Crowbarman55
- Joined
- May 22, 2021
- Messages
- 1,095
Turned the MRCOOL on in the garage and left for work.
Todd
Todd
So I plan on maybe getting some hooks to go into the rafters, but I also have to keep in mind that my wife wouldn’t be able to reach them without a stepladder so the wall kinda works for now.For rod storage my dad used smaller hooks on the loft rafter/joists, and I use aluminum bars on spacers from my work room ceiling (only 7 ft...)
Actually, moving the wireless master to there has improved the network performance immensely. Prior to the move my devices' favorite word was Loading....... It's totally counterintuitive. I just stuck it there temporarily til I could find a better home, but it's staying now.I'm not sure I'd put my wifi equipment hard adjacent to my electrical panels or to a doorbell transformer. The amount of electrified metal has got to be both blocking signal AND generating RFI. The area right behind those two router / wifi devices is chock full of romex, just inches from your antenna. That's like trying to look thru the gaps in a wood fence, in terms of signal blocking.
Is there somewhere far from all that where you can put your wifi, at least for a test? All you need is an outlet and a long Cat5 cable. And you might find out your wifi doesn't actually ****.
C-Clamps are your friends here.Sorted through my drill bit assortment, on the floor... I dumped the full case of consumable bits and a full can of Pepsi when the workpiece I was drilling caught on the bit and swung around out of my hands. That was enough for today...
Of course, and I know thatC-Clamps are your friends here.
None of us would ever admit how many times we actually had a piece of steel fly out of our hands because we were “just gonna drill something real quick“lolOf course, and I know that. This post is equally (if not possibly more) relevant for the "Ever-do-something-so-stupid-you-wonder-if-you-should-be-left-unsupervised" thread.
I have clamps, just have to figure out where I put them after the move... I had bar clamps across the shop, not unreasonably out of reach, I just didn't grab them because I had a good hold on the piece for the first two holes. I'll get back to that project tomorrow, had to go to my parents' place to check on the boat and the mail. They're not back until Friday/Sunday.
Treadmill motors and electronics are good for powering other projects. I made a welding positioner from my wife's treadmill. The 90 volt DC motor powers the turntable and chuck. The screw-motor that raised and lowered the running surface, now operates the tilt. I had to mill out a new tone-wheel to trick the sensor and slow the motor by 50%.Completed my upgrade from 12 to 16 inch bed on my mini lathe, Took apart a free treadmill saving the motor for the future mini mill upgrade when original dies. Kept the walking belt to use for workbench and in tool boxes...
Only because it's happened so many times, you can't recall them all - unless of course it left a scar... (Yeah, Left thumb and forefinger, I remember that one..None of us would ever admit how many times we actually had a piece of steel fly out of our hands because we were “just gonna drill something real quick“lol
They make Shop calls?Haircut.
I haven't found a consistently good place since I move here however, yesterday I may have found one.
Save the plastic slider sheet under the belt - works GREAT for sliding under a car/truck... Better than a creeper.Completed my upgrade from 12 to 16 inch bed on my mini lathe, Took apart a free treadmill saving the motor for the future mini mill upgrade when original dies. Kept the walking belt to use for workbench and in tool boxes...
That reminds me of a movie I saw called the Worlds fastest IndianWatching the movie”The Last Indian”where Anthony Hopkins character was making his own pistons, I got interested in the process. After a little research, I realized I wasnt nearly skilled or patient enough..lol Nice work.
Sounds like you need a young priest and a old priest,sometimes there’s just something evil that no amount of tinkering can correct.Good grief, this ZX11 is trying to test my patience...
Got it all back together yesterday & it manifested another fault.
First it had an issue where pushing the starter *** would only result in a *click*.... Twice, then it would turn over & fire up on the third press of the ***.
But ONLY when there were witnesses, it would fire right up when I tried to diagnose the issue in the garage or it there was no one around when I was out on the bike.
Turns out the battery terminals weren't *tight*.. but they weren't loose either.
It's stopped doing that...
NOW (since yesterday) it spins over when I push the ***, but doesn't fire up until the third attempt... Not the 2nd or the 4th etc, ALWAYS on the third try..
And ONLY when there are witnesses. Yesterday it was another Kawasaki mechanic I worked with years ago. He couldn't believe how clean & *unfucked with* my ZX11 is... Then it took three attempts for it to fire up...
It fires up first press of the *** in the garage or if I'm out on the bike & there's no one around...
This bike has starter cut-off switches on the kick stand & the clutch lever. However, if they are faulty I *think* nothing happens at all when you press the ***. I need to investigate this. I know they can easily be bypassed with a jumper.
FFS.
Ya, that’s the one..lolThat reminds me of a movie I saw called the Worlds fastest Indian![]()
$20 clippers bought 15yrs ago... best investment Ever.Haircut.
Is that some kind of hook or magnet holding up the light? Please share.
Next time I have the bodywork off the bike I need to wheel it outside & give the radiator some attention with degreaser. Not sure how long the fork seal was leaking, but the left side the rad looks like a Superfund site.Sounds like you need a young priest and a old priest,sometimes there’s just something evil that no amount of tinkering can correct.
Do you remember it?Does it count if it doesn’t leave a scar? Asking for a friend…
After months in the hospital, in ICU and 8 months of home recovery, I am starting to feel confident enough to try and make it to the garage. I made it half way to the shop, yesterday when the monsoon hit. Today looks like a better opportunity.
Getting old has been a terrible reward for a life well wasted.
