are corrected, the engine can be further assembled, and installed. Once installed, these sub-assemblies can be placed on the car.
C
Craig Balzer
Colorado Springs
As shown on a previous posting, I had the suspension bits cadmium plated.
I installed the front suspension - less the uprights. With the uprights still on the bench I can flex the arms out of my way to gain easier access to the engine bay. Obviously, new bushings were used.
The second photo shows angle of the system once mounted - shows the anti-dive geometry
C
Craig Balzer
Colorado Springs
I installed the trunk (AKA - boot) sound-deadening mats, the rebuilt and newly cadmium plated latch mechanism and the fuel tank.
Installing the fuel tank was only possible by invoking several Old English curses and invectives.
Just need to install the new fuel lines and the electric fuel pump
C
Craig Balzer
Colorado Springs
I rebuilt the radiator frame with the new aluminum radiator and rebuilt twin electric cooling fans (controlled by 2x relays) with new fan blades
C
Craig Balzer
Colorado Springs
The V12 XKE has a basic fresh-air ducting that funnels air from the radiator opening through a duct hose into the passenger cabin.
First photo shows the 2" opening on the firewall (just above the brake booster).
I found a 2" duct fan that I plumbed into the hose and will wire it to an unused switch on then dash board. cut a slit in the fan housing to route the power lead into the opening and then to the fuse block. Doesn't push much air but will help in stop/go traffic and when stopped/idling.
C
Craig Balzer
Colorado Springs
I rebuilt the heater core and housing.
Won't attach it until very near the end of the restoration process
C
Craig Balzer
Colorado Springs
I had sent out the four small gauges (fuel, water temp, oil pressure, and volt meter) and the 2 large gauges (speedo and tach) to be rebuilt by West Valley Instruments. Time to install them along with new wiring harness.
After doing the Gauge Panel, I did same to the Tach/speedo panel.
Then knocked it over onto a bolt. Oooops. Time for a redo.
Also replaced 90% of the old incandescent bulbs with LEDs
C
Craig Balzer
Colorado Springs
The most frustrating operation (aside from the head stud debacle) was getting the window regulators to operate quietly and smoothly,
The passenger side was too easy -- it doesn't get much use.
It took 11 tries to get the driver side regulator to operate quietly. Turns out the rust and years-old grease on the lifting coil spring was the source of the noise.
Too many photos of the during.
Just a video of the before and after -- on YouTube:
Before:
After:
C
Craig Balzer
Colorado Springs
I opened a can of worms when I took apart the steering column for cleaning and restoration.
The problem is I am having issues on reassembly - hoping my retired Jag-Mechanic can fix this issue too.
The last photo shows my issue - I don't believe there is supposed to be an air-gap above the white plastic spacer
C
Craig Balzer
Colorado Springs
Installed the newly chromed rear bumper with a new body seal
C
Craig Balzer
Colorado Springs
I dropped the Independent Rear Suspension (IRS) -- actually my Jag-Mech-Buddy did 99% of he work.
I watched and provide tools and encouragement.
I then pulled the mounting bushing that needs to be replaced and cleaned up and painted the undercarriage where the IRS sits.
Still need to source the bearings and bushings and stuff to rebuilt the cage and then have the pumpkin rebuilt.
There is a heat shield that I left in place (doubt I could remove in one piece) but I cleaned it up and painted with heat-resistant paint
C
Craig Balzer
Colorado Springs
Sooo -- there is one year of progress condensed into a handful of postings. There were other minor accomplishments but these cover the major efforts.
I am very much looking forward to over coming the head stud issue and determining if I am correct regarding the steering column.
My goal is to get my car back on the road and functional sometime the summer of 2024 🤞
Cris B
Lancashire, UK
Amazing garage space, really enjoyed reading about that.
Appreciate you attention to detail on the E Type restoration. It will be really special when you finish it. Great workmanship 👍
C
Craig Balzer
Colorado Springs
Thanks Chris
I really enjoy working in there - lots of space.
I haven't even come close to inadvertently scratching any newly painted surfaces.
I look forward to actually driving it again. Last ride was in September of 1990
C
Craig Balzer
Colorado Springs
Time for an update. Gonna condense a year+ into a handful of photos
I ordered fuel line kits from SNG Barratt for the boot and engine compartment. I was expecting rubber fuel lines with the original red stripe running along them. Got this (partially installed):
Next step was on the opposite side of the car. I had to familiarize myself with the 7 wires coming out of the 8-pin connecter beside the driver's headlight and the dozen (+/-) wires leading into and out of the 16-pin multi-connector that is bolted behind the US drover’s headlight. These wires power the headlights, turn signals, side lights -- that sort of thing
Here is the 16-pin multi-connector with 135,000+ miles with of grime and grit.
During that procedure I also compared the original 8-pin plug and 16-pin connector to the new ones I am installing.
Everything matched up with one exception.
The original 8-pin has 7 wires on it
After a couple hours over several days, this is what I had with new connector block and wiring. After drawing a schematic and checking it 4-5 times (OCD + **** Compulsivity) and laying the original on the bench, I aligned the new wires onto the terminal block
New 8-pin barrel plug
and new 16-pin connector (only for the truly over-the-top example of OCD + **** Compulsivity)
Also spent some time chasing wiring and deciphering schematics - even less photo-relevant. I still have 6-8 wire ends that to meet their mate/terminus. After getting as far as I could, I decided that perhaps a change of perspective may help. This is just a fitment test as I figure these panels will be in/out a few times.
C
Craig Balzer
Colorado Springs
Next I had success in reattaching the driver side and passenger side demister control cables.
The driver side would have been much easier IF I had taken the time weeks ago to clean up the receiver and cable end on the bench rather than under the dash board. Also - test fitting the proper roll pin on the bench would have been how a smart guy would have done it. But the vent was installed under the dash and I didn't wanna go backwards.
I needed a teeny, tiny roll-pin to secure the cable end in the receiver on the vent (I did NOT lose the original but it was mangled during extraction). That is when I thanked myself again for the Craig's List purchase made years ago. I bought 4x of these hardware storage tray racks - complete with a stock of pieces.
Here's two of them,
Did I say I was looking for a particular pim? Seems I have a selection:
A lifetime supply:
I one I needed was in the upper left corner of this drawer
On 23APR24, I received 2x boxes from Jet-Hot. My exhaust system pieces are back after the coating being applied inside and out. The mufflers were NOT coated inside - just on the outside for obvious reasons.
The headers (from Moss Motors) were packaged so well when I received, I simply sent them on without opening the box. Due to the co$t of Jet-Hot coating, I did NOT $end the resonator a$$embly.I reasoned that that assembly was behind the cabin and far enough down stream that NOT coating it would have minimal effect.
Happy Snap Time - captions
I was reassembling the window regulator and bits on both doors. This is what happens when you install the regulator and glass with greasy/slippery hands. The guillotine effect is to be avoided:
Note the “missing segment” of the reflection of the line in the cut in the concrete floor (right in the middle of the photo). It still smarts to look at it.
I took a break from destroying my Jag and the paint on my 65 Buick Riviera Gran Sport buffed and ceramic coated
Back to work on the Jag (we are now in mid-April 2024). I have been adding pieces to the bonnet and discovered an area that I failed to capture any photos of. The harness in question splits power from the 8-pin plug to the passenger side.
Here is an overview of the pieces
I determined the wiring harness is fed through the tunnel in the bottom of the bonnet nose to the passenger side.
and comes out near the passenger headlight
C
Craig Balzer
Colorado Springs
In May 2024 I started installing small pieces that were easier to do with the engine out of the way. I’ll be the first to admit this photo doesn’t look like much. After all, all it shows is three brake lines attached to the 3-way.
The truly observant among you noticed the sliver of black plastic under the horseshoe. I put that in there as reinforcement for a potential jacking location (couldn’t source a really hard wood). It is a piece of Delrin Acetal Plastic that is 17" long, 1" wide (fits snugly in the recess at the bottom of the horseshoe) and is 1.5" up into the horseshoe.
I notched the Delrin to clear the three bolts securing the hold down bracket. The notch removed 1/2" of material leaving ~1 inch bridging the bolts.
I used steel "zip ties" as a suspenders and belt" approach to keep the Delrin piece place
A Jag Lovers thread regarding the V12 oil pressure relief valve reminded me I had previously tried unsuccessfully to remove mine. It takes a 1-1/2" socket/wrench to open it; I didn’t have one. Amazon!
The oil pressure relief valve threads into the opening at 4 o’clock in the above photo. I wanted to see if there was any crud in there and check the status of the o-ring. Cleaned out the crud and soaked the relief valve in rust remover to clear up the innards. It appears the relief valve may be frozen and needs to be freed up. If the rust remover doesn’t free it, I’m hoping a bath in my sonic ******** gets the job done.
After only 2 hours, the solution is already working. The aluminum (?) washer needs to be renewed. However, I am pretty sure the o-ring may also need replacing.
On Monday 24JUN24, Jeff’s (a Jag V12 mechanic friend) visit was to conduct a main frontal attack on the two recalcitrant stud holes. I tried chemically bonding the replacement studs in the holes. The bond didn’t hold the torque (27.5 lb/t).
Jeff wanted to buy grade 8 bolts and fashion them into the replacement studs. NOTE: Jeff measured the new replacement stud cuz with his calibrated eyeballs he saw it was thinner than the original. Hmm. So we stripped the identical stud from my eBay spare block and took it and the micrometer to buy the hardware.
It took 90 minutes to visit ACE, select the items, and return. We got back only to discover the grade 8 bolt was too thick. How the hell did that happen?? Rather than waste another 90 minutes going to/returning from ACE, we opted to use the proper tools (that Jeff brought along) to do the job properly.
Captions = details
Used a pair of zip ties to secure cam gear to chain
Some good news (to counter-balance the bad which I am about to post). When Jeff removed the head, he figured out which sized Time-Serts were needed to make the proper repair.
The 10x 1.00" deep Time-Serts arrived in the mail (smallest amount I could order)
Along with the Time-Sert Installation Kit ($100 - ouch)
The Oil Pressure Relief Valve is pictured cuz when we removed it from the housing it was dirty and stuck (what else is new).
I soaked in it Blaster rust remover and after 2-3 days the internal plunger was freed. Just gonna take a while to source the proper O-Ring.
The bad news will be on the next posting - bumping against the 10-photo limit
